View Full Version : MX-5/ Miata
- 90 miata battery overheating
- Faulty OBD 2 port
- How expensive is it to convert an 2001 1.8 MX5 to Euro 5?
- MX-5 Upgrades
- putting a 99 miata motor into a 97
- Warped Flywheel?
- Fumes coming in with top up...??? Is that normal
- Re programming transponder keys
- 2016 Mazda MX-5 Miata gets 25 percent fuel economy boost
- 2016 Mazda MX-5 Miata will start at $25,735
- Instant Mobility System
- Grinding noise: drive axle, brakes, other?
- 2002 miata no spark
- 268HP Turbocharge Mazda MX-5 by BBR
- Mazda MX-5 Wants To Be A BMW Z9 Concept
- 1992 Mx-5 ticking while driving
- Oil leak, I know it's common
- brake and tire wear problems--related?
- tires for 09 mx5
- 2000 Mazda Miata Engine Shuts Down
- Engine swap questions
- miata ecm not responding
- 2000 MX-5: Random misfires and P0420 code
- Read before posting
- premacy clutch problem scraping sound
- I'm considering buying an 06 or up Miata, need advice.
- Mazda MX-5 Superlight
- Average gas mileage?
- kia engine swap???
- 'o6 Headlites
- SAS (air bag controler)
- Computer replacement?
- 90 top adjustment
- Traction control on the MX-5?
- Miata NB vs. 350z - Opinions needed
- 2000 Miata P0420 questions
- Mazda Miata '96 convertible top leak
- 04 Miata Rear Brake Pads - HELP!
- Waqter on passenger side
- Need help with a 1996 Miata please!
- Custom fit CAR COVER for 99-05
- 2004 mazdaspeed owners manual
- FS:1st gen Miata in Norcal 85k miles
- Miata with Vette motor video! Wicked fast!!!!
- Miata Performance Chip
- 2001 Miata Suddenly Will Not Start
- mx5
- Just joined the Miata gang
- keyless entry
- Exterior/Dash lights flicker when car is on
- How can I make my Miata faster?!?
- Vaiable valve timing control sensor or camshaft position sensor?
- Disabling air bag... is it really this easy?
- Miata insurance for 16 year old.
- front end damage
- Thinking about gettin miata..
- Need Parts 91' Miata!!
- Watery OIL
- cam timing
- Engine-transmission gasket problems - knowledge needed
- 95 mx-5,cel says o2 no output,and ac question?
- 91 auto = junk??
- having trouble
- Adding remote trunk release to a 1990 Miata
- rough idle at low rpm
- Immobilizer problem?
- Switch under steering column..
- Sway Bar Link question
- Red Hartop For Sale
- new TONY MIATA movie!!!
- Intermittant start...
- Fried Alternator
- Transmission service
- tuning an mx-5
- Potential 2001 coil pack
- snow tires for mx-5
- '93 Miata with 150k. What should be the right price?
- tips or pictures on the egr valve..
- 96 Kia and The 96 Miata engine bp05
- Vapor Purge system
- miata bashing... why?
- Interested in purchasing a Miata, looking for advice.
- 2000 Miata p0300 code
- 92 Miata A/C recharge
- Installing a new soft-top
- Supercharge 1999 w/65,xxx miles??
- Need Clutch Help
- Looking for a Miata with blown motor
- Aftermarket EBRAKE HANDLE for 2007 MX-5
- Oil Pump?
- z31 or miata
- Miata Battery
- Fog Lights?
- Mazda National Day – Orlando, Fl – Jul/28/2007
- FRUSTRATED! 2001 Miata Dies while driving or Won't Start
- Newbie looking at a Miata !
- Weather stripping
- miata engine the same as a geo storms?
- 1991 Automatic Tran Change?
- Power options
- moisture getting inside
- FS: 1993 Mazda Miata fully built RWD TURBO hardtop roadster
- Miata!?
- Need a miata door?
- Best year
- towung
- mx5 straight six
- Considering a miata...
- WANTED -White Miata MX-5 HARDTOP
- 90 mazda miata, fuel pump
- hardtop and Rollbar installs
- mx5 not holding high revs ?
- late 80's early 90's sports car preference?
