View Full Version : Golf
Pages : 1 [2] 3 4 5
  1. how do i open the fuel door on my golf??
  2. VW Golf, VR6, '98 - No computer communication
  3. VW Golf VR6, '98 - 5th gear problem
  4. VW Golf VR6, '98 - Air Bag Light Reset
  5. Biodiesel Conversion
  6. battery problem
  7. 2001 VW Golf TDI engine oil pressure light
  8. 94 Golf no start in hot weather (no crank)
  9. Help needed starting Golf IV
  10. someone please help! 94 golf diesel
  11. cromodora alloy wheel center caps
  12. 1994 Golf - Oil pressure light keeps coming on
  13. Gear gater
  14. 2001 Golf Alarm/Keyless Entry Question.
  15. vibration damper question
  16. Unable to start when hot
  17. Light Bulbs
  18. WTB: Rubber Door Seals 91 Golf GL
  19. Aircon = -hp
  20. VR6 engine
  21. inner tie rods, WHERE TO BUY THEM?
  22. WTB: Exhaust Seal Ring for my 91' 1.8L 8V Golf MEX
  23. '00 Golf 2.0 Cylinder Misfire
  24. Cylinder Misfire '00 Golf 2.0
  25. Reasonable price to fix ignition switch?
  26. Do you like your golf?
  27. Squeek coming from under the vehicle
  28. Golf Gt
  29. Mk3 Golf Not Starting
  30. Throttle Body
  31. mk2 golf vr6 lump transplant ?
  32. Does any1 here actually reply 2 threads or just view?
  33. Golf 93 intermitent over heating
  34. 2002 VW Golf Hatch will not unlock
  35. Golf MK3 Wipers
  36. Do all golfs have very light steering?????
  37. Where can i find Custom Golf GTi Body Kits?
  38. New and have some questions please help.
  39. '99 golf gls starts and dies within seconds- help
  40. What first...
  41. Quick Question : Help Plz !
  42. Remote Start Question
  43. Anyone with knowledge of subwoofers and amps
  44. Tranny code
  45. Golf No More, The Rabbit is Back
  46. I Work in Halfords So if anybody needs price....
  47. Mk3 GTi Clutch/Tranny problems?
  48. Minor Body Work
  49. Recon kit for Pierburg
  50. Golf ECP light ... most common causes
  51. 94 Golf will not start
  52. wheels for sail
  53. looking for a 98 golf
  54. mk3 GTI 16V! Does anyone Know?
  55. 97 GTI Wipers
  56. are all 2.0L 16V the same for parts?
  57. CHECK ENGINE light
  58. Need advice on finding a mod.
  59. Shift linkage bushings mklll
  60. Mk2 Golf for sale
  61. 2002 GLS losing power
  62. 1998 Golf GTI
  63. Golf 1996 power steering
  64. MK3 Diy thread
  65. Golf MK3 Air Filter/Intake????
  66. Air Baggin a Golf
  67. 96 golf 2.0 clutch cable question???
  68. VW Golf noisy power steering
  69. Golf VR6 Hiline 97 - Heated seat not working?
  70. moulding clips?
  71. 5 Cylinder Engines
  72. RPM Madness!!
  73. Mk V R32
  74. E-Brake problem
  75. UK MK3 1.8L CL owners....
  76. 96 4 cyl auto maybe running on 3?
  77. radio is killing my battery
  78. Mk3 Golf Engine Doesn't Idle
  79. Mk4 VR6 swap in Mk3 Golf
  80. Any 1.9L turbo diesel drivers out there??
  81. MK2 Golf Cooalnt problem can you help me?....please
  82. Smoked Angle Eyes Upgrade
  83. Spluttering 99' Golf 4 1.8 20v
  84. GOLF 96 Light and Fan question.
  85. 1992 Golf GL Overheating
  86. Opinions please.
  87. F/S NJ - 1999 Volkswagen Golf 5 Speed
  88. VW Golf 2006
  89. Diesel golf, gti, jetta
  90. help with my mk2 golf 1.6
  91. r32 1/4 mile time
  92. Oxygen Sensor
  93. Water Leak Under Dash 94 Golf
  94. looking for TDI
  95. Gaerbox oil issue
  96. Gaerbox oil
  97. Stalling problems with Golf 1.6CL
  98. Another Problem...
  99. buying a mk3/4 in the U.K
  100. Opinion on 97 golf
  101. Golf GL to GTI
  102. Starting and alarm problem...
  103. Volkwagen 1994 FORESALE
  104. 88digifant to a 84 gti motor swap
  105. Headlights Stay On!!!
  106. no reverse lights!!!!!
  107. 1st Time post...help needed?
  108. Golf Mk IV V5 Tail Light Replacement
  109. GTI 1990 1.8 manual - starting problem
  110. proper alternator.
  111. 94 golf diesel engine swap-or injector?
  112. 92 Golf Test Mass Air Flow Sensor (Hard Start and Hesitation)
  113. Need front left frame Golf MK4
  114. Need front left frame Golf MK4
  115. electrical problem...alternator maybe? MKIV 2.0
  116. mk4 indicators won't blink
  117. Gearbox problem
  118. Gearbox problem
  119. head bolts
  120. MkII engine cut out, won't start
  121. 2002 Golf TDI door lock blank
  122. HELP.....Overheating 93 Golf...
  123. Driver side door lock
  124. inner door panels
  125. Going crazy Electrical Problems
  126. 98 golf: remote alarms car but won't lock/unlock
  127. Golf Mk3 1.8 For Sale
  128. Can i get an induction kit for mk3 1.4cl
  129. Golf Mk3 Intermittent Stopping
  130. why wont my heater controls light up?
