Honda
Civic | CRX
> '88 - '91 Civic | CRX | Wagon | Shuttlee
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
I need help with my automatic seatbelts on my 91 EF sedan
Air Fuel Ratio(AFR) incorrect leads to unstable idle speed even misfire!!
Nick's EF Sedan Build (her name is Suki from The Last Airbender))
Bringing it back to life!
EF Cup Holders - Sedan Hatch
First post of 2019
I'm BACK
Need help with wiring I think? On 89 crx
Aaaannnd, I'm back! (And some background)
b18 swap malfunction
CODE 41 Primary o2 sensor heater
SERIOUSLY OT: Calling all chicks! IT'S PART 6!!
Refreshed 2014 Honda Civic Coupe to bow at SEMA
1990 Civic DX 1500 Will not start.
distributor question
fixing code 20
video of my weird idle
Hydro or cable transmission
Looking to do engine swap need some advice
Question?!?!
1987->1991 parts
Starting Problems with 90' CRX SI
91 Civic Ignition Question
Ok yet a different overheating related question
89 Honda CRX Cluster -> Will it direct swap to 89 Honda DX Hatchback
New Valve Stem Seal Puller for Hondas
erratic idle jumps up and down in neutral
HaPPy BiRTHDaY.....
Need diagram or photo for 91 civic throttlebody
91 civic 1.5 dpfi redlining when i start the car!!
Happy Birthday Amy!
Cool AF news From Igor...
Happy Birthday Kris....
HaPPy BiRTHDaY MeLLoWBoY....
Honda civic 1990 wagon ECM
HaPPy BiRTHDaY BuLLSHiFTeR....
Trouble Starting
"EF You".....Happy Birthday!!
BS Honda Shop Meet (Idaho) 1/28/2012
1990 Civic sedan - shift lock sticks when cold
Happy Birthday ToNY...
Happy BIRTHDAY....
AF News Video 2
Dual Happy Birthday action.....
Another BiRTHDaY!!
Screwed up antenna
Happy Birthday.....
HaPPy BiRthDaY.....
Where do I find parts for ZC engine
ATTN: Bounty Hunters, bring me these heads....
engine
hey af new 4th Gen enthusiast
GooD MoRNiNG CiViC LanD!!!
Just bought a 91 4dr Honda Civic. Not sure what it has in it...D15b2?
CRX wont start........
90civicrider Returns... My ongoing lsvtec build.
EK question on CTR conversion. (Please don't kill me?)
1990 Civic LX - valve clatter noise getting worse
good grounding
code 8 and 20
Team TLD...where did my Lonely Drivers go??
got a new 88 hatch (lots of pics)
Jahrul Intagra for sale, fast and furious
Wire Tuck Anyone?
Happy Birthday to....
CRX vs Del Sol vs...
ALeRT: Scaveger Hunt Contest....
I DeCLaRe War!!!
Wagons...come play!
welcome back TheSilentChamber....
shift rod laying on ground
Update on 90 civic fuel issue
Mugen Releases More Details of CR-Z
bought a 91 civic base hatch 1.5 4-speed, in need of help on ignition troubles
JDM Engines
Fuel issue could use some thoughts
1990 Civic LX - valve clatter when cold?
How to remove Throttle Positioning Sensor???
How much power can i handle!
88 Civic Idle Problem
what are you running?
What is an '88 CRX worth ?
Timing marks are gone from my crank pulley!
how could i make my 91 crx hf faster??
timing belt broke at 55 mph
who's going to answer the call???
SERIOUSLY OT: Keep whoring alive, it's THREAD #5!!!
bad ground?
Engine gauge say overheating, but engine barely warm.
91 civic rebirth
new to this need help
no spark
exhaust systems
Battery drain on horn/brake light circuit
Just snagged a 1988 DX Sedan for $250
Oil on plug 1
rear sway bar brackets
Transmission Problem?
Help!!!
Started 90 4Dr EX rebuild this week!
4 wire sensor w/ecu jumper HELP
dashbord swap info/opinions
89 si window problem
Help!!!!! civic wont start help asap plz!!!
91 hatch si fuel pump cover and hard line not connected? no fuel tank pressure? is that bad
injector swap
No brakes
91 si blox lower control arms...NO place to bolt rear sway bar!!!
91 si have spark and fuel just no start????
