View Full Version : 3000GT/Stealth
- A 3/S Legend has passed away.
- Stealth/3000Gt -TCM pa
- Ultra-Mega 3000GT/Stealth part out thread
- Need a reman a/c compressor 3000gt
- Good ol days!!
- resistor engine control module MD145962
- 91 Stealth srats for 10 seconds and stops. Car may still be in limp mode.
- Help
- 2016 3S National Gathering
- East coast gathering
- 1995 3000gt overheating need help
- Need help
- Heres What I want Whats going to be the Tilly?
- favorite cool air intake system?
- Lost MY CAR KEYS NEED HELP
- 1995 inside fuse box
- Car will not start after changing crank and cam sensors
- Crank Pulley removal
- tactmeter
- 1993 stealth etacs problem need help
- Check engine light comes on & goes off
- 97 3000gt w/40K but problems..should I buy and gamble?
- 2014 3S National Gathering
- 1991 Dodge Stealth R/T Sale Rebuild Engine
- 93 Dodge Stealth Starts, Runs Rough then Dies
- Any good Stealth Mechanics in Maryland?
- car is backfire when driveing
- Plans for behind rear seat speaker box
- Pulse generators
- Help with engine swap please
- '91 VR4 radio replacement
- 2013 3S National Gathering
- New Shift Boot From Bonnie B Buttons At eBay
- Reverse gear grinding in vr4
- Please Help! as I attempt to descripe the alarming proformance in my 1994 3000GTsL-
- 1999 3000GT base for a first-time car buyer?
- 2013 3000GT / Stealth / GTO Calendar On sale now.
- Valve Cover removal
- 2012 3000GT/Stealth National Gathering
- 3000gt sl tranny probs
- Charging System warning light help?
- 3000gt sl fuel upgrades
- 3000gt i need some help
- Any old school 3SI members here (1998, 1999)?
- need to adapt a 91 3000gt engine non turbo, to a 93
- ECU help to others if needed !
- '91 Mitsubishi 3000GT enige for sale
- ECU / Capacitor problem
- Mass Air SensoR
- Fuel injectors
- East Coast Gathering, 2012!!
- Selling my 98 VR4
- NEED HELP (electrical)
- 91-96 3000gt/Stealth K&N Air Filter For Sale
- 2012 3000GT / Stealth / GTO Calendar
- Need advice for 97 3000gt base
- Hot Start issues
- never have changed my coil pack or module.
- Turbo help
- How to wire new cooling fan to the existing cooling fan wiring
- ATX shifts hard. Solenoid?
- 91 GTO wont start
- HID Light Kits
- Vibration and noise when braking
- 1992 BASE Marker/Turn Signal Assemblies?? HELP
- 2012 3000GT / Stealth / GTO calendar submissions
- Replacing front & rear main seals
- Fuel filter change or upgrade
- No leaks and only 5 psi.... why?
- AC wiring problems
- rear driving lights/dash lights keeps blowing fuse
- 3000GT LS AT TRans
- *** GZP / 3Swarehouse 30% off SALE ***
- Car running sluggish when warm or humid
- 2011 3S National Gathering June 21-26 2011 Indianapolis, In
- 1991 Dodge Stealth ES for sale in MN
- 1991 Dodge Stealth R/T TT AWD for sale with 20k original owner miles
- 16g turbo kit forsale! must sell! cheap!
- Help please,h ard to find vacuum leak
- 2011 East Coast Gathering
- Things to do if your car has been sitting awhile?
- 3000gt's/Stealth very own off topic thread: v 5
- Want to get my 3000gt to 600hp and insane torque
- looking for a vr4
- Snow cables vs snow chains
- Efffffffffff
- Electrical Gremlin
- 2011 3000GT / Stealth / GTO calendar - Just in Time for Christmas
- Rims & Tires
- Alternator Removal Question
- Clunking Noise??? What is it??
- Seat Covers and Shift boot
- smoking 3000 gt
- got a base 161hp 1998 gt, pls help!
- 2011 3000GT / Stealth / GTO calendar voting.
- Starter Problems???
- extremly high idle
- My 3000 GT turns 0ff while driving
- O2 sensor
- Problems after changing IAC
- 3000gt knocking noise
- Dashboard light help
- oil pump
- Reverse Lights
- Iac & maf
- Car will stall out in neutral.
- 3000gt SL Twin Turbo ECU and MAF?
- y pipe?
