View Full Version : Intrigue
Pages :
1 [ 2]
3 4 5 6 7 8 9 10
- 1998 Intrigue power window failure
- Fuel Filter
- 99 intrigue electrical problems
- Anybody know what this is? (Behind rotor)
- Front sidemarkers
- Power Steering Stiff, Pump vs. Rack? No ETBCM Codes
- Something with the oil
- Dumb Question
- Tranny smell
- TCC Lock up when warm / Code 742/ Which solenoid is the TCC solenoid?
- Any input on this??
- AC Condenser
- Sold the 99 today, A bit Sad, Many years of Great Service
- Clicking sound when I tUrn Right Only
- Cassette is stuck
- Tranny drain
- Which Intrigue to buy???
- 99 intrigue
- Shuts down after a hittiing bump.
- Bad Strut Causing Bad Alignment?
- Changing Spark Plugs
- 3.5L V-7 Compressor Removal and Reinstallation
- 02 Keyless Chirp/ 99 Headlight issue
- Diagrams
- ABS reset
- Paint Code
- Proper way to jack up Intrigue?
- Bouncing front end
- 2000 with P0122 DTC
- 2000 3.5L Coolant loss and misfire
- tie rods and ball joints
- AC blowing Hot/Cold air through vents, car has Manual climate control
- Anbody have a wet trunk???
- A/C Control Dual Zone switch assembly Not Working
- A/C fixed but need help
- 01 Intrigue-Slow Cooling Fans-Engine getting hot.
- Regrounding the Tranny?
- tranny cooler?
- car dead rotten egg smell, strange noise
- 2000 Intrigue front hub assembly replacement
- Intrigue 99 3.5L Engine Misfire Code P0300
- 2002 3.5L Vehicle History Report???'s
- 2002 3.5 problem with steering???
- A/C whining
- A strange sound
- P0101 & P1811, 20% Possitive Short term fuel Trims Need Help..
- ONLY 13 MPGS any ideas?
- Sold my Intrigue, sad but true
- Where can I buy Quick Struts for Rear
- SEL, ABS, Brake and Trac Off lts but no codes
- P1811 Transmission hard shifting replaced PCS Twice
- freeze plug leaking?
- HELP 99 Intrigue Pulsating
- Another Intrigue Trans Issue
- 3.5l V-7 A/C Compressor Rebuild/ Reseal
- Ambient Air Temp Sensor
- What extra Intrigue maintenance would you do at 100k miles?
- Intrigue motor swap 3.5 to 3.8
- Steering Gear / Steering Rack Replacement
- 02 olds intrigue 3.5 another tranny problem
- bcm problem
- Replacing PCV Valve for 3.5L Intrigue?
- Automatic transaxle removal (4T65E)
- What wires can I splice to Keep Rad Fans "ON"
- Fuel Filter for Intrigue
- Car Rotting at bottom of rear rocker area
- Four wheel alignment
- Alarm activated by garage door opener
- Step By Step Instructions to Replace 98 Intrigue Transmission?
- flasher location
- Windshield?
- 98 Intrigue Transmission Issue
- Electrical Problem
- three problems happened !!!!
- Replacing Auto Transmission 4T65E
- Rough idle at freezing cold start - 2000 Intrigue
- Real wheel alignment - 2000 Intrigue
- HELP!!!!!! 2002 Intrigue3.5L wont start
- blower motor stay on!
- Heat not working 98 intrigue
- Car won't start
- Slight delay when shifting from park to drive
- Intrigue Right High Beam is out
- 2001 random missfire
- Do our cars have starter Interlock
- Replacing radio with steering controls, advice?
- 99 3.5L engine rebuild questions???
- Brake Recommendations
- Random Stalling & random lurch/miss
- Engine hesitates while accelerating
- Upper Intake Manifold - Intrigue 98, Service Engine Light on
- '01 Oldsmobile Intrigue Front speakers not working
- Corroded brake lines, but solved fuel econ. issue
- Head Gasket on 3.5L LX5 V-6
- Another ignition switch problem?
- Oil warning Light came on
- Lots of problems
- 2000 3.5L Cylinder 4 misfire
- "vommmm" sound/noise coming from front-end
- engine kills when I turn the left turn signal
- Alternator going out?
- Transmission Issues
- Fuel Gauge Reading Full or Empty All The Time?
- Brake Warning Lights? Traction Off Light? ABS Light?
- Intrigue project
- Ignition Switch Replacement
- Multiple OBD codes
- 98 olds intrigue 3800 lower intake mani removal
- Solutions for New Steering Wheel
- Bum heater
- 99-3.8 Loosing Coolant, Can Smell it in engine area
- Water Pump Replacement 3.5l
- dashlights coming on
- 99 Intrigue Starting Problems
- Engine stops while on the highway
- Rocker panels shot
- Trunk Gasket
- Whining from engine bay when accelerating
- Upgrade Advice Needed - Prioritization??
- Intrigue 1998 - hard start damages starter
- Factory Battery Removal 2002 Intrigue How??
