View Full Version : 3 Series
- Good service manual for 325i
- Engine dies on deceleration
- BMW 325is (1995)
- purchasing a 2001 330i sport
- 328is *salvage*
- twinturbo on e30. 3,6 l
- New to BMW world
- new user, 1994 BMW advice
- Electrical problems
- 2 weird questions
- Dumb question.. but let's proceed ... regarding headlight bulbs
- Shifter problem
- 1989 325i coolant and headgasket problems
- Cold air intake problems
- Putting rear lamp holder back (Silly Question)
- Wheels With Tires only for 150
- twinturbo
- E30 325E TO E30 M3 ENGINE&TRANNY SWAP ANY HELP?
- 94 bmw 325 problems :( abs light and door makes noise when key is out
- 325e cental locking wiring diagram
- 1998 318i Engine Code
- 1984 318i charging problem
- BMW 320D 2001 Rear indicator problem
- Instrument Cluster
- engine replacement in 325 bmw
- Back to BMW
- airbags in the car!
- BMW 318is Performance Potential?
- rough idle
- Is it really the brake light switch?
- Rear end drone
- Repair Seat release.
- E46 - Eagle Warranty Corp. Any Good?
- Just failed Cali smog check in my 88 325iS
- style 162 rims without sports package
- She won't start
- Oil light/mixing engine oils
- Auto headlights won't shut off - ideas?
- noise when engine is cool.
- 1985 325 Engine Manualtrans 1987 325 Engine Automa
- oil service and inspection lights
- central locking doesn't unlock
- dashboard removal help
- 1985 318i engine cuts out - need help
- Wiring Diagram or HELP
- new car smell
- 318 brake light trouble at night only
- Less power? buy heat shield
- What should i do next to increase horsepower of e46
- E36 Climate Control cuts when electric radiator fan starts
- gas leak oh my with these prices 325i 1992
- Brake chatter
- Air bag light problems. Need help fast
- help with 3 series starting, HELP!!!
- Programming key to select specific seat memory
- 3 Beeps
- Air Conditoner problems in my E46...
- A/C compressor -- auto off in cold?
- thanks milpas421 for the heat shield
- Heat shield air intake???
- cam position sensor problem
- 94 Bmw?
- 325i (E36) electrical problems
- 1994 BMW 325i or 1999 Chrysler 300M what should I get??
- looking
- Motor surges @ an idle
- 1993 318I sun roof Problem. Need Help.
- Help With 1995 325i Audio
- alternator trouble
- Blown Transmission on a 95 318 - I don't believe this is common
- multiple wiring issues???
- Frozen Ignition Barrel
- Convertible Canvas/Gasket Separation Problem
- BMW 330 speedometer plug into trany
- 1997 M3 Complete Engine for sale
- Locked Key inside my 2000 323 Ci
- Bmw 318is
- Transmission control module
- 1987 316I BMW ignition timing settings or data spec
- 325i vs 325is
- Help with 1992 325i OVERHEATING!!!
- 93' 318i electrical problem
- Could someone explain to me, where the E30 or any other E? come from
- Inspection
- E36 A/C Fan Problem
- Thermostat Question
- problems with stock radio in my 1997 328i
- Converting E30 to a Turbo Car
- '84 E30 325e - A/C
- High mileage???
- Brake light Circuit failure indicator.
- Climate control failure
- blower motor resistor location on a 90 325i ?
- check lights
- 04 325ci gas mileage
- e36 outer ball joint question
- Hilf mich, bitte! Mein Auto ist kaput
- Which is the High pressure and low pressure line for A/C?
- PLease help...325i...key inserted,but it won't start...
- engine swap 3 series help
- paint spots (?)
- very rich 86 325
- 1999 323i Service 1 Necessary?
- Good deal?
- 1986 fuel system leak
- E30 Hot start problem
- Alarm Arm/Disarm
- hole in underside
- Will this fit....
- E36 vs E36
- WTB 1999-2003 E46 Coupe with body damage and manual transmission
- cigarette burn
- on board computer
- Radio wiring diagram for 1996 328i
- 1996 325i air bag light
- 1986 325e
- Comfort Relay! 89 325i
- Clear Bra (Roadblock by Autobahnd)
- Sheepskin Seat Covers -- 1987 BMW 325es
- Smokers Package?
