97 Geo Metro Lsi fuel injector problem
dgiusa
12-16-2004, 12:50 AM
was Driving along and the car just died not sputter no nothing. Got all kinds of advise and finally found that I had a faulty fuel injector. Ordered a replacement and changed it out. Got the car to start couldn't keep it running rough idle. Vapor locked the engine. Purged vapor lock and had a nice little camp fire. lol Now the only way to keep car some what idling I had disconnect a vac hose. I now have Gas in my oil. I know this because I have a huge puddle of the wonderful mixture sitting under the car now. Any I deas, Short of taking to the desert and blowing it up. Any question please ask. I am running out of options and money on this one.
geozukigti
12-16-2004, 02:22 AM
If you're getting gas in the oil, sounds like perhaps you have further problems past the injector. Sounds like your piston rings are bad. Do a compression check. Also, since it's a 97, it has OBD-II. See if you can run a scan tool on it. See what's causing the bad idle.