- installed new battery-now idles at 1,200 rpms
- Need to Know Wrench & Socket size
- Catalytic Converters
- What's Your Favorite Rotor & Pad Combos?
- Need a door!!!
- Keyless entry ??'s 02 3.5L
- P0420 o2 sensors 2002 Intrigue 3.5L
- Wierd ????? about Radio
- Heater Fan only works on speed 3 4 5
- Rockauto Clearance for Intrigue
- Help with torque specs please.
- Traction Control Switch
- I found a place that can Tune the LX5 Shortstar
- 2001 Olds Intrigue, inner and outer tie rods
- 2001 Olds Intrigue, need diagram for inner and outer tie rods, please
- Not Starting, did ignition switch - no help
- 99 Intrigue Oil & Coolant smell
- 2002 Intrigue air injection system fault
- Brake light on dash on!?
- AC: High Side Pressure Spikes Normal?
- Watch your odometer if you disconnect the battery!
- Use the turning signal blinkers engine shuts off!!
- A/C "Mode" switch not working
- 2000 Intrigue transmission filter change
- I over toruqe a thernostat bolt any solutions
- 98 3.8 Intrigue - Air from all vents
- overheating problem and what can cause it
- Low Trac/ABS
- Radio Reception
- 2002 Intrigue brake rotors
- 1998 intrigue won't crank...
- 2001 3.5L engine stutter intermittently
- 98 bleeding brakes/ABS light comes on
- Air Pump
- Only passenger side blows cold
- blower motor
- Heater Core Replacement - 98 Intrigue
- 3rd brake Light Add On Module
- intake plenum replacment
- Crankcase position sensor
- 2001 3.5L Intrigue Code P0300
- Must be a prototype.
- Front passenger-side headlamp assembly likely to be for sale
- Continuing problem with 98 intrigue - misfire #6 cylinder
- Gotta love the summer A/C threads
- Windshield Wipers Retarded!!!
- My 2000 Intrigue problems
- 02 Olds Intrigue driver door electrical panel
- Hard Shifts
- Rock Auto Clearance Items
- 99 Intrigure External Temp and Recirculate
- 00 Intrigue Hard Start, high revs
- Crankshaft balancer bolt
- 99 intrigue transmission issues
- broken sway bar
- 99 intrique
- 98 intrigue...clicking under hood
- Intrigue 99 Air Conditioning
- Power Window Regulator
- cylinder 6 misfire
- Fram Air Hog recharge
- '99 Intrigue A/C Questions
- AC compressor does not engage 00 intrigue
- Another one gone....
- How to change inner tierod end
- Key fob working intermitently
- 98 intrigue 3.8 intake help
- front speakers/bose
- thermostat on 02 olds intriqe
- Several Issues W/99 Intrigue
- 98 intrigue...pwr window cable.
- blend door for heat/ac
- cooling system problems!
- Low Coolant Light and Low Oil Pressure Light is on were are they located?
- Left front Turn Signal
- Anyone put led's in their Intrigue??
- Automatic Headlights Don't Come On
- Fog Light Assembly
- No Front, Rear Brakes only!!
- Torque specs for engine and Transmission?
- Third Brakelight Flasher Module
- 99' intrigue, engine lock?
- 3.5 Ticking
- Removing harmonic balancer/pully
- Oil suggestions for high mile 3.5
- Stipped Wipers
- Front struts
- intrigue overheating!
- 2001 Olds Intrigue 3.5 No Spark
- Starts When It Wants To
- a/c blowing heat on driver side and cold on pass
- UPDATE: Flashing dash on startup, accompanied by dieing randomly
- HELP! Good Samaritan Needed for Pix
- would you attempt an ignition switch change in your driveway?
- 2000 Oldsmobile Intrigue 3.5 transmission failure no D or R
- Leather Cleaning Suggestions
- Need Pointers on Replacing CV Assembly
- Small coolant leak
- When turning to the Right I hear a Cliking Sound
- 1999 Intrigue recall on steering shaft and joints
- weird stuff on startup problem (update)
- 3800's recalled.
- remote keyless entry problem
- Where to buy sheet metal?
- Climate control and Brake Issues
- How to clean the MAF sensor?
- Engine kicks to high rev, in reverse
- olds intrigue fuel door and trunk release issue
- significant sputtering @ 40 mpg ++
- 1999 Intrigue 3.5L - AC blows, but not cool air
- Different gauge cluster?
- Aurora V-8 to Intrgue engine swap.
- Wierd stuff on start up
- 99 Intrigue 3.5L - P0410 -Service Engine Code - Help
- Car will start and shut off
- Hazard Switch compatibility Question
- 99 olds intrigue sunroof issue!!!
- 3157 Replacement DRL Bulb
- Need Help! Crank, No Start.
- Intermittent problem after driving in fog, high humidity
- 240,000 Club
- how do i get rid of the seatbelt reminder bell in '02 intrigue?
- 1999 transmission install
- 98 Intrigue engine failure?
- Transmission not shifting smoothly after using cruise control
- pwr. window cable..98 intrigue
- Anti-freeze leak
- Looking for a new window switch.
