View Full Version : Metro
Pages :
[ 1]
2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
- 1996 Relay Fuse
- No start, engine turns over
- Gearbox rebuild issue
- 2000 geo metro vehicle speed sensor
- 1994 xfi available Seattle area
- dropping tranny in 99 metro
- For Sale: 1.0L Engine + XFi Transaxle Runs Good
- Timimg decreases when idling at stop
- Alternator question. 1991 Lsi Convertable
- Transmission Option for Model T
- 1996 Metro with undercarriage cancer
- engine swap 3 cly to 4cly
- number of miles obtained on a 3 cylinder
- 1993 Geo Metro Engine timing question
- zero resistance from distributor to the battery through coil wire
- swapping motor manual / auto.
- Eating Camshaft Position Sensors (Ignition Pickups)
- 3 cyl auto no reverse or 2nd when cold good when warm
- '93 Geo Metro Problem - Intermitant and Enigmatic
- 5 Speed manual Transmission Question (97 Metro)
- For sale: 1993 3cyl Geo Metro for parts, Gainesville, FL
- 1995 Geo Metro 3 cyl starter wiring needed
- valve seats ?
- Is this forum dead? All metros owners post an update!
- installing altenator please help!
- 2000 Metro no-startsubmit new thread
- Need Advice '93 Metro 3 cyl
- Engine rebuild with intermittant knock
- 95 Metro no power
- 2000 metro very rough idle
- Emissions ppm
- Front Right Signal out - bulb & socket OK
- Gotta replace brake lines - 92 XFi
- Rubber boot on shift rod into transaxle...92 5-spd
- Chipmunks in the heater fan
- Coolant in exhaust
- Geo Metro Restoration
- 1995 Radiator Running hot
- 95 geo metro
- Shifting problem
- cam sensor
- Where can I get an EGR modulator?
- changing engines
- engine swap
- Metro A/C Amplifier ( computer)
- Warning buzzer on 94 metro
- Geo Metro Code 51 Solution Sequence and Side Benefits
- pinch bolt engineering
- engine stops
- help 3 cylinder has rough idel after rebuild
- 96 Metro 1.3L won't run/idle
- Brake Hose
- Looking for a Metro
- Say it isn't so Johnny Mullett!
- 97 metro lsi
- Changing to 13's
- my 92 3 banger won't warm up
- P1451 code
- EGR valve - fuel mileage?
- Selling my '94 geo metro
- sensor issue ?
- Hood latch springs rusted out...
- Can you install new muffler in one piece up to cat easily?
- Threw in the sponge yesterday
- High intake air Temp
- Fuse blows on transmission shift
- Floods on start...then runs fine
- Metro Power Loss
- 94 XFI fuel guage not working
- How do you feel about this? Ford 1.0 3 Cylinder with 8 Speed Transmission!
- 95-97 metro control arm bushings available
- Tires
- Keeping the Metro cool in the summer
- Idle solenoid
- Thinking of Replacing Crankshaft Seal
- no juice to fuel pump after in-place rebuild 96 metro
- 93 Metro keeps burning up rear wheel bearings
- High idle after fast shift.
- 1996 geo metro 3cyl
- any tips on ring job for 1.3 '96 metro?
- Troubleshooting lead/pull issue
- eating oil & running rough when warm???
- I need specs on a 99 1.3 cam broke it where the cam sensor goes!
- Reading airbag fault codes
- 99 Metro 1.3 lsi need a pic of camshaft
- 93 metro problems
- Egr
- 97' Metro 4300 RPM @ 65 MPH . Why ?
- water pump replacement
- blown tail light fuse?
- 95 metro 1liter 5spd. advace needed
- 2000 1.3L Metro no start after water pump replacement
- transmission seals ???
- yes another tranny question...lol help
- What's the Difference?
- anyone in wa, have 5sd to sell/trade
- big time oil leak crankshaft seal?
- Geo Metro 1995 Radiator Pissing Out Coolant
- '96 o2 sensor wiring
- 91 Geo Metro cold issues and more.
- Things to look for on 1991 Geo Metro
- heated 02 sensor on early metro
- Geo Metro w/ Mid-engine Taurus SHO swap
- Replacing Valve Stems
- need advice tranny
- 92 geo metro convertable center brake light needed
- Leaking front axle seals
- Gas tank fill tube leak
- Steering Wheel Removal
- 1991 Metro Rear Wheel Bearing Issue.
- Failed emissions test
- How to Replace Outer CV Boot
- Motor Mounts
- Metro Automatic Transmission Fixes
- Automatic to 5 speed
- Sudden Engine Turnoff
- My Metro is getting long in the tooth...
- Tranmissions
- Head Cylinder difference in between 98 and others with square timing belt tooth
- 91 geo metro clutch adjustment
- Metro AC/Heater Blower Switch....need one
- 95 metro you have to prime to start
- Startine Engine after 2+ years storage
- How do you open brake line clips?
- where is the turbine speed sensor
- Electrical trouble?