- 2003 350Z roadster or MX5 hardtop convertible
- fuel in cooling system
- So what do you guys think of the new MX5 "thrilling videos???
- MX-5 Zombie
- Motor swap!
- Miata's reliability.
- Speedometer / Gauges
- Codes p0300 p0302 p0442 p0455
- hot to mod
- flashing Air Bag light on the dash
- Mazda price
- 1999 Miata rough idle
- For Sale: 90 Miata $1800
- Master cylinder rebuild
- No Tail or Dash lights
- 90 miata performance in the ditch
- NewB clutch question
- 2001 vvt motor
- miata p1135 oxygen sensor problem
- quick question.
- 165K mi/$2000 Good, Bad??
- Idle Probs
- Fuel pump or anti-theft?
- looking at buying a 92
- Code P0420
- getting one
- 1995 Miata for Sale in Southbay, CA
- literature
- best platform: miata or mr-2
- Miata top and back window
- FS: 1993 mazda Miata fully built up for street fun.
- Roadster Emblem From Japan
- Headlight Help
- I guess I bought a Miata
- Headrest Speakers
- DIY Custom Steering Wheel
- Is My Car Sick??
- Miata "Assy. Fan from 01-99"
- Getting a miata, quick ?
- Ok, this is just annoying...
- 2006 Miata...WOW
- Did I have a souped up miata?
- O2 Sensor help
- Leg room in a Miata?
- Top for '92
- price/bluebook
- 1990 Miata Engine
- Solstice outsells Miata!!
- 1992 miata milage
- 90-97 Miata Convertible Top w/zippered Plastic Window NEW!! $225.00
- Tokico Shock Question
- Which is the best deal for a miata?
- Fuel pressue
- Cartech turbo kit
- Fitting 99+ Intakes on 94-97
- Miata mileage expectancy
- car shows
- Heater Core
- Mazdaspeed Tire Pressure Loss
- Best tires for Miata?
- Carfax for 99 Miata
- Performance chip?
- Maxamum potential for the Miata
- Engine rattle/front of engine @ idle
- Wanted: Hardtop
- Rough idle
- 1999 MX-5 hard top for sale
- for all your Miata questions/issues, no matter how big/small/stupid
- eunos roadster knocking after new wheel and tyre change
- 99+ solid lifter size
- WTB:Moss Low-Pro Headlight cornversion
- 1996 Miata keyless remote programming
- planetmiata bad experience
- Cold Air intake in Winter?
- Miata wheel bold pattern
- engine swap part 2
- Mazdaspeed Miata vs. S2000
- Miata Cold Air Intake Custom Fabrication
- Mx-5 Overheating Issue
- supercharger or turbo?
- How Hot Can It Get In There
- 13b tt engine swap for sale complete and more
- 13b T Swap
- Need advice on Miata
- carfax help
- 2003 Miata Instrument Panel Problems -- Please Help
- 92 to 95 help please
- D-spec tie-rods????????????
- Headlight Issue
- Shop Manual
- Gauges
- Jumpy Speedometer
- Carbon Fiber
- Want to buy M1 Miata
- 91 Miata running rough at idle.
- Manual to automatic conversion
- Miata 1999
- 1st gen center console
- need unrestricted air flow for new intake
- Tec 3 question
- 1995 Miata CEL never on
- stinky exhaust
- car dont start no rpm show on the tach when turning over
- what's eunos
- "Lotus" Style Eunos Badges
- whump - whump
- check engine light
- engine swaps
- Parting out 90 Miata
- V-6 Mx-5
- coil-overs
- Zero Clearance
- NB & NC Miata? In So Cal? Lemme know.
- MX-5 (don't call it a Miata)
- Haynes manual
- caliper piston
- crankshaft replacement???
- Idle Air Sensor???
- Overheating!!!!!!
- Help!!! Noob with clutch problem
- Can't get into trunk
- MSD Ignition?
- lookin for 1st gen front bumper
- Anyone wanna buy a Supercharged Miata in NJ??
- looking for CHEAP hardtop
- Hi ,need help with supercharged mx5
- Best Gas Octane
- Gas
- big problem need help
- swap or boost?
- Please help me find a 94-95 1.8 miata motor
- 2006 miata
- Getting a Miata to Run 13's
- Serious exhaust questions
- miata newbie...
