View Full Version : 1st Gen 95-99
- Loose clutch fork?
- 98 neon Won't idle
- 98 Neon Rad fans only work with A/C turned on; overheating
- Disable Air bag
- 96 DOHC no compression!!!!!!
- timing belt broken
- Hard to get into 2nd gear-MTX
- 95' Dodge Neon problems
- Center Console Removal
- Chirping PS Pulley
- auto trans kick down ???
- Transmission problem?
- oil light
- gas cap door
- 95 neon r&r stering column, Broken locking ignition
- 97 SOHC Neon Belt squeal
- P0140 rear O2 sensor stays at center
- 5W20 Oil
- 1995 5-speed transmission
- 1996 neon need help fast having problems installing trasnmission
- Gasket - exhaust manifold to head
- Removing cylinder head
- auto transmission heads up
- Help! Fuel Gauge wtf?
- how to change belts 99 neon sohc with ac
- cam sensor for 99 plymouth neon 5 speed
- 1997 neon ignition/timing issues
- Aftermarket mpg booster
- 97 Highline horrible mileage
- 99 neon no fire
- 97 neon, New AC with challenge...advice
- 1st GEN NEON, FUEL PUMP FUSE/RELAYS PROBS
- 98 dodge neon starting problem battery light on
- 1996 neon problem running/driving
- Crank pulley install tips
- Motor Mounts or Bobble Strut
- 97 Neon DOHC Engien problem
- Good online site to buy timing belt cover
- misfire!!! please help!
- Coolant Leak
- Block heater install 97 neon
- Neon Part-Out, Parts for Sale Cheap!!!
- 98 neon with 3+ amp battery drain: AC Clutch??
- Neon Compression test results, your diagnosis please????
- Speaker wire replacement
- 98 Neon A/C Issue
- 1995 neon
- 97 Neon Head Gasket
- Console dies
- 1996 dodge neon trys to stall
- 96 neon having electrical issues i think
- 96 neon trying to stall while driving
- 1996 dodge neon wont shut off with key
- neon automatic shift stuck in park
- 99 Dodge Neon Belt squeaking and squealing
- wandering belt
- 98 Sport Auto Transmission Overheats
- What is that sound and why does it jerk?
- Headlight Seals
- 99 Neon Sport not starting
- stuck shifter
- 1996 Stuttering after spark plug change
- 98 NEON 2.0 DOHC Ruff Idle After Timing Belt Change
- '99 Neon - key snapped off in ignition
- running rough
- 99 neon crazy hesitation when I turn right?!?!
- alternator removal ????
- 96 door panel
- power problems
- shifter knob
- Is it the pump or relay
- 96 Neon Gas Tank Support Question
- 95 Neon blower housing
- 96 neon poor accleration.
- Gurgling Sound
- 1996 over head light
- help 98 neon no spark
- '99 Neon Highline Stereo Problem
- waiting for triple a right now
- 1998 Neon fuel pump not working, air bags were deployed in accident
- 99 Neon Owners Manual
- Oil Dipstick Tube
- 98 dodge wont start
- PCM question
- huge oil leak
- 98 Neon No Start
- Transmission won't shift
- 99 dodge neon probs
- '99 Neon timing belt or chain?
- 98 Neon oil leak 2.0
- 98 neon overheating and leaking oil
- 99 neon with no spark
- 2 problems need help with both!!
- Key wont turn in ignition but makes the beeping noise
- clutch ajustment in 95 neon
- trans swap
- boost ideas
- Want things done do them yourself! (story)
- 95 sohc revs between shifts
- 98 neon will not turn over
- any suggestions? this will take a genius!!
- Timing belt alignment marks
- 1998 Neon Rough Idle/trouble code p172
- another 95 neon problem...
- Many issues with 95 Neon. Please Help
- 97 Dodge Neon engine reving
- Back-up light help
- No compression after cylinder head service
- 98 dodge neon - squealing
- 96 neon cruise control
- new project need advice
- Performance parts suggestions
- 95 Neon SOHC Wont Start, Help!!!
- Omfg!!! Help!!! I hate champion plugs!!
- Rear Speaker Removal???
- 96 neon woulnt start
- Fuel Pump Issue. HELP!
- Seafoam treatment
- MAP sensor
- car finally gave codes while running rough
- Oil drain plug size - '99 Neon
- 96 neon tranny problem
- keeps blowing 20a fuel fuse
- 98 Neon Problem-Rad.
