View Full Version : Aurora
Pages :
[ 1]
2 3 4 5 6 7 8 9 10 11 12 13
- 98 Aurora Electrical (Sentinel?) issue
- Transmission fluid leak fixed.
- Ground Locations 1995 Olds Aurora
- Having a starting problem.
- Oil cooler lines
- Power window and door lock passenger side
- 95 olds instument panel
- 95 Aurora transmission slipping
- 2001 aurora 3.5 h motor head bolts striped block threads
- Oldsmobile Forum: 2001 3.5 V6 wont turn over
- 1996 4.0 wont rev past 1500RPM at a loss
- 1995 evap emission harness
- Boggs down
- Radio died
- engine bogs down and dies.... at a loss
- 02 Aurora Neutral safety switch
- '98 Aurora Brakes
- oil filter adapter
- A/c compressor
- 2002 3.5 crankshaft position sensor
- 2001 3.5 Trouble Starting
- 95 Aurora slams into reverse & more
- What is the black box called under my 98 oldsmobile aurora drivers seat. How do i get it open?
- 98 aurora
- hvac fuse
- low/high oil pressure
- Door electrical issues - Was: Whats up with that?
- crankshaft position sensors
- need 95 aurora frnt splsh grd underneath front of car
- 95 Aurora fuel shut
- 01 - 3.5L - Oil in Coolant
- 01 - 3.5L - Coolant Heater Line Replacement
- 98 with climate issues
- 18 inch rims for 1999 aurora
- air intake
- Karlyn plug wires?
- P0300,Random Multi. Misfire Code HELP
- 2002 3.5L Aurora High Oil Pressure and Oil Leak
- Car shudders in wet weather
- small coolant leak on drivers side, 3.5L
- heater goes on and off randomly
- 02 Aurora PO420 code
- water in the OBD I
- Air bag conversion, anyone done it?
- Battery not charging
- 95 Aurora Dash lights out
- Door handle problem
- knock sensor
- Speedo died...
- Car Dies in Wet Weather
- Car Audio
- 2001 Aurora rear brakes
- ABS brake lights intermittedly comes on.
- aurora fuel pump retaining ring problem
- harmonic balancer!!! need help please
- 95 AURORA wheel bearing???
- 95 obd1
- P0442 code
- Cam Position Sensor
- Air Condition problem:
- Rear defrost strange problem
- 1997 Aurora Electrical Trouble
- 01 Aurora wont start,electrical problem
- 1998 aurora hvac problem
- steering column
- 95 Aurora DS Door Switch
- 1996 Transmission in 1995 Aurora
- 95 Aurora Oil Pressure Readings
- 95 Aurora
- Trying to get the 95 back on the road
- warm air-conditioning drivers side
- Refrigerant lines cold, air warm though
- Aurora Computer mod/upgrade?
- drl and lcm questions
- 2001 Aurora all windows mirrors and locks
- 97 Aurora car immobilized
- sputtering and coughing
- 1997olds aurora engine swap
- hard shift to reverse
- Head gaskit
- 96 Aurora Explosion
- 98 Aurora for sale
- 2001 Aurora SES light question
- power windows dont work
- 2001 Aurora with a few issues
- air conditioning
- 2001 Rear suspension problem
- Charging system-95 aurora
- 96 aurora pos
- Service Stability System questions
- Air Shocks - Pump
- aurora
- Electrical/Lighting Issues?? HELP
- heater problems
- overheating
- 98 Olds Aurora battery change, but heard auroras are notorious for bad alternators
- 1997 Olds Aurora oil pan removal
- 99 aurora information center help
- Please Help
- Valet key
- intake manifold problem
- 1995 alternator spacer/mt.bracket
- 95 Aurora Rough Running
- Video of erratic temperature gauge tell me what's happening ***video***
- Bad Multi-function switch or bad Module???
- Flashing Parking lights when key is off
- Gas Tank for 97 Aurora
- my Tach just stopped working ! help !
- Question on Grounding
- AC problem
- Parking lights stays on(solved)
- 1999 Aurora ignition off & headlamps flicker
- alot of new problems
- 95 trans mount
- dsplk
- air conditioning
- 95 altenator problem
- Vibration Under Acceleration
- Installing blower motor on 2001
- Oil Pan Crack
- 96 Aurora Driver Door Lock Asy
- 2001 aurora blower motor
- RPM's Increasing
- transmision leak
- 95 Aurora ECM/Prom for Trans Swap
- power seat
- jerking ~40 MPH 98
- 95 trans info
- headlights..please help!!!
