Opel/Vauxhall
> Astra/Astra Coupe/Kadett
View Full Version :
TS/Mk4/G Astra convertible roof latch motor fix
Stage 1 ECU Remap
Aftermarket Head Unit replacing MyLink 7”
Car won't start, suspecting there is an o-ring leak, I need more input.
Astra J VXR OEM Style Head Unit
Flashing engine management light
Random cloud of smoke
Opel Astra H 1.9 CDTI RPM Does what it wants
Can't shift into gear (after clutch replacement) when engine is either turned off or hasn't been going for long enough!
Astra 2011 Sri PHONE function
Opel Astra.
Unsual alternator problem
Top gear's star in a reasonably priced car opel astra up for sale
Astra
Problem with gearbox?
Opel astra k what do you think about?
best way to remove an astra ignition barrel
Opel astra H engine light
AstraVan 1.7 CDTI Parked for 1 year - Wont Start
2004 holden astra ts
Why won't my Astra start?
08' Saturn Astra (yes American)
White smoke - safe to drive to mechanic?
Astra mk5 Conv. Roof Module
Opel Astra GTC 3rd cylinder out of order. (LPG)
non - start mk3
Opel Astra H Vs. Opel Atra G
02 Astra manual trans. problems to get 1st gear
indcator fault.
Whining noise when accelerating
will not fire sometimes
coolant gauge inop.
Astra on small rpm has no power
V6 engine for 1997 Holden Astra
New lad!!!
astra speaker fault.
Vauxhall Astra 1.6 16v Petrol will not fire
vibration noise going up hill.
running water on windows.
Smell Diesel Odour 1.7Dti Astra 2001 114.000 miles
OPEL badges needed!
Indicator Problem
1.6 astra sxi
gear issues with automatic Asta
Mk 4 astra 1.4 tick over too fast when hot
vauxall astra clutch problems
astra 2003 convertible, car wont open
Astra Fuel Economy
Astra 2.0 Sport - Stalling problem
Big Problem Opel Astra1200cc
Wiper fault?
Injector valve 1 low voltage c20xe
Astra:roadtest in China!~
Where can i find a manual for a fuel injection ECU ...?
Revving problem
Astra 1.7TD not starting
Vibration in my Astra Estate in 2nd and 3rd gears
Astra time display....how to set it?
ASTRA H Temperature Dispaly
problems with 1995 astra
Awful problem with opel astra
Blaupunkt Acapulco MP52 - Opel Astra interface
astra not running correctly
Vauxhall Astra Estate 1.7 Dti
astra td wont start?need advise.
astra water in oil
help me please
lost performacne, burning smell
af13
headlights
1995 Vauxhall Astra 1.4 8v - OIL??
1988 astra hatch transplant
Astra radio recoding
Opel astra DTM
HELP : Badges!!!!
Jerking Problems
vauxhall astra club 1.6 auto
Astra seat belts during a crash
turbo
exhaust ideas?
opel astra olympic 1.4
astra headlight
mk3 isuzu 17TD needs help!
Vauxhall Astra Radio Wiring Diagram
Indicators on Astra 1.7cdti 54 plate
astra 1.7 turbo diesel
Astra external temp sensor location L reg
1995 Vauxhall astra radio wiring diagram
Astra Turbo diesel 2.0 (UK)
ecu does not want to release errors!!
2002/2001 Astra Specs etc
Trouble with CIM Unit (Astra H)
Idle or not
Vauxhall Astra MK3 1998 Vibration noise from gear stick assembly
1999 Astra Wiring Diagram?
need help urgently!
Opel/vauxhall Astra Convertible
2000 Astra 1.6i Engine Number Location??
Installing a bluetooth car kit into Astra.
Astra 1996 GSI seat belt problems
Unichip
Astra Emission Control Warning Light
Astra getting steamy - too much moisture?
turbo intercooler?
1993 vauxhall astra mk3 radio wiring diagram
1993 Opel Astra CD (2 Litre)
Car recall and refund
astra lacking power
Astra Mk3 Speakers
Astra Performance parts
Some help on a swamp
Fuel or electrical
Refurbish
Cutting out
petrol and oil leak
2004 Astra
Astra Australia
astra styling
test
Can't believe this is the 1st Post!
