Our Community is 940,000 Strong. Join Us.
? on sohc zc
crx hf
09-11-2003, 08:45 PM
Well i have an HF with a sohc ZC(grey valvecover) and i was wondering how much horsepower they have?Also what do u think it will run in the 1/4 mile.My mods are:2.25 exhaust,intake,shortshifter and unfortunetly it has an HF :frown: TRANNY.
91EF3ZC
09-11-2003, 10:10 PM
It has just about 120 Hp, Mine ran a 16.4 with DC header, INJEN intake, APEXi exhaust. Si tranny.
gsf1200m
09-11-2003, 11:53 PM
I thought ZCs were faster than that, especially with those mods, i guess not though.
HONDABOND
09-12-2003, 12:04 AM
They are faster than that... Thats actualy unuasualy slow! Do you have a big ass stereo system or something dude?
Im aiming for mid 13's All motor, mid you my zc is built... But still, thats slow dude.
91civicDXdude
09-12-2003, 02:25 PM
sohc zc is about the same as d16a6.. 108hp.
dirty91crx
09-12-2003, 04:56 PM
jdm sohc zc.....has a different cam profile over the d16a6....im not to sure on the output but i think it was slightly more than the a6...dont quote me though.
Melt
09-12-2003, 07:05 PM
from what i have heard the sohc zc puts out 118 hp
mine isnt hitting that however because im running dual point fuel injection.
I will have 1/4 miles times and hp for you guys soon ... my friend just got a gtech.
sparq
09-12-2003, 07:10 PM
gtech? :lol2:
dirty91crx
09-12-2003, 07:36 PM
i beleive in gtech! damnit my 1/8th times were off my 1/10th finish and .2 60'......there pretty accurate if your calibration of the meter is dead one.
Melt
09-13-2003, 01:52 AM
ok before all you suckaz go knockin the gtech check out this thread AF member 'carrrnuttt' posted.
http://www.automotiveforums.com/vbulletin/showpost.php?p=1174974&postcount=2
"G-TECH/Pro is a very accurate machine, and the trap speed result that you get from the G-TECH/Pro is actually more accurate than the racetrack. Reason is that the racetrack averages your speed over a 60 feet stretch between two beams and G-TECH/Pro measures your speed at the exact 1/4 mile point."
anyways the guy i was talkin about that got one used it to check the hp on his 91 accord and it seemed pretty off so he hasnt figured out the calibration yet, (just got it today) but hes supposed to go try doin the 1/4 tonight so ill keep you guys posted.
Melt
09-13-2003, 01:57 AM
oh and currently af members can get one for $52 if anyone is interested
http://www.saxforte.com/data/gtechpro/gtech_home/gtech_home.html
91civicDXdude
09-13-2003, 02:04 AM
until someone comes up with a d16a6 vs SOHC ZC ..stock vs stock ... dyno graph, i will belive the sohc zc is a fancy stamped d16a6. The engine came out in trim levels less than Si, so that means its the USDM equilvant of a DX engine in japan.
Melt
09-13-2003, 02:39 AM
d15bitch seems to know more about the differences between the sohc zc and the d16a6 than anyone else, but apparently the internals are the same ones used in the dohc zc (dunno if this is good or bad :screwy: ) and the cam is slightly more agressive.
D15Bitch
09-13-2003, 06:57 AM
A lot of people like to compare the D16A6 with the ZC SOHC, purely because of similar appearance. But on that note, the D15 and D16 engines all look alike, but are they the same...?
First off, the ZC is JDM, the D16A6 is not. We all know the Japanese like to give their engines more oomph, have better engines...
Second, the pistons and conrods in the ZC SOHC are the same ones used in the DOHC ZC. Despite what some people may believe, the rods and pistons are stronger than that of a D16A6. Better for modding...
Third of all, the cam in the SOHC ZC and the slightly higher compression of 9.3:1 (compared to 9.1:1 of the D16A6), makes a stock SOHC ZC push out 120HP. 5HP less than the sohc vtec engines...
Now, I have had the privilege to drive two separate cars, one stock with a Euro D16A7 (D16A6 without a cat), and one stock with a SOHC ZC install. Only difference between the cars was the mill itself...
I found the ZC to be smoother revving, faster revving and an undeniable difference in power. Especially from 3000rpm where the ZC cam really gets to scream up to redline. I found it kicked me in the back very nicely, better than the D16. That was why I decided to source one of my own to drop into my 4G4D.
I thoroughly enjoy this motor, much better than my previous D15.
