View Full Version : Nonspecific
- 2002 Astro van
- CV axle problems ??
- Pretty Cool Metro!
- Cruise Control / Electrical Smell
- reprograming a keyless remote 2002 GMC Sonoma
- need an opinion
- Child Saftey Problems
- Oil Consumption: Answer this and you’ll be the man!
- 93 prizm a/t no first gear
- Dripping dash
- Parts Needed
- Geo Metro Mini Truck Conversion
- Unable to upload photos into my gallery
- 90 metro speedometer/milage
- 4age and 4afe exhaust manifold
- How do I read the VIN number?
- tight belt
- Electrical Problem...Please Help!!!
- 96 geo need help
- Suzuki Tracker?
- geo prizm failure to start
- help
- 95 prizm guzzling gas and dies when decelerating or stopped
- 94 Prism turns over but no start
- 94 Prism white side marker light replacement
- 95 Prizm Clutch Pedal Feels "Sticky"
- 98 metro wont start no dash lights
- 93 geo prizm engine swap?
- 93-94 prizm radio unlock code
- 92 geo ignition
- corolla cluster swap
- 95 geo prizm hesitates
- 93 Prizm engine blew up
- 91 geo prizm swap
- Anyone know where i can find a geo forsale
- 96 Prizm problems.
- 93 geo prizm front end noise
- Can a CV Shaft cause this??? (please read)
- Prizm LSI seats to a Base model
- cd player installation
- what is the major problems on geo prizm?
- I need help with my wiper motor
- o2 sensor wiring for a 96
- 94 Prizm, new front axels but abs lights at 65mph
- Electrical Mishap 91 Metro
- rims
- 94 prizm, wont start
- removal of stereo from 97 prizm?
- Help with seat removal on my 91 Prizm
- low compression pistons
- 94 prizm motor splash pan#@%#@
- Transmision trobles
- civic front bumper body kit on a prizm?
- worn differential =
- '91 Prizm lights go on by themselves
- aamco = prizm a/t
- 1991 fuel system problems
- 94 prizm differential question=
- 94 prizm,slow shifting a/t.
- fuel filter replacement for geo prizm
- motor swap
- '94 GEO Prizm Belt tensioner
- a/t don,t upshift easily.
- 3 to 4 spd. a/t conversion=
- normal a/t actions=
- transmission swap=
- 94 prizm,rack and pinion.
- 94 Prizm, Fuel Problem
- 94 prizm, 165,000 miles =
- 94 prizm a/t question=
- strut mount job$$$$$$$$$$
- 1999 Chev Prizm headlight adjustment
- updated my 92 geo
- headlights
- 94 Geo Prizm, Nox emissions out of limit
- please help me
- on my 1994 geo prism, cant i install a stereo w/o buying an adapter?
- Towing a trailer with a Prism
- 93 Geo Prizm Engine failure
- geo prizm 92 heater
- heater core replacement
- trunk latch(key wont open trunk)
- Brake and Battery Lights On
- '95 Geo Prizm Idles But Won't Take Gas
- What Can I do?
- Rough idle
- 90 Geo Prizm (shifting Problems)
- geo prizm 1997 starter replacement
- 1997 Geo Prizm
- turbo making check engine light come on
- 91 Prizm door lock stuck
- GEO PRIZM O'2 sensor
- car randomly won't start...HELP!
- body kit to low to the ground
- 93 geo prism parts needed
- Help- cooling fan
- 97 Geo Prizm
- transmission
- sneak peak under my hood an exaust
- prizm clutch problems
- Charging dash light will not come on.
- carolla bumber on prizm
- Geo Prizm AC clutch Fix
- '94 Prizm leaks water when A/C is on
- What engine could i put in my 94 geo Prizm
- starter
- 93 celica gt front end work on a 92 prizm?
- tach on 96 geo prizm
- 99 Geo Prizm LSI
- Alternator Problems? Car is DEAD...
- Cost Of An Exhuast
- wanna see how good my prism runs
- Geo Prizm '97
- 93 Prism help!!
- starting probs in the morning
- ?? crazy Prism won't start
- 93 prism engine runs rough
- Clunking form the front end.... Help!!!
- Prizm Projector/Euro Headlights
- Replacing the Stock Bumper
- 95 geo timing 1.6 liter
- Help !! 94 Geo prizm - stalling
- Harness +Hardwire +12 volt
- remember the geo with the turbo stickin out the hood(its aliiiiiiive an.....
- '90 GEO TRACKER....No Start
- My 94 Geo Prizm wont start, help!