Strange things happening - Need some ideas
91 Civic Hatchback/Vacuum Hose Diagram and won't smog
chronic leaking from valve cover gasket
Fuel pressure check
Main Relay Buzz & No Start/No Fuel Pump Power
91 Civic Help
91 4DR Civic HELP!!!!!
Car died on the highway! Please help me!
someone help!! crx b16
d16z6
1991 honda crx si check engine light
d series oil pans
Sputter
b16a ran like crap in hf
DX/SI Trans swap
motor swap
Gas Gauge Hi Beam Indicator - Weird
Rear disc conversion Q
4-Hole early CRX wheels?
Rear Left Running light not working
91 Civic Nothing when you hit the ignition
b16 smokes and runs like crap
sparadic vtec
sparadic vtec
sparadic vtec
Integra to Civic suspension fitment
CRX turns over but wont start
88 crx hf engine timing
'91 CRX Driving Me Nuts!
zc swap 1.5 to 1.6
90 hatch swap
tryen to fix somebod els mess
90 civic hb dx battery light on while runnin
Upgrading Injectors
Really need help Major Issues!!
Car died and oil in spark plug wire tube
89 hatch w/d16y7 wont rev over 4000rpms
does a civic have the fuel/igniton relay??
88 civic sedan motor mounts
Honda Civic problem :(
Code 43 Fuel Supply System Help!
Need D15b2 answers buying motor
91 Civic runs rough after timing belt fix
battery drain
can u put a zc sohc non-vtec head (complete) on a stock 89 engine? and good idea?
89CivicDX2door-Coolant overflow problem
roaring noise
Just bought another CRX, having issues...
itr tranny on b16a
91 Civic HB smoking.
Walker mufflers
Halfshafts
91 civic 1.5 eng tensioner bearing replacement
Totally stumped with my ecu problem
wiring harness
hey guys, long time no see!
Rear engine mount 91 civic
another idle issue...sorry
bunch of problems
CRX HF sputters when warm
90 Civic Sedan Rear Wheel Bearing Replacement???
Ball Joint Torque????
Need to replace upper control arms. How to????
1991 honda accord
reusing a head gasket
Energy Suspension or Prothane bushings??
Rust Repair
curious starting issue
**Best Place to Find**???
civic si hatch 89. will a non power steering rack fit instead ov powersteering one
I dont even know
Good Price for a d16a6 installed?
Shocks + Springs
b20 engine questions
89 civic started a light fire!!
mpfi swap
1989 Civic Starting/running problem
front rear crossmember
Hydro trans mounts
1985 crx hf problem
Eird oil leak
maybe axle...i dont know
That can ruin your day....
ITR tranny on a b16a sir 1
1.5/1.6 part compatability
Steeri9ng shimmy
Which size silencer?
b16a slight backfiring and pops after header install
cant fight it
Quarter panel repair
Doors squeaking/grinding??
CRX DX Rear Bushing replacement
89 crx wont start
Just replaced both axles, and they're clicking/rubbing
zc sohc
error codes!
EF Honda Meet in PA!! July 12th!!
build question
No Start after car has been running and shut off
Driving, and the engine dies
A/c help
Alternator interchangeability
cornerlight hell
fuel pump cutting
honda civic 1989 (SI) hatchback..b16a conversion.. HELP
car wont start and i need to sell it
mpfi
What rims are these?
91 civic dx sapw with b18c1
HELP me PLEz b18c1 info problems
Got bored and lowered the wagon today!! (pics)
timing mark mystery
Sparks out exaust, Won't rev over 3,500!
91 Civic idle
obd1 injectors
Valve Cover Gasket Issues
1.6 valve v-tak W/ slowness switch
civic/crx tail light swap?
fender removal
CRX Lowered the right way
CRX Transmission oil....
Battling the Burning oil..
vibration/steering wheel off ceter
help ecu and alternator fuses keep blowing
What the heck is wrong with my civic?
89 civic hatchback fuel problems???
1988 CRX DX oil leak, how do you fix it?
91 lx gauges don't work
Car is making a Grinding/whistling noise while driving
Timing Belt Question, 2
fuel pump location
91 LX rear windows are about to make me mad......
b-series noob question
need some code help and a main relay ?
h23 swap 4th gen civic?
Pan Seat Swap
88 civic fan question
got pic's of my engine bay,What is it?
How do I up load pics????
intermediate shaft? Where?
