View Full Version : 924/944/968
- Just bought an 89 944. What now?
- Video: Replacing the camshafts, timing chain and slide rails on the 968
- Video: Replacing the connector of the Hall sensor on the Porsche 944 S2 / 968
- Video: Adjusting the timing of the VarioCam
- Video: Inspection of the VarioCam on the Porsche 968
- Video: Repairing the speedometer of a 944 S2 model 91
- Video: Testing the Bosch air flow meter of the 944 Turbo
- Video: Repair of the electrical auxiliary water pump on the Porsche 944 Turbo
- Video: Overhauling the limited slip differential
- Video: Overhauling the intermediate shift lever on a Porsche 944
- Video: Replacing the hydraulic valve tappets on 944 S2
- Driver Seat Adjustment
- Video: Replacing the seatbacks
- Video: Replacing shifting lever
- Video: Replacing radiator
- Video: Replacing engine mounts
- Video: Repairing the speedometer of a 944/1
- Video: Removal and Installation of the Steering Gear
- Video: Replacing the front wheel bearings at the S2
- Video: Replacing pads at the timing chain of a S2
- Video: Replacing wishbone
- Video: Replacing fuel lines
- Video: Replacing brakes at the floating-frame calipers
- Video: Replacing Clutch
- Video: Removal and Installation of the Gearbox
- Video: Replacing radial sealing ring and pilot bearing at the Porsche 944
- Video: Converting the late 944 strut to Bilstein shocks
- Adjusting the timing at the camshaft sprocket of the S-models
- Video: Repairing the digital clock
- Video: Repairing the glove box
- Video: Tightening the oil-water radiator of a Porsche 944
- Video: Replacing rubber bushes at the front stabilizer
- Video: Replacing the brake hoses at a 944 S2
- Video: Repairing the steering wheel lock
- Video: Repairing DME Relay
- Video: 944 Removing additional headlamps when the bolts are rusted
- Video: Replacing the camshaft housing gaskets
- Video: Making the Porsche Tool 9262/1
- 87.5 944 won't start.
- Video: Repairing an electrical seat
- Video: Repairing the central locking
- Video: Repairing the wipers
- Porshe 944 / First car
- Video: Changing the Gearbox Oil at a 924/944/968
- New Member
- Video: Repairing the tank cap
- Lost Torque drive - No forward or reverse
- 944 and car covers
- Video: Replacing clutch hydraulic at 944
- Video: How to replace the brakes at a 944 S2
- Video: Making the Porsche tool P 233 for locking the fly wheel
- Video: Servicing a 944
- Knocking from under the shifter. Please, any input.
- Video: Replacing water pump, belts and shaft seals on a 944 S2
- Changing the coolant switch on a 944 S2
- Changing the driveaxle boots on a 944 S2
- Rims for 944
- 85 Porsche 944 electrical problems!
- WTB 1986 944 parts
- Victory motorcars – Good Service!!
- need help for 944
- Repair of a S2 with a broken timing chain
- 1987 Porsche 924S for Sale
- 1983 porsche 944
- 944 new buyer help
- 1984 porsche 944
- 1984 944 fog lights
- AC Switch late 944/968
- 944Fest @ Nelson Ledges OH June 5th - 7th
- Battery wont charge?
- Temperature gauge shoots straight up?
- FOR SALE: 944 parts
- Wanted: 968 mirrors
- 944 cuts off
- Porsche Dash Plastic
- 968 tiptronic or manual?
- Screamer
- S2-968 Head Swap?
- 944 online.com
- 944 gt3
- 1986 944 not starting...
- 944Fest 2008 @ Mid Ohio (DE EVENT) - Registration Now Open -
- 1985.5 Porsche 944 runs rich
- air-oil separator
- 944 Odometer Behaviors
- 944 Cam belt slipped?
- 944 Timing Belt/balance Belt
- oli problem
- fun in a 944
- 86 924 Lsd
- chevy 350 conversion
- 85.5 Porsche 944 cranking problems
- 78 924 Rear Seatbelts
- 1986 944 Turbo For Sale
- reliability? specs?
- Rear Wheel camber
- Relay problems
- Performancechips.com
- Is this a good deal (link)
- 944 Cooling Fan Not working
- oil pressure 86 944
- make a fair offer
- Bad Fuel Pressure Regulator?
- '86 944 making loud road noises
- i finally got it
- Parting out an 83 Euro if anyone needs something.
- 83 944?
- 84' 944 starter?