91civicDXdude
09-13-2003, 08:00 AM
Im sorry, but you're wrong here, my friend. The DOHC ZC has dometop pistons similar to those of the d16a1 1g teg engine. the SOHC ZC has dish pistons, *SURPRISE* like that of the d16a6. I know this becuase i've seen both with the head off.
It wouldn't surprise me if the SOHC ZC had a slightly better cam and .1 more compression as its a JDM engine, but 120hp, i doubt that.
91EF3ZC
09-13-2003, 09:25 AM
YO, asshole, here is a chart from a Hyper Rev book from Japan.
The ZC came in the Si noting less. I am also working on getting you proof of the HP numbers.
91EF3ZC
09-13-2003, 09:31 AM
Maybe it was a 14.6, It was so long ago. I never ran it again. I really don't like drag racing at all. I went just for the hell of it cause all my friends went together. Anyway, it was probably 14.6. I also ran with my 17's on, and I have a system, box w/2 10's 2-amps, nothing crazy.
91civicDXdude
09-13-2003, 09:39 AM
Asshole? why do you have to get all rude?
and the Si has the DOHC ZC.
oh, and 16.4 sounds about right. :loser:
D15Bitch
09-13-2003, 10:12 AM
I've done this before, but will do so again. Let me point your direction to this link. It is Honda Japan's archives for past models of civics.
http://www.honda.co.jp/HOT/ModelData/civic/index.html
Go to the line-up for 4th gen sedans, have a look at the RTi and RTi 4WD. You are not dreaming. Honda japan puts the performance of the sohc ZC in those sedans at 120HP.
If you need to, translate the pages with this:
http://babelfish.altavista.com/
And the information about ZC pistons and rods also came from other Jap sites that I translated. I will see if I can find them again.
Maybe, just maybe, it is also possible that they did SOHC ZC with dometop pistons, and with dishtop pistons... I say this because I have also read SOHC ZC's to put out 115HP.
But if Honda Japan says their 4G4D's with SOHC ZC's put out 120 HP, who am I to argue with them...?
optimuscivic
09-13-2003, 11:47 AM
hey whats the wheel hp of the sohc zc?
Melt
09-13-2003, 12:31 PM
haha ... york2600 drove my car one time and thought that thing was like mini vtec :lol: :sunglasse
crx hf
09-13-2003, 02:18 PM
Well i have a SOHC ZC in my HF with intake,shortshifter,2.25 exhaust and HF Tranny :frown: and i beat my friends 91 civic si with just an intake.even though my tranny sucks my engine is still very strong.Just to show how much my tranny sucks im doing about 90 in 2nd gear.
91EF3ZC
09-13-2003, 04:28 PM
Why do I have to get all rude?
Your the one shooting off at the mouth when you don't have any facts or documentation to back up your stupid mouth. I would suggest that you shut the fuck up and not speak untill you actually know something.
HOW ABOUT THAT? YOU LIKE THAT? :nono:
Melt
09-13-2003, 04:54 PM
i highly doubt a sohc zc ran a 14.6 without being somewhat built ... maybe 15's or so ... i know you have mpfi and a lighter car.
I will be running my car hopefully tommorow if the guy with the gtech comes to the meet 707imports is havin on treasure island.
91civicDXdude
09-14-2003, 11:23 AM
waaaah. how about you shut your 16.4 running mouth and stop shooting off shit you read off some website. take some engines apart and find out your facts. If the SOHC ZC is any different than the USDM D16A6, the *ONLY* difference would be in the cam, and a d16a6 would have to have a VERY radical cam to gain almost 15hp in stock form.
Oh, and also, in japan, almost every d series engine is banded with a "ZC" stamp. their D16Z6 is a "ZC" as well as their D16A8/0 (DOHC ZC), D16A6 (SOHC ZC). Its impossible to tell what ZC they're talking about when they say ZC.
Again, is it necessary to resort to using cuss words. cant you grow up a little and stop getting mad when you are wrong :lol2: :lol2: :lol2:
D15Bitch
09-14-2003, 11:48 AM
I don't like you.
Not because I think you are a rude person, but purely because you jump to conclusions without proper investigation. In my opinion, people like that are dangerous. Look at G.W. Bush for example.
In your case, I asked you to read the link to Japan's archives. I asked you to read it properly. even gave you a translation link. If you had done that, You would have seen that they list "which" ZC is used in each car by stating wether it is DOHC, SOHC, FI or Carb'd. They "concealed" that information in the specsheets for each model. Yes, the Japanese state ZC. But if you bothered to look, you would see they ALSO state whether SOHC, DOHC, FI or CARB.