- who says you cant put a 93-97 body kit on a 92 geo prism (pics
- Help installing a Tach
- Air Intake Temp Sensor
- turbo geo
- 95 Prizm Dash Noise
- blew my geo engine up racing(new engine advice
- prizm can't pull hills.
- prizm timing belt replacement
- 94 Prizm poor gas milage Sub 200miles per tank
- Compatable engines for 95 prism
- 94 prizm m/t problems..... please read
- 1997 Geo Prizm driver door lock stuck
- Prizm Help
- 96 Prizm Inside Dash problems
- Tweaks?
- I am looking for used GEO Prism passenger side front fender(black) and head light.
- I ordered a kit for my 92 prism from ground effects
- Replacing rear speakers
- 96 Geo Prizm Check Engine Light
- Engine Mods
- 94 prizm a/t, 144k=
- Slow Geo Prizm 1996
- 95 Prizm leaky valve cover
- 90 Geo Prism problems
- 95 prizm not firing
- help trying to install new cd player
- prizm dilemma
- mirror
- Non unlocking door locks
- Hey all Looking fro 96 Prizm handles!!!
- Gauge Cluster with a Tach
- We need a Prizm forum
- Installation Of Alternator Belt
- 93 prizm not starting..need help!
- door handles and brakes 92' Prizm
- History of Geo
- What will this fit in
- Geo Prizm 1994 ECM and Module
- Stock Audio sys in 94 prism
- Diff between 94 Prism LSI and 94 Prism
- geo prizm with or with out motor wanted
- 95 Geo Prizm Won't Start
- Body Kits
- 91 prism battery was installed backwards
- 91 STORM NEED QTR GLASS & Rr. BEARING/HUB PLZ!!!!!
- wanted
- Tracker bogs down
- fuel filter location on 1991 geo prizm
- 1990 geo prizm heater problems
- 95 prizm window replace, help please
- Prizm performance mods
- would a prizm be a good first car
- How do I re-install rear seat in '94 prism
- GEO makes thumpy sound on turn
- Shift-Lock Override
- Calling All 1.0 3 cylinder owners
- 1995 Geo Prizm Smog Test
- 95 tracker wont start
- 1991 Geo Prizm High Beam Not Working
- Geo prizm 1994 Radio Err9
- Geo Prizm Gauges
- 1994 Prizm Head Unit Swap
- will this transmission fit?
- noise in front when turning right on take off!!
- Need some help (Finding Prizm parts/mods)
- mystery...please help!
- '95 Prism Oxygen Sensor - threads
- 94 Tracker HELP!!!!!!
- '91 Prizm won't turn over
- Tracker exhaust
- Anyone want prizm mods.
- radio security code--need to disc. batt--help please!
- Geo Prizm Starter = can see gap after installation
- oil leak 98 tracker
- Turbo for 95 prizm
- 94 tracker stereo/electrical
- 1990 Geo Prizm LSI - Starter Removal Help?
- Help - Starter Stays Engaged (1990 GEO)
- Axel problem-STUCK in another state-HELP
- 4WD power distribution
- Tracker Top help
- HELP please trying to install a car stereo
- Tinting windows on Tracker
- 97 Tracker 4wd
- 95 Geo Tracker front-end groaning/rubbing noise!
- Fuse Keeps Blowing
- !!!Can't decide on which sleeper...!!!
- prism died while driving
- 92 Geo Prizm, Custom parts?
- Tracker Windshield
- 95 Geo Tracker Emissions
- 96 Prism...multiple issues
- transmission
- Tracker bog's
- Tracker Not Ideling and NO Power
- Geo tracker help
- 96 tracker
- 91 tracker timing problem
- 1992 Geo Prizm Parts Car
- Service Engine Light - OBD
- New Battery...No Radio...TOP-SECRET Code?
- Wipers dont work???
- Exhaust size
- 96 Geo Tracker Window
- 1997 Geo Prizm Stereo Unlock Codes
- 1999 prism code P0441 purge flow rate
- electric superchargers
- My girl's front end needs fondling!
- 1992 Tracker Rear Differential Problems
- 1992 tracker
- Prism Mods???
- 95 Trcker Blinkers on the Blink
- 90 Tracker-Bizarre Problem Please help Soon!!!
- Blue Tracker Soft Top
- 91 Tracker engine problem
- Throttle or Oxygen sensor problem?
- 95 Tracker engine noise on acceleration
- 94 Tracker Tuneup (1.6L I-4 MPI)
- Motor Oil on top of trany
- Need a safe place to store items.
- advice plz
- speedometer all over the place
- mr2 swap for 93-97 prizm
- 95 Prism gauge cluster?