- 944s wheels
- 944 Serpent belt NO A/C
- 924-944
- '78 924: Which fuse is which? :P
- Do I really need my Catalytic on my '83 944??
- Water pump issues!!!!
- 944 turbo???
- Wanted: bargain 944 convertible in UK
- 944 buying questions
- 944 Block Swap
- Fuel Pump DME Relay!
- Just bought a 944! I have some questions!
- '86 944n/a Stalling Problems
- looking at a 944
- Rear Hatch
- timing belt etc.
- 944 light problems
- apples to oranges
- mods
- Riding with kids in a 944 cabriolet
- timing belt
- 944 turbo porsche part car, need any parts?
- 1987 Porsche 944 Renegade
- RB26DETT in Porsche 944?
- body panels of 924
- Alignment adjustments....
- Slotted rotors for '86 944 Turbo?
- 944 Track Time
- Porsche 944 Oil in Water
- 87 944 turbo starting problem
- 944 vs. toyota supra, how can i do it?
- wheels for 84 944
- My new 944
- Pumping up Hydraulic valve How
- How do get the rear crank seal out?
- Help! Vacuum leak, miss fire, 951
- 85 late 944 started after sitting valve chatter
- Need Radio Immediately
- 1985 Porsche 944 late n/a
- 91 twin turbo supra engine in 944
- how much to sell.
- 89 944 will crank, but will not turn over.
- Paint job cost
- Installing racing seats and harnesses
- Opinions
- Replacing Tranni-Torque Shaft "Coupler"
- 84 Porsche944
- selling my 944turbo cheap
- won't start
- cheap 944 modifications
- 951 Rev Limiter?
- Starting Clutch Job, Any Pointers?....Please
- 944S noise problem
- Modify 944 engine
- 944 S2.....which tyres??
- Pressure Problems
- change sensors when chenging the brake pads??
- What Is a realistic price to modify 951 motor
- when to change oil/air and fuel filters?
- K&N air filter increases ther engine noise?
- 84 porsche 944 hybrid question
- Porsche 944 w/ LS 1?
- sunroof relay question
- 1983 944 stuck in neutral and can't shift into any gear
- 951 fs in ohio
- Looking for a Switch
- I think I Need a clutch kit now. *sigh*
- starts but stalls immediately
- time for timing belt...
- 944 Factory Shop manuals (6) for sale: Ebay
- 944 body kit for SALE!!!
- new and just bought a porsche 944
- oil leak...
- beating on a 944T
- 944 Sunroof
- 944 turbo
- Regarding Mass Airflow Sensor
- 1979 Porsche 924 *died* need help
- Clean sub/amp install
- LS1 in 951?
- Leaky Fuel Rail...Again
- Nasty Idle Noise
- 944 tuning potential
- 944 custom exhaust and stock exhaust
- Cleaning out garage-late alum. control arms
- 944 N/A fog lamps
- project car
- 944 for sale
- 944S Porsche 1988
- Porsche 968 Info
- 944 turbo caprio i want comments
- Want to buy a porsche..
- Possible to use 968 headlites on a 944?
- A few things with my 944, please help
- engine fan
- HELP! 300hp+ Needed Which Engine Should I go with?
- '87 944 Oil fill tube leak
- Help Trans problem... no first or second
- CD player wiring? K&N FIPK? and chip?
- Mo30 Wishbone/control Arm
- rear shoulder belts
- 89 Auto 944
- Click click click click ck ckckckck!
- fire, burned stuff, and emissions control
- 1986 Porshe 944 Oil Pressure Light
- Thinking about buying...
- Buying a 86' 944
- General Info
- fuel pump wires
- Upgrade to 968 6 speed Tranmission
- Cooling fans won't turn off!
- sunroof removal
- engine wont keep running
- 944 fuel filter
- Screws for Fans?
- F/S Porche
- F/S 1981 924 turbo
- Fuel Problem
- vr6 into a 944
- 83 Porsche motor oil leak, were to look?
- Will Turbo Axles Fit On Late 86 944???
- loose shifter?
- Just bought 944
- Help.... IT WONT START! ('88 NA)
- 2.5 crank shaft for sale
- Top Gear (tv show) w/ 944
- Dash light Change?!?!?
- 924 and 944 Transaxil
- Shopping: 924 vs. 944
- balance shaft
- 944 starts then stalls never figure this one out
- Right Rear Fender
- 944 to 951 can it be done?
- New door
- 944 s mods???
- prepping 924S for spec 944
- Cold air intake?
- 944 NA Auto
- Engine swap.
