Where can i buy a prelude wiring harness?
lechnowsky-j
09-24-2003, 09:05 PM
i have everything i need for my h22 swap in my del sol except for the wiring harness. anyone know where i can buy one online? thanks
plum
09-24-2003, 10:25 PM
ebay has them mounting brackets and wiring harness if you need
H22man
09-24-2003, 10:29 PM
I had the same problem recently when I did my H22 swap for my Accord and you'd be lucky to find a harness in a junk yard anywhere - I called them all in Texas with no such luck but did find a performance shop in Austin that will modify your old harness and add/lengthen whatever wires you need.
Just call ProTech Performance at 512-834-8771 and speak with John. He quoted me $150 for my '91 obd1 to obd1 which only needed a few additions.
H22man
09-24-2003, 10:38 PM
Just checked ebay again:
All Categories0 items found for h22 wiring harness
lechnowsky-j
09-24-2003, 10:52 PM
if wires on my stock harness need to be longer or shorter, why cant i do it myself. might take a long time but it would work wouldnt it?
H22man
09-25-2003, 09:03 PM
2 key words IF ? and TIME ?
I'd gladly pay $100 to eliminate the IF ? and $50 for the TIME ?
Of course you could DIY, but you would still need to invest $65 for the Honda Service Manual to get all the wiring diagrams assuming you know how to use a voltage meter to get all the pinouts right.
I've been out of my baby for 2-weeks now and its starting to feel like 2-years. Plus there is no guarentee these JDM engines don't have other problems so plan on the unexpected.
Even after I got all the wiring right, now something else is wrong that even a pro who is looking at it is having trouble figuring out.
You know you've got problems when guys like these are having trouble with it now... http://www.pyrracing.com/
93accordEX
09-28-2003, 08:29 PM
h22man - for you its really really easy. you need to add 4 wires for vtec and knock sensor which depending on your ecu might not even be needed. I also had to extend wires for the iat and iac cause I put on a euro r manifold. However this is going from a f22 to an h22. I dont know if it would be as easy with a del sol.
