View Full Version : Intrigue
Pages : 1 2 3 4 5 6 7 8 [9] 10
  1. tape player dead
  2. Air Intake Grilles
  3. Delco radio error codes
  4. 2001 Intrigue Climate Control in Celsius
  5. Headlight and Dashlight Flicker
  6. looking for radio unlock codes
  7. Oil and brake problems
  8. Alternator replacement/electrical issues
  9. Starting troubles (not turning over)
  10. i need help
  11. General Intrigue Fixes
  12. Climate Control Problems
  13. Where's the thermostat
  14. Oil Life Monitor
  15. Rattling Noise
  16. 98 Intrigue Intermittent Starting Problems
  17. Automatic Headlights
  18. Squeaky noise when brakes are depressed slightly
  19. Olds Intrigue 99 A/C-Temp Control
  20. how to dissconnect the governer
  21. Replace Alternator ???
  22. NOISY valve lifter(s) or rocker arm(s)
  23. no heater display/heat
  24. Wipers Stopped Vertical....
  25. Engine Oil
  26. Slight sticking of throttle
  27. Blower Motor not coming on
  28. coolant leak help please 98 GL 3.8
  29. How to Tell Which Model I Have
  30. 99' intrigue overheating 3.5L 6Cyl 109,000 miles
  31. A/C orifice tube
  32. Burning Smell
  33. Window creeking sound
  34. headlight flicker
  35. auto trans TSB's
  36. Four Headlight Relay
  37. service engine light
  38. 19mpg to 16.5mpg after trip, causes?
  39. What does a defective CV sound
  40. Heavy Duty Brake Upgrade
  41. Heater output
  42. Intrigue Transmission (4T65E) prices.
  43. Listing for GM transmissions. What tranny does my GM vehicle use?
  44. Hi-Po 4T65E Raptor transmission
  45. What size Socket, front wheel Hub
  46. Help need to know were to start looking
  47. Where are the Spark plugs
  48. Funny Thing at the Bone Yard to-day
  49. Heater Problems
  50. Where is ecu or computer located 99 Intrigue
  51. Warning replace your Plugs don't believe GM
  52. What lights should be on?
  53. 99 intrigue trans problem?
  54. Any-one with a code reader in Toronto area
  55. Front-end Noise at 40mph & 60mph
  56. Engine light on, Intrigue '99 3.8
  57. 3.5 L Engine
  58. stereo codes
  59. what the hell?
  60. thought i'll give my fellow intriguers a heads up
  61. burned CDs that skip in Intrigue CD player?
  62. replacing your flasher
  63. Bose CD Radio
  64. Taking my Intrigue On A TRIP
  65. transmission: fuel evaporation
  66. Quick Questions (re: lights and sound system)
  67. Oil Change light
  68. oil service
  69. Long Life Transmission
  70. frequent fog light burnout
  71. Backfire
  72. The Cost of an Import vs the Reliablity of an Intrigue
  73. Replacing CPS
  74. timing belt?
  75. A common problem so it seems... my turn signal issues.
  76. Worst trade in value EVER?
  77. Chrome Trim Moldings around doors
  78. Cloud of White exhaust smoke
  79. Paint Codes
  80. how to change coolant?
  81. Preventing The Window from falling?
  82. A/C blinking information wanted....
  83. Another window problem!
  84. Window Problem!
  85. coolant light
  86. Stuck Shift Knob !!@#!@
  87. A/C just stopped working and light blinks...
  88. headlights and taillights
  89. Help with "Change Oil"
  90. Need Serious engine help!!!!
  91. passlock problems
  92. Oldsmobile Modifications
  93. About the front end as well as a car accident
  94. PCV Valve
  95. Passenger Turn Signal failed
  96. front end noise
  97. PCV valve location
  98. Towing
  99. Coolant Temperature Sensor
  100. replacing air filter
  101. Traction Low Light Keep Coming On
  102. rear speakers
  103. Spark plug installation for 2000 Intrigue
  104. Intrigue=Lemon
  105. window down
  106. intrigue grounding
  107. NHTSA informations (recalls and complaints)
  108. Throttle Body and EGR
  109. 1998 program remote....this worked for me
  110. 97 intrigue trouble starting?
  111. Changing brakes on 2001 gx
  112. Transmission questions
  113. wind noise from mirrors
  114. A/C problem (works after ~10 miles)
  115. Sun visor
  116. 2001 Frontend popping
  117. Leaky oil pan gasket
  118. 3.5 Shift points
  119. Shift knob...
  120. Service engine soon code P0440
  121. 99 Intrigue Horn Blows Intermittently (usually when cold outside)
  122. Found Great tires
  123. Sun roof problem
  124. 2000 Altenator blues
  125. 01 Intrigue, metal scraping noise?