- What type of upgrades should I be looking into next?
- TPS question
- 3000Gt VR4 main cap for sale?
- What do I need to change out
- Best vendors for rebuilt 94 Auto Trans
- 94 auto trans
- 3000gt vr-4 main cap.
- License Plate ideas for my new 94 3KGT
- nj, pa, ny owners
- finally
- Pictures from the 2010 3S National Gathering
- Clutch Problems - 93 Stealth R/T
- Harmonic Balancer Fell Off
- Sl to Turbo engine swap
- Automatic Tranny Help
- vote for the stealth
- only firing on 4 cylinders...
- Alternator Problem or Not?
- Confused?!?
- Red flag lmi turbos
- Possible Clutch problem?
- Thought I'd give this a try: Need parts painted anyone?
- I need some help with my 95' 3000gt....
- Clutch line
- Rebuilding turbos
- Passenger window
- Heater hoses replacement
- Blown Head Gaskets how long...
- Car wont stay running
- Finally got a nice practical DD!
- oil question
- spark issues
- AC verses Idle control !!!!
- The End of an Age
- Need help... Car starts for 10 seconds then dies
- Psi
- New Shoes
- Won't boost past 10psi
- Moving The MAF Sensor
- car dead twice...help
- cars dead twice. think its the alarm
- 6g72 swap with 6g72 tt
- Ok, I'm frustrated...(eBrake light in 1st/2nd)
- 3000 gt sl dohc engine parts
- VIN research
- has any one tried these?
- hard rights
- Climate Control Display Dead???
- motor source
- stock injector sizes ???
- turbos???
- Changing Vaccum lines and hoses
- Just rebuilt the clutch master
- Car won't start after siting for a short time
- adding turbo
- complete wire harness
- I have questions about the test pipe.
- Regular Maint. & Tune ups for better upgrades to come.....
- Cant boost past 6psi without knock
- 94 VR4 What mods should i add?????
- Clutch Problems!
- rough starts
- ECU Fried
- 3000gt running rich and back firing
- Stock seat and carpet color?
- Sunroof and o2 sensor questions
- lifter tick, please help i can't find the right info!!! :(
- intake?????????
- eating gas rough idle missing when cold
- need some help
- fender flares
- Positive Battery cable
- afc-nea/can i hook it up to a non tubro???
- avc-r question???
- question about rims
- Quick Question
- Not starting
- 3000GT buyer
- i hate to ask...gm maf & maft questions
- How do i install a JVC KD-HDR60
- Clutch master cylinder
- Car runs rough then dies??
- Timing
- identify please.
- Quick Question?
- Which boost controller to get?
- bought a book
- Any have input or know first hand which AFC is better or works better with our cars?
- 3000GT/Stealth National Gathering 2010 Registration is open
- No power coming out of the hole
- need help with vr4 fuel issue
- Clutch Issues and Transmission Options?
- Need help car wont start!
- interesting problem
- Starter??
- need some info about tranny options
- The 2010 3S National Gathering.
- Need help fast. No crank no start
- Any thoughts/feedback..?
- OBDI Diagnostic Port
- Opinions?
- 94 3000gt jdm engine swap crank and camshaft position sensor problems.
- RIMS! at long last. . .
- The 3000GT/Stealth/GTO 2010 Calendar
- Should I turbo It???
- 3000gt electrical nightmare help!!!1
- Clutch Problem/concern
- Boosting problems
- Bov?
- I have a VR4 but need to see if anyone knows Hyundai's?
- datalogger question
- vr4 engine
- how
- What does DSM stand for?
- Lug pattern
- help mom in need of advice
- Phazar
- 94 3000gt not sparking
- bypass valve conversion q...
- post boost leak test
- Changing Vehicle Speed Sensor
- Got a ? about SAFC vs 660cc injectors
- Irratic Idle...Help
- steering wheel adapter hub
- Can someone please run a carfax for me on a car I am about to buy cant tell accident
- totally random
- Solid mounts- Pros' and cons'
- possible vaccume leak?
- engine problem
- So are brembo rotors being discontinued?
- 1992 3000gt engine knocking!!!!!
- Boost gauge not working
- Help w/part removal, outside window weatherstrip
- Fluids
- brake lights and tach. not working
- Headlight conversion
- Cooling Fans!
- Just bought my first VR4
- question on oil changes for tt
- I need some suggestion on my 3000gt spoiler