- 98 Neon
- Transmission troubles
- Possible bad PCM?
- performance
- Odd Speedo Problem
- 97 Neon DOHC Oil pressure-Relief valve or bearings??
- 97 engine swap wont start
- adjusatble cam gear
- 1997 2.0 into a 1996 motor swap
- 1997 Neon Stick shift stuck
- sooo
- pics of newly painted valve cover
- battery light never goes off
- Ignition coil help
- 97 starter probs
- cam angle sensor
- 95 neon caliper lockedup
- running rough with engine light on
- Odd engine shake when rad fan is on.
- Gen 2 to gen 1 engine swap
- DOHC in Highline?
- 96 neon srt swap
- 1997 DOHC neon HARDCORE over-heating!!!
- gas/oil in with plugs after change??? help
- My Darn Radio
- 95 neon pops fuel pump fuse every time
- SR20DET In A Neon
- Flashing check engine light. Idles ROUGH!
- 99 belt slipping
- Seems when i'm sriving im in neutral, RPM shoots up but car goes nowere.
- ignition lock cylinder
- '98 Dodge Neon Sport with back fire
- 96 Neon
- speedo problems
- Code 43 (Misfire) and Ground problems
- How Hard Is It To Have A 1ST.SRT-4 Conversion?
- Will A MTX PCM Mess With My ATX Any?
- SRT-4 Gauge Cluster
- SRT-4 Brake System
- Temp guage question
- Bad motor mount cause for transmission slip?
- 98 Plymouth Neon
- 1995 neon runnung rough
- DOHC Head On SOHC Block...
- What Computer System Should I Use?
- 60mm TB (Throttle Body) For My SOHC
- How?
- 1996 Neon, How do I set timing for new belt.
- With All This, How Fast Do You Think...
- What Is A Good Muffler To Use On My SOHC?
- My SOHC Belt Broke (Here's The Story)
- pics of Iceman CAI?
- What Manifold Parts?
- Slave Cylinder
- SRT-4 Pedals
- Crane Cams Are Gone?
- Water In The Trunk?
- Will SRT-4 Shifter Fit In 1ST Gen Neon?
- If I Buy New Valves For My Head, What Should I Get?
- My SOHC Rattle
- My Neon Won't Start (Here's The Story)
- camshaft end play what do i do now????
- 99 Neon sohc wont start
- Tell Me Everything I Need For A 5-SPD Swap
- Rear Windows
- engine mount
- Transmission Help (Slipping)
- Dome light
- Just beginning need info
- Shifter cable adjustment
- 98 backfires when i accelerate
- passing gear lever help.
- need a little info...
- 99 Dodge Neon- Reposted
- Oil leak and Gas leak...
- what the largest rim size on a 1.75" drop?
- 96 neon fuse problem
- 99 Dodge Neon Missing After Multiple Repairs
- Transmission Question
- Spudders at idle Runs fine driving
- 95 neon tail lights blowing fuses
- hard to start rough idle
- When do you need to replace coil pack..?
- please help, 98 neon and maybe a couple answers to idling prob
- 95 Neon Runs for 10-20 mins, Start up after 2 hours ??
- Problem installing timing belt
- Is is possible to check the timing on a 98 neon DOHC?
- blowing fuses
- My Alternator is Toast
- 98 Neon Interior Electrical Problem
- 97 Highline won't go into drive
- 1995 Neon SOHC Error 42
- 98 Neon Starting Failure
- idleing problems
- interior lighting???
- aftermarket gauges
- 95 plymouth neon ignition problem
- No turn signals/blower motor
- well that failed
- Shift linkage
- Plymouth vs Dodge neon??
- 95 Neon Highline won't start???
- Need help
- Inquiring mind
- How to tell if the block is cracked?
- eagle talon cams for neon?
- 95 dohc cams??
- 95 dodge neon
- 1998 EX Serpentine Belt replacement diagram
- High Idle, 1997 Neon
- 95 neon engne swap
- EGR .....Get Bent..... please help
- starting problem with 95 neon
- 95 dodge neon
- 95 Neon Starting problem
- 97 sohc/dohc piston swap
- Speedometer and Gas Gauges Stop Working
- Gas Tank Removal
- Error Code P0743
- missed deer hit ditch airbags deployed
- 97 dodge neon highline/custom/fasst--stumped mechanic--HELP!!!
- installing a turbo and have no idea what im doing
- Neon finally gave up
- thrown rod maybe?