- 92 metro-to buy or not to buy
- Popping out of 5th (Dr Bill warning)
- Question for DOCTORBILL
- 1995 GEO Metro 1.0 5 speed Transmisson Question.
- new head gasket installed wont start?
- Head gasket? maybe
- Where would I put Oil Pressure Gauge tubing on my '95 3 cyl Metro engine ?
- Overheating Problem 95 Geo Metro
- '93 Metro Window Crank Handle - any aftermarket ones that fit ?
- 92 metro timing
- Inner Door Window Seal Clip - Fix ?
- Rocker Panel Rust
- hot start issues
- Acceleration Issues
- 2nd metro time
- Question about Power versus Fuel Input
- Are allfront wheel bearings the same?
- Geo starting problem
- $20 13" tires at Sears!
- Water pump tube o-ring question.
- What is the Black Sticky Stuff Holding the Door Watershield Plastic On ?
- Thanks and farewell
- Taking Off the Inside Door Latch Cover ???
- Metro Radiator Question of Compatability
- 97 Metro RH rear view mirror replacement
- 96 Geo Metro Engine
- '96 Won't start
- Acetone in gas?
- 96 tranny syncros
- Free A/C stuff, just pay shipping
- air/heater switch for geo
- Gearshift Shaft Seal leaking...
- Window will not roll up completely
- The "Leakin' Oil Rig"
- transmission problem
- 94 Metro Starts And Runs Rough At Startup
- 96 1.0 with P0420 Code
- Engine swappage
- Service manual
- Engine Replacement
- Engine Swap
- Engine Swap
- Engine Swap
- Problem With Breaking Pistons
- 94 XFI motor Oil question
- Mouse Milk Penetrant
- Upper Hose that Connects to Radiator
- Brush Guard
- Radiator Drain Plug
- '96 Geo Metro Clutch Slip
- 97 LSi SDN - Wiper/Washer Switch
- Help WHERE is the TCM? 1997 Geo Metro.
- 94 bearing spacer
- AC repair compressor change out
- 2000 IG ignition fuse blowing...Please help!!!
- THE PHOENIX and strange happenings
- 97' Metro Lsi leaking coolant
- 96 metro lsi automatic shifting trouble...
- Worn Struts - Symptoms ?
- Seat switcheroo?
- Crankshaft Journal sizes
- Inconsistent engine performance
- Metro check engine light
- Trick I learned to replace seals
- Thanks
- 99 chevy Metro Shop Manuales 1&2
- Auto-trans not shifting down @ stop
- Geo Metro Distributor O-Ring Seal - Size & Part Numbers
- Jumper - Timing Diagnostic Plug - "Duty Check Data Link"
- THE PHOENIX Lives AGAIN ! - It's Alive, It's Alive !
- Timing belts
- 95 Metro Stalled out at light
- 93 Geo Metro 3cyl
- 3rd Annual GeoPalooza July 24th-25th 2010
- need trans parts 96 1.3 manual trans
- 1996 geo 1.3L automatic
- service eng lite
- Engine Swap 91 metro into a 96
- 95 Metro adjusting front door- sag-
- I need a guide for lifter disassaembly and cleaning.
- Parts Deal! New Goodyear (Gatorback) Timing Belt $15.00 or less incl. ship...
- 99 Metro Code P1250 ?
- Gear Oil Leak
- 97 LSi 4 door Safety Locks - How to open the doors?
- The Phoenix is not Dead ?
- Ruff warm idle
- Speedometer or cable problem?
- DTC 301 code
- Water Leak? Carpet Wet!!
- Water Pump @106k
- The Phoenix is Dead !
- Exhaust before Muffler Hitting Part of Suspension? SPRINGS BAD?!
- hahah, argh, i did this to my self, clutch help
- Metro Auto Trans Mount FUBAR
- Just put the head on and it cranks like it doesn't have compression
- Frost on the Inside
- 1997 geo metro wont start!!!
- Need a repair manual? $10.00 on CD-ROM Best Price Anywhere! Complete!
- Shift Knob Removal
- Timing Belt Questions 1995 1.3 L Automatic
- Pulling Motor
- Forcing The Engine Down To Get Work Clearance
- Body Rust Caused By Leaking Water Pump?
- Odd behavior and trouble codes - Need a fresh perspective
- A Coolant Conumdrum
- 1999 Starting "petal" wear?
- 1995 Geo Metro engine mis
- 92 metro ruff idle, gas smell
- WANTED - '96 Metro Speedometer/Tachometer
- Timing Belt Wear -What are the Symptoms?
- Fix or Forget
- Hate to say it, but my '95 has got to go
- 97 metro - rough idle, 35 mpg
- 92 metro oil pan
- Unusual Noise
- 96 geo metro crankshaft pulley bolt keeps snapping
- 93 Metro Low Compression doesn't raise when oil put in cylinders
- Fuel Injector Replacement - Thanks for the Heads Up
- 96 geo metro hot soak no spark
- Can Master Cylinder Be Bad Without Leaking?
