View Full Version : Cherokee
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. 2.5 engine swap?
  2. 1990 cherokee
  3. 1990 cherokee door seals
  4. rough idle all of a sudden
  5. 1984 cherokee 2.5 vaccum diagram
  6. 1988 Jeep Cherokee high idle
  7. 1987 jeep cherokee laredo
  8. '94 Jeep Cherokee tire problem...
  9. Starting ??????????
  10. Plug wires????????
  11. new xj, old issues
  12. 89 Cherokee Erratic Idle
  13. Front drivers window "acts" stuck
  14. An Interesting Conundrum...
  15. HOW DO YOU ADUST a TPS Throttle position sensor?
  16. Jeep Cherokee not shifting properly
  17. Asking for an opinion....
  18. Exhaust system
  19. Site Search Turned Up Little !
  20. NSS cleaning
  21. Door mounting
  22. Please Help! 89 Jeep Wont Start! Cold weather
  23. changing back to full roof rack
  24. 94 Jeep Cherokee Overheating!
  25. 89 jeep cherokee
  26. Haha!! Lol!
  27. wipers won't park in normal position
  28. 1996 cherokee charging system
  29. Clutch Fluid???
  30. 96 Cherokee radio + lighting problem
  31. How to test my 4x4
  32. fluids
  33. fuel pump timer?
  34. stalls after 10 minutes of driving
  35. any ideas on getting a cheap windshield?
  36. Getting to the cps?????
  37. Exhaust Fumes in Passenger Compartment
  38. Bigger Tires
  39. changing injectors
  40. 1990 Cherokee 4.0L Auto Not starting
  41. oil smells like gas
  42. 92 cherokee speedo
  43. 92 Cherokee 4.0 speedo no work
  44. 91 cherokee 4.0 Intermittent stumble when cold
  45. 97 Jeep Cherokee/starts sometimes/other times no.
  46. What are they thinking???
  47. Rattle from oil pan area
  48. Oil Pressure or Indicator problem?
  49. Bad censor????
  50. ? on 98 Cherokee Cooling System
  51. 4 Whell Drive Issues????
  52. Location Gas Pump Relay 88 Cherokee
  53. Bushwacker Fender Flares?
  54. O2 Sensor or MAP Sensor
  55. High Idle Problem
  56. 1996 Jeep CHerokee
  57. Idiot Lights
  58. 01 Cherokee serpentine belt squeal
  59. Cruise Control Problems 95 Jeep Cherokee
  60. Jeep Total..changing threads
  61. Is it possible?
  62. Shifting Problems 4wd
  63. 92 cherokee clutch
  64. 1987 Jeep Cherokee Chief starting problem
  65. 2000 Cherokee No Fan For Heat
  66. 2001 Turn Signal Issues
  67. 1994 Cherokee radio fuse?
  68. Shock advice
  69. Tapping when cold, stops suddenly when engine is warm
  70. 1996 Cherokee Xj a/c condenser
  71. 1996 Cherokee Xj transmission lines
  72. New AC Compressor
  73. 1991 No brake lights!?!?! Confused
  74. disabled mom needs QUICK advice!! PLEASE?
  75. Where are the engine lift brackets?
  76. Transmission Problems please help!
  77. Can i go higher??
  78. Sun visors
  79. tcc stuck locked!!! help
  80. 1987 Cherokee Brakes deep concern
  81. pics of my 99 xj
  82. Changing Windshield Washer Pumps on 97 Cherokee
  83. Timing Belt ?
  84. 1993 jeep cherokee sport issue
  85. Stalling when drives slow !!
  86. Help Engine Knock 4.0L
  87. Replaced the Fuel Filter and the Stalling is way worse
  88. How much Lift???????
  89. 96 Cherokee Country Dash lights
  90. humming noise coming from the back of my 89 cherokee
  91. What wheels will fit?
  92. 89 Cherokee Pioneer Cooling System conversion
  93. 95 jeep cherokee 4.0
  94. 1992 Cherokee Laredo
  95. Jeep tranny acting up
  96. Need Help. 89 Cherokee Overheated now Loud Clacking noise when Accelerating
  97. '96 with '98 trans, How to???
  98. jeep barely stops
  99. 254,914 miles
  100. Jeep 92 - just won't start
  101. Ignition key wont turn plus...
  102. 99 Jeep Cherokee Runs Rough When Cold
  103. 150,000 mile inspection
  104. Paint
  105. 99 cherokee sport with difficult engine start
  106. question on differential fluid exchange
  107. No BU or running lights or
  108. oil in my air filter
  109. Dome Light
  110. Problem with idling
  111. Front axles seals on '86 Cherokee
  112. i have 4 problems my jeep i need advice
  113. 1998 cherokee 4.0 missing at idel no stall
  114. 1998 cherokee 4.0 missing at idel no stall
  115. Overheating?
  116. Lift For 1987 Cherokee????????
  117. need some serious help-lift coils
  118. Loose gas gauge
  119. np231 swap for np242?
  120. Keyless entry
  121. Door panels
  122. How to change headlight switch
  123. Popping sound from front of XJ
  124. backspacing??