- factory Alarm System
- mirrors
- climate control issues problems
- climate control
- Thinking about buying a 91 318i
- Intermittent fan on A/C-defroster 318i
- Wiring Diagram
- NEW 3-series, what do you think?
- AC compressor
- buying a 325i
- Display light on Radio
- new clutch...now won't start
- Need some hard facts here regarding M50B25 boring/stroking.
- swap? or rebuild?
- 94 318 overheats in traffic (aux fan not working)
- is the 3 series any good?
- Just bought a 1985 325 few minor repairs needed
- re build kit? 82
- BMW 316i
- BMW tune direction?
- Little help: E?
- Obd
- 98 318i Towability
- Fuses description E36
- a/c blows warm
- jammed wheel lock
- Looking at '93 4 Dr 318i
- 1994 325i??
- alpine cd changer
- 00 323i clock setting problem
- 1995 BMW 325i
- Winter tires - recommendations?
- Steering Noise
- 328i 1997 Automatic Top Stuck, Most Uncool!
- BMW 318IC LED problems
- 1992 325i -good idea or no?
- Buying a 92-98 325
- Upgrading my 2000 323i stereo experience
- intake/exhaust
- replacement mirrors
- 1985 bmw 325 5 spd trans
- 2005 Sunfire vibration at 75MPH
- Breaking in period?
- owners of 3 series build 1999 thru May 2000
- Automatic stalls!!
- Buying a 325i
- e30 headers
- Won't start????? Help!!!!!!
- 1994 318is Transmission Control Modul
- #1 #3 #5 injector problem
- fooked bmw
- window
- e34 exaust...
- oil change 1997 328i
- key tumbler??
- 2002 bmw 3-series winter driving and issues
- Researching body styles - 3 series
- Help please, ignition light comes on when braking?
- Cleaning Painted Plastic
- bmw 1995 320
- Speedo/Cluster Lighting
- Plz HELP!! A/C electrical problem
- E30 Idle Problems
- 1996 BMW 328I questions
- Oil pan Replacement
- my 1986 325 radio needs codes
- Finding used parts
- 87 325 window, power to crank
- Please help!!!!
- 1991 318is fuse panel diagram
- Exhaust
- 325is cold air intake
- 93 325IS Fuel pump
- gas mileage
- Brake-light Malfunction
- 1995 Color combinations
- 325I timing belt broke: need advice
- Problem with 3rd gear
- 91 318is Timing Chain Kit
- Wow i really need help with my '91 318is
- Hi
- 1987 325i odometer just quit working
- 19' MVR Magnums for sale!
- fuel pump relay 1997 328iC convertible, electrical short problem
- 92 e36 20ise wipers
- FAQ Links to Aftermarket Websites
- 1985ish 318
- Brake Lights Out, Cruise Control Won't Release
- Wandering Idle
- BMW break-in device going around??
- 1999 323i Gear Shift Kinda Tight/Rigid from P to R
- 1999 323i Weird Noise / Shaking Steering Wheel
- 1999 323i Head Light Replacement
- Am I nuts to buy $58 control arms on ebay?
- 323 Wont Jump Start
- 325i clutch
- "INSPECTION" light on dash came on?
- 325i Vs 525i
- Limited Slip question....
- been kinda dead here. . .
- buying a car
- fuel odor in car
- I Found My Car!!!!!!!!!!!
- buying a 325i with miles
- ball joints
- Harman Kardon
- 325i lsd
- 325is Questions. Thinking of Buying!
- bimmer or beemer
- Angel eyes
- I post my Bmw Drawing !
- i need to know what to do
- auto to 5 spd
- Trunk Not Level??
- What can I expect from my 318ti
- A and M system
- Question on model year
- Rear Wheel bearing hub assembly
- 92 325i rear wheel hub assembly install
- Valve Cover Replacement Nightmare
- new BMW driver
- How Can I Burnout?????
- How Do I Remove 325is Emblem??????
- Help. Please evaluate this car description.
- 3 Series roof bars
- P0735 Error Code, Gear 5 incorrect shift ratio
- 1990 325i wont start/ has fire but no fuel pressur
- wanna put a turbo on my 1988 325i
- Which 3 series model
- Instrument Panel