  131. timing issues 92 golf 1.8L 8-valve
  132. Quick question
  133. ECU chip (2.0 L 8V) and clear euro-style corner lights
  134. Clicking Relay ?
  135. dent removal?
  136. what does SR mean?
  137. Sunroof stuck open on tilt
  138. Where is the thermostat on 91 Golf
  139. Golf Mk 2 Engines
  140. Paint code
  141. Brake Fluid for '79 Golf GLD
  142. 1/4 time
  143. Oil light flashing Car wont start HELP! - VW Golf 1.4i
  144. mk3 engine problem
  145. Having problems staring my Golf 95 CL - HELP!!
  146. Exhaust?!?!?!?!?!
  147. Golf epc/ecu problem cranks but wont start
  148. 89 Mk2 1.8 idling probs
  149. I have a question about electric system
  150. look for spare mk3
  151. Steering Wheel
  152. Oil leak question???
  153. Cold Start Problem (Please HELP!!!)
  154. MK4 Heater has packed up
  155. Golf Mk3 engine running badly at low revs
  156. 1992 Golf GL: "Boots" on CV Joints!
  157. new to VW Golf
  158. Electrical Demons
  159. Knocking sound in 1st and 2nd gear
  160. E-brake Cables
  161. Looking for Used Diesel Golf or GTI
  162. Who has any idea which race this VW Golf ever raced?
  163. stud diameter for mk3??
  164. Central Locking
  165. Coolant Warning
  166. United Kingdom - R32 availability?
  167. Alarm not functioning correctly
  168. Mk4 Golf Central Locking Probs & WIPERS
  169. headlights.....not there...:P
  170. Auto trans not fully going into reverse
  171. '92 Golf - Directionals not working
  172. After rattle when acceperator is released ?
  173. spark plugs
  174. '95 VR6 wont start....HELP!?!
  175. ALARM Someone just shoot me and save the insanity
  176. Hot & Cold
  177. ingnition switch replacement procedure
  178. '95 Golf III Oil in Air Filter??
  179. VR6 Fuel Smell
  180. My new ride
  181. alarm bypass and still no start
  182. MK II Dash Lights?
  183. Timing Belt Replacement On Golf Mk3
  184. ??? Highest Mileage ???
  185. fuel filter removal....
  186. 96 golf few ?s
  187. 4-Motion Overheating
  188. golf stalls when i put it gear??
  189. hrlp electrical gremilins
  190. Special window tinting
  191. My vw wont start number 5000 ha
  192. Alarm and Central Locking Issues, MK4 Golf
  193. Wheel setback
  194. pcv valve
  195. wiring 03 golf 1.4
  196. need help finding a part
  197. squeal/whirl noise from mk4 golf on idle
  198. Head swap
  199. car wont start HELP
  200. Acceleration Issues
  201. Mk4 1.6 Auto Hesitation from standstill
  202. Mk4 1.6 Auto Excessive fuel consumption
  203. help! 85 diesel golf ignition switch removal
  204. various quirky problems 2000 Golf GLS 2.0
  205. Headlight hell
  206. Interior like a swimming pool
  207. Mk4 1.4 stalling for no aparant reason
  208. 1992 Golf GL - - BRAKES!
  209. confused front wipers.. 1 works 1 doesn't
  210. 1988 Mk 2 Golf Won't Idle
  211. Everything electical acting up, car won't start
  212. Electric windows don't work with doors closed.
  213. golf '97 stuttering!!
  214. Vw Golf 1.8 Gti Turbo 1998
  215. brake lines
  216. 2003 VW Golf GTi
  217. ECU remapping 95VW GOLF 2.0L 8V
  218. Any one know where to find to AC Evaporator Drain tube on a 95 VW Golf?
  219. Mk4 Golf GTI 1.8 20V alarm fault
  220. Mk 1 misfire
  221. New Fuel filter
  222. 88 golf smokes and idles bad
  223. upgrading stereo system
  224. 1995 golf 1.8 top end and a 2.0 bottom end I need more gas.
  225. Does anyone have a spare airbox laying around for a Mk3
  226. Corrado G60 parts, good for FI
  227. Golf 95 Gone Crazy !!!!
  228. 97 Golf...wet weather start problems!
  229. idling problems
  230. Outside passenger door handle problems
  231. '04 TDI 4 door banger project
  232. 95 golf won't idle
  233. 1992 Golf "oil separator(?)"
  234. Drivers Side Door Lock
  235. Please Help Me
  236. It wont start when hot weather
  237. Can ANyone Help WIth THese Questions?
  238. 95 golf 2.0 -> black smoke, erratic idle
  239. coolant/fuel gauges both out
  240. Audi A4 Wheels to fit Mk4 Golf?
  241. I have Gremlins....really
  242. Door handle swap
  243. golf gti 1999 non start in hot weather
  244. G-Spec
  245. smell
  246. ?Immobiliser prob golf mk3 vr6
  247. Cutting out problems on mk3 golf gti 2.0 8v
  248. Specs Of Mk3 2e 2.0l 8v
  249. Passenger Door will not open
  250. Help, I'm Overheating!!!!!