  125. 98 cherokee stumbling and going dead (cleaned NSS)
  126. Popping in front steering
  127. Comanche
  128. Pop When Turning Gone !
  129. 2001 Jeep Cherokee speedometer acting strange
  130. 304 help
  131. Lifting the steering column
  132. cherokee high rpm knock- only in acceleration
  133. Power steering issues
  134. Clutch Problems
  135. 5mpg
  136. 1988 Cherokee Pioneer Steering Box Q's...
  137. No 4x4
  138. need help with replacing radiator this weekend
  139. Front Loose
  140. '87 cherokee start stall problem
  141. 88 Cherokee ex manifold bolt
  142. 96 cherokee starts only w/ gas
  143. 350 in an xj
  144. Won't idle
  145. A/C blower motor intermittant
  146. Good code reader/scan Tool
  147. Wiring for a trailer
  148. front breaks screwed?
  149. 89 wagoneer limited problems
  150. 2000 Jeep Cherokee OVERHEATING HELP!!
  151. 200 Cherokee Sport Amber Engine Light
  152. Engine not starting, acts like dead battery
  153. head lights
  154. 89 cherokee wont start
  155. please help
  156. Interior lights stay on
  157. 87 jeep no start?!?
  158. bearings?
  159. 90 xj lift
  160. 2001 Cherokee Engine Light advice
  161. Noobz Question
  162. Need immediate help with white smoke/antifreeze leak
  163. Blower/HVAC problems
  164. Check engine light - an 01 Jeep Cherokee
  165. Gas Gauge on a 1992 cherokee
  166. Proud Owner of a 1989 Jeep Cherokee Sport
  167. has anyone had any experience with Auto RX Engine Cleaner
  168. NO START (no bus)
  169. Need help with 89 wiring
  170. Checking trouble codes???
  171. 88 Jeep Cherokee Vacuum Diagram.
  172. Newbie Needs Electrical Help
  173. Knock turning left
  174. Overhead console
  175. Heat Shield and Check Engine
  176. Anyone know about CSF Radiators from DPG Off Road?
  177. My 4 wheel drive wont engage. Any ideas?
  178. 1999 Jeep Cherokee Won't Start
  179. 93 Jeep Cherokee Idler Pulley Help!!!
  180. Coolant temperature question
  181. coolant spilling out cap
  182. steering loose
  183. Horrendous clacking noise while braking
  184. Dented exhaust pipe connecting to manifold
  185. Jeep towing
  186. Can almost start, squealling
  187. 1988 Jeep cherekee runs only iwhen the key is in the start position.
  188. Electric Fan 90 jeep
  189. No power to Radio and cigar lighter
  190. Wierd knock in rear
  191. 91 Sport blowing fuse
  192. Help with my Stick-o-matic
  193. 97 cherokee sport oxygen sensor voltage
  194. Does anyone else sound like a diesel?
  195. More power!
  196. Hot jeep
  197. Remote keyless entry
  198. Hills With 2000 Jeep Cherokee Sport
  199. OK. Now I've got some electrical gremlins...
  200. '99 Cherokee Stalls..
  201. Rear window issues
  202. Reverse Transmission Issue
  203. Oil gauge jumps when decelerating(1993 Grand Cherokee)
  204. 1993 Grand Cherokee 5.2L V8 Turbonater
  205. 86 Chrokee Running Problems
  206. shifting
  207. shifting problems
  208. 1999 Jeep Cherokee Loredo
  209. 91 cherokee knocking at idle
  210. 1991 cherokee transfer case problem
  211. 01 cherokee knocking
  212. overheating problem
  213. Leak under dash
  214. 1999 Jeep Cherokee turns over "very slow", shuts off when it idles
  215. Running Hot STILL AHHH
  216. Procedure for shifting into Low Four Wheel Drive
  217. Hypertech - Hypertech Power Programmer III
  218. Just Curious Engine Swap Question
  219. Surpentine Belt - Proper installation?
  220. Stalling, Squeeking, Overheating, & A/C
  221. A/C squeels on high - ideas?
  222. interchange engine
  223. help 98 4.0 cranks, no start
  224. 13 MPG (how bout you?)
  225. Stalling of Jeep Cherokee
  226. 1999 AC / Hesitation while accelerating
  227. 1999 Jeep cherokee air conditioning stops working
  228. Manual driver side mirror replacement (with remote)
  229. ignition switch red wire hot with blower on
  230. NO Headlights
  231. Jeep XJ Brake Adjustment
  232. 2001 Jeep Cherokee Spark Plugs
  233. Turn signal switch replacement
  234. 2001 Dome light bulb replacement
  235. Master Cylinder???
  236. how to lower jeepy
  237. Comanche 1988 bypass
  238. Can't turn ignition key on 90 Cherokee
  239. shimmy when i start to accelerate
  240. Air Conditioner Pricing Question
  241. 99 Cherokee with no Brake Lights
  242. engine computer changeout
  243. 1995 herokee country fuel injector control circuit problem
  244. 2001 Cherokee starting issues
  245. Electrical gremlins
  246. 99 Cherokee Rotors
  247. Cherokee no start
  248. No Reverse transmission
  249. Cherokee speedometer stops working
  250. Pinstriping Decal Kits?