- 95- air shocks
- 95 aurora runs like crap.
- 96 Aurora Issues
- got a new problem
- 95 Aurora Fuel Problem?
- please help!
- 2001 aurora passenger locks windows mirror
- Mirror Wiring Schematic
- trunk release button
- hard starting sometimes!
- Hesitation and rough idle - sometimes
- 95 Aurora Strut and Shock Recommendation Needed
- Inner Tie Rods
- Stock muffler pipe size?
- 1998 Aurora 4.0 W/4T80E No Spark! Please Help
- P0300 Random misfire code. 2001 Olds Aurora 4.0
- Exhaust tips salvageable when muffler change?
- 1997 door actuators?
- Flasher module for turn signal.
- 97 aurora can't open front doors from the outside
- 98 Old Aurora idles 500 over while driving? Emission Control?
- 95 Idle pulley
- Radio wont shut off when car shuts off and door opens
- vibration in steering wheel
- sensor location
- Alternator bench testing procedures 95 aurora
- Driver side wiring harness removal....
- misfire and backfire underhood
- 2001 Aurora heated seat problem
- '01 Aurora Headlights
- 95 overheated
- 96 olds aurora cant remove idle pulley
- changing oil filter on a 2001 Aurora 3.5 V6
- 96, I heard a pop under the hood & my brakes stopped working
- So many problems, so little money, no repairman !
- 1997 Olds Aurora Gear Shift Light
- "95 Aurora
- aurora not startin cold very easy
- Instrument panel, DIC, climate control quit working
- 3.5 Aurora Low Pressure error messege
- Overheat A/C not on error
- Coolant leak over transmission
- Gas shocks, or other recommendations? - 99
- 97 aurora wont start
- Improve mileage
- Low Coolant Sensor
- Leak in Fuel Line
- aftermarket radio
- Remote entry
- New To Forum and Aurora
- 97 gas tank
- Wheel bearing I think (kmohr3)?
- interior lights
- horn does not work
- '97 belt tensioner arm replacement???
- radiator replacement tank
- Shake, Rattle, and Stall....
- 97 aurora help with electrical
- changing rear fog light
- brakes
- Help my door controls don't work
- My 2001 Aurora is getting tired
- 96 v8 stalls rough idle
- location sensor oldmobile
- water on driver side floor ......
- 2002 Oldsmobile Aurora Rear Door Panel Removal - HELP
- Instrument Cluster Dead in 2001 Aurora
- aurora 4t80e transmission problem please help
- odd transmission issue
- 2001 hole pattern
- 95 'chugging' like its running out o'gas?
- 99 aurora front doors
- 99 aurora light switch problem
- 2001 4.0 random misfire code
- 1998 Aurora climate control fan issue
- Aurora upgrades needed.
- 95 Olds BROKEN MOTOR MOUNT MAYBE????
- 96 aurora oxygen sensors?
- 1995 aurora Questions About fan relays. cooling system etc
- 2000 Aurora 3.5L Rod cap torque specs
- Alternator not charging, but no light
- engine diagnostic codes please help
- 2001 Aurora problems burning out lights.
- Aurora, 2001, swap 3.5l for 4.0?
- 2001 Aurora 3.5L Smoking
- air pump fuse keeps blowing
- front end noise
- retieving trouble codes
- Late ignition fire
- Help Insalling Rear Brake Pads
- hot outside , not cold inside
- Can a bad plastic coolant recovery tank cause overheating ??
- 1996 aurora transmission trouble!!!
- 95 Aurora died, looking for advise?
- fuel pressure
- Another Power Seat Problem!!
- 2001 Aurora A/C compressor won't kick in
- '95 aurora dash bulb replacement?
- 95 old aurora steering wheel controls inoperable
- A/C Question
- Please Help!! Smoke comming From the Dash
- Freeze plug problem
- Help P1139??
- Egr Valve
- Flush and Fill or Back Flush ?
- new fuel pump
- 255/45/18 tires on a 2nd Generation?
- 2002 Aurora 4.0 trans lok problem
- Changing alternator on 98 aurora....
- 95 Aurora Valves
- heater door actuator
- Need new stud, but confused...
- 99 aurora a/c not cooling
- Phantom cooling leak
- Sunroof on 1999 AURORA not working
- AC not working on driver side 1999 Aurora
- 1999 Speed sensor problem
- 95-only fuel rail/return line recall info
- High Idle
- Tach problem
- Replacing fuel pressure regulator