Also, on what you said about SOHC ZC having a "Very Radical Cam" (your own words), you once again missed the point, cleverly concealed by the japanese in their online specsheets, that the compression is higher. So you cannot blame the cam alone for the SOHC ZC being different from the D16A6. It is also common knowledge that the japanese use different TB on their engines, which could also account for their SOHC ZC's pushing out 120HP.
Almost finally, I have to reiterate that a SOHC ZC is not a D16A6. It is a ZC. That what it says on the block... ZC.
Not D16A6.
Even a SOHC ZC head flows better than a D16A6 head, which could, *surprise*, also account for more HP than a D16. And this knowledge I got from someone who had *also* opened up a ZC SOHC.
Finally, about me not liking you. Don't sweat it, you never asked me to like you, and it will make no difference to your universe wether I am right or wrong... The only thing that will make a difference to your universe is your own attitude to new information, even if it is contrary to what you know. That is how people grow...
HONDABOND
09-14-2003, 07:10 PM
Sohc-ZC 118Hp
Sohc-ZC-Vtec 128Hp
There are two versions, do not test my zc knowledge. :nono:
Melt
09-14-2003, 07:58 PM
theres a sohc vtec zc? I remember back when i was a noob on this board i thought there was one but everyone told me there wasnt.
dirty91crx
09-14-2003, 09:02 PM
sohc zc vtec.....3 stage vtec system. rated at 128hp or 130ps. rods on the d15b vtec ar slightly larger than the usdm d15's yet smaller then the a6. sohc zc....same as the a6 with higher compression and a hotter cam. Just to show how much my tranny sucks im doing about 90 in 2nd gear. can we say hf tranny? get rid of that thing quick....find an si or build an si/zc hybrid. Despite what some people may believe, the rods and pistons are stronger than that of a D16A6. Better for modding... http://www.codyscafe.com/~mrbone/pics/DeadD15/P7300005.JPG rod on the left is jdm d15b vtec rod on right is d15b2. Oh, and also, in japan, almost every d series engine is banded with a "ZC" stamp. their D16Z6 is a "ZC" as well as their D16A8/0 (DOHC ZC), D16A6 (SOHC ZC). isnt the d16a8 the euro version? now on the argument that dohc and sohc zc pistons are the same....we are about to tear into a d15b vtec and will have piston specs up soon to end that part of the debate.
91EF3ZC
09-15-2003, 06:39 AM
What are you talking about? This was all I said about my own personal 1.6 ZC "It has just about 120 Hp, Mine ran a 16.4 with DC header, INJEN intake, APEXi exhaust. Si tranny" I never said anything about a cam or internals. And I really don't give a shit anyway. And what was I wrong about? Oh and by the way, how old are you?
91civicDXdude
09-15-2003, 12:19 PM
your "120hp" I/H/E SOHC ZC = 16.4
my 125hp I/H/E D16Z6 = 15.5
5hp makes a lot of difference :uhoh:
Melt
09-15-2003, 12:38 PM
theres also the vtec factor.
and the fact that you may be a better driver than him ... or that he was running 17's at the time.
My friend did not come to the meet sunday so i was unable to run my car and get times. I hope to do this on sep 28, because he is coming to that meet, along with a few other fellow af members.
91EF3ZC
09-15-2003, 04:30 PM
WHO CARES!!?? I DON'T. I have a B16a in a 92 Si as well, I really don't care about the HP, 1/4 mile, all that BS. and my B16a is nothing special either, so what?
I had the 1.6 SOHC VTEC in my 92. it was okay. Big deal.
D15Bitch
09-16-2003, 12:45 AM
COOOOOLLL!!!! :grinyes: :grinyes: :grinyes:
So you wanna swap me your B16 for my D15 then if you don't care...????
:lol2: :lol2: :lol2: :sunglasse :sunglasse :lol2: :lol2: :lol2:
91EF3ZC
09-16-2003, 06:15 AM
Allright, lets do it. :grinyes: LOL
Melt
09-16-2003, 05:39 PM
i think 91ef3zc's entire point was he is happy with what hes got, and isnt really into hardcore modding on his cars, nor is he real worried about if it can "hang" with other peoples cars.
Riddick
09-18-2003, 01:52 AM
I also have a SOHC ZC question... Are SOHC ZC parts interchangeable with the D16A6, like camshaft, piston, etc?
91EF3ZC
09-18-2003, 01:57 PM
Well put, thank you Melt, That is exactly how I feel. I am simply a Honda and JDM enthusiest(sp). I like it for what it is. That's it.
Thanks again,
Mike