  126. How do you find error codes?
  127. Fuel Pump problem is possible?
  128. Water thru AC filter
  129. 98 Intrigue shuts off when driving
  130. since their wont be a new intrigue
  131. How many miles are on your Intrigue?
  132. automatic headlights problem
  133. intrigue abs light
  134. Car turns over but takes 5 seconds to start...
  135. idler pulley 3.8
  136. intrigue
  137. A/C blows cold air in only 2 vents
  138. Can you adjust the seat height in Intrigues? If so, where are the controls?
  139. Acceleration Lull/Response question
  140. Door Paint Peel - 1999 Intrigue
  141. More cooling problems
  142. how to
  143. 98 intrigue pass side rattle
  144. shaking in park ..
  145. Automatic Climate Control
  146. Heater/AC Control Switch "Issues" 98 Intrigue GL
  147. oldsmobile a/c trouble please help
  148. Noise of water running 2000
  149. 1999 Intrigue Rumbuling Noise from Front
  150. Electrical/Water Problem?
  151. a/c drain
  152. gas peddal?
  153. '99 3.5 Speed sensor failure @ 86k - $500
  154. Intrique 99 Remote
  155. ABS computer
  156. Coolant light on
  157. air pump fuse
  158. Digital Climate Control Problem
  159. Bad Key Ignition
  160. Ignition Switch Lockup
  161. 3.5 Intrigue shift points.
  162. problem when turning
  163. gas and trunk release problems
  164. 98 intirgue alloy wheels problem
  165. Bearing Assembly
  166. Automatic headlights... can anyone disable this...
  167. Intrigue Exhaust
  168. Power Gas Door latch failure
  169. V6 3.5L Engine Shot at 42,000 KM
  170. More Turn Signal Problems
  171. AC cycles off/light blinks?
  172. Almost stall after startup/synthetic myths?
  173. 2001 Intrigue tranny question
  174. Service Engine Soon - Code P-0446B
  175. electric problem
  176. Alt. replacement on 99 olds 3.5L
  177. Control Buttons Running Hot
  178. High-pitched whurr - ABS motor?
  179. left blinker
  180. Left rear tire noise
  181. Power Door Locks
  182. Is my window motor going?
  183. Starting problems and Anti-Lock Brake light
  184. Programming Instructions for 02 Olds Intrigue
  185. Intrigue Transmissions are problems!
  186. Starting Problem...just click
  187. Gas Mileage
  188. Spark Plug Gap
  189. Turn Signal Problems
  190. 1999 Intrigue Cam Sensor
  191. 2000 Intrique Power windows
  192. Removing the u-bend and resonator from Intrigue exhaust
  193. A/C light blinks
  194. Overheating
  195. Oil sensor plug
  196. Fuel pressure regulator or not?
  197. Coolant leaking
  198. Brake warning light
  199. Service Vehicle Soon light and Air Pump Relay
  200. Question:Rear Air??
  201. 1998 Intrigue Front Cupholder
  202. interior lights
  203. Transmission shifting
  204. '99, 3.8l engine movement
  205. Power window problem
  206. Oil Problems
  207. fuel pump location
  208. Car Hesitation or Burp
  209. p0410 code
  210. 2000 Intrigue PCS light
  211. Turn Signal
  212. 1998 rear cup holder
  213. AC question
  214. Radio & A/C lights
  215. High Idle Fixed!
  216. Electrical behaviour
  217. best superchager
  218. Service Engine Light
  219. Any of you Intique owners interested in a new Olds forum?
  220. 99 Intrigue burning oil
  221. What is It??
  222. Heater Control switch
  223. Power Steering problem
  224. 99 Intrigue alternator
  225. ????
  226. Oldsmobile intrigue 3.5 COLD AIR INTAKE
  227. Blown Tranny 2000 GLS 102K miles
  228. Hello all.
  229. Newbie
  230. 99 Intrigue Engine Knock
  231. How Serious is this engine code??
  232. 2001 intrigue wind noise
  233. Car cranks for ever before starting, any clues?
  234. To dex-cool or not to dex-cool...
  235. 2001 Intrigue Keyless Remote
  236. New Forum member
  237. my car tries to turn itself - kinda like Christine-what do ya think
  238. 98 intrigue engine light
  239. 99 olds hard starting
  240. Coolant light came on
  241. low idle
  242. OEM cassette radio
  243. Questions
  244. High Blower stuck on
  245. Emissions pump?
  246. 99 keyless remote for intrigue
  247. Aftermarket receiver options?
  248. 1998 Olds Intrigue GLS & EGR
  249. Update-2 on Thermostat and Service Engine Soon Light
  250. 98 windshield washer fluid will not pump
