View Full Version : General Discussions
Pages :
1 [ 2]
3 4 5 6 7 8
- 1998 Sunfire turn signal
- 97 Sunfires DIES AT STOP SIGNS
- 96 Sunfire keeps dieing when driving!
- 2001 pontiac sunfire cranks but wont start
- engine swap
- 1997 Sunfire cranks won't start
- rear signal light replacement
- 2002 sunfire= a/t 4 speed??
- INteresting sound
- sunfire interior
- Just bought a used '99 sunfire
- 1997 sunfire standard engine life
- 99 Sunfire Problems
- Repainting Front Left Fender
- Signal, DRL, headlight possible ground issue???
- Questions about Passlock I
- Adjusters for Sunfire Headlight
- Turn lights "orange" law???
- 1999 sunfire NO high beams
- Tail lights
- dash lights not working
- Problems with sunfire maybe bypass? or ignition?
- 98 sunfire gt engine swap
- Will a 2.4 liter RT4 engine from a neon fit into the 99 sunfire gt?
- 96 sunfire air lock
- Car won't start...
- computer
- Keyless remote programming
- computer port
- power window problem(clunking noise)
- 98 sunfire 2.2 wont start below certain tempature
- 2001 Sunfire questions
- Optional Gauges for 2005 Sunfire
- 1996 Sunfire - sounds like a diesel
- Please help me ID this part..
- Poor gas mileage
- Please help...I don't know how to set my clock...
- 2005 Sunfire...ticking in the A/C...
- quick question please help
- 99 sunfire problems
- sunfire swap
- Speed Sensor-'98 Sunfire GT
- Radio not shutting off when I open my door
- poor pick up
- balance shafts?
- 2000 Sunfire GT - Stiff Gear Shift
- 02' Sunfire...PWR WINDOWS
- Turn signals?
- 95 Sunfire PRNDL indicator not working
- 96 sunfire ETS off and Check engine on
- power steering leak
- 1997 Sunfire - Stalls now no start
- Stock exhaust piping
- 2004 Pontiac Sunfire 2.2 Oil
- '96 Pontiac Sunfire GT runs rough in hot, humid weather
- Engine Light Goes On & Off - Gas Cap? Sensor?
- sunfire? any suggestions please?
- Engine Knocking
- Installed used engine
- Need input... Two used Sunfires
- Bypassing Anti-Theft System
- 98 Sunfire anti theft gas cut off problem
- advice needed on sunfire
- trac off light pontiac sunfire 2001
- Changing stock deck to aftermarket?
- security light question
- P0502 Code
- where is the oil filter on an 04' 2.2
- Air Conditioning Not Cold
- Sunfire 97 2.2 turns but won't start
- 99 sunfire cranks but will not turn over
- removing gear shift nob
- '97 Sunfire - Brakes & Rotors?
- 1998 Pontiac GT Headlights
- 96 sunfire engine knock
- Code 420 and gas smelll
- 1995 Pontiac Sunfire Head replacement
- brake line replacement
- Desparatley need a wiring diagram
- Heater Problems
- Please Help!!
- Fuel pump harness
- '96, anybody ever changeout the coils/Ign. module?
- 96 Sunfire Too lean
- 95 Sunfire transmission trouble
- oil warning light
- Strut mount problem??
- Brakes on 96 sunfire
- EGR valve on 96 Sunfire
- Battery draining and ETS, check engine light
- When should the radiator fan turn on?
- Replacing analog mph guage
- delco loc radio disabling
- coolant problem
- 95 sunfire coolant smell
- Rear defrost not working
- changing altenator
- Trip Odometer Problems 1999 Pontiac Sunfire
- 96 sunfire 2.4L dead
- 1998 2.2 rough running on cold start
- Quad4/Twin Cam/Ecotec owners!!!
- Side Mirrors
- Injector question
- no power to temp sending unit
- Strut or something worse?
- 96 sunfire with a few problems
- How gullible do mechanics think people are..
- I'm New Here.
- 1999 Sunfire headlight bulb repacement
- 2005 Sunfire - Programming Key Fob
- Rear end sagging a lot, with weight in it!
- knocking at bottom of engine...
- 96 Sunfire 2.2L Head Woes
- 2000 2.2 sunfire wont start
- R.I.P. Sunfire
- GT Wheel Bearing ??
- Heater blower motor?
- looking to buy a sunfire
- 96 Gt Brakes ??
- ETS Light ??
- HELP! Sunfire Rough Idle/ Dies, Hard Start
- Please help me diagnose this.
- Oil cooler hose leak
- headlights not coming on
- Stalling
- '99 Sunfire Engine Question
- intermediate steering shaft
- Sunfire Bearing??
- 98 Sunfire Gas Tank Leak
- Sunfire Rotars???
- 98 GT Control Arm???
- 2001 Sunfire se fuel filter
- Bicycle in trunk
- Need manual for settings!
- Cooling fan
- 1996 sunfire is giving me headlight problems
- 1999 Sunfire GT?
- 1999 sunfire stall problem
- 96 Sunfire GT
- brakes and rotors on 2001 sunfire gt
- What a father will do for his daughter...fuel pump change-out..
- 00 2.2L 5Spd. 3 problems
- Stupid question
- 1997 2.4 sunfire starting problem
- 1997 Sunfire gasoline smell any ideas?
- 1999 2.4L Sunfire GT overheating
- How do I replace a 96 sunfire oil pan
- Best Performance Upgrade For 95 Sunfire
- Loose Back End
- Sunfire Convertible - need weatherstripping
- Anyone here have a Carfax account?
- Transmission question?
- Convert OBD 1.5 To Full OBD 2
- Aftermarket car alarm installation
- Whats The Difference...?
- Looking for info
- Sunfire Body Kits
- Rear Speakers
- How To Replace Thermostat?
- 95 sunfire se 2.2L emissions failed
- 2002 sunfire underbody lights
- 96 2.4l ignition problems
- A few problems.. 98 Pontiac Sunfire
- FS 2003 Pontiac Sunfire FS
- fuel injector
- 2002 sunfire
- Sunfire 98 problem after replacing water pump
- 2003 trans fluid change
- odometer
- air condotioning
- 2002 check engine light
- hesitating
- 2.4 engine swap
- something wrong?
- odomter ligth
- BIG exhaust problems!!!!
- 98 Sunfire Coupe - How do you disable airbags
- Key ignition problem.
- F/S: 1998 Pontiac Sunfire
- changing spark plugs on 03
- Sunfire Dash Lights
- washable paint
- dashboard removal
- How do I know when to replace brake pads?
- water pump
- 2001 Starting problem
- projector headlights
- which ECM does a 1995 has
- Help to Test, maintenance or replace Sunfre 2002 Sensor's
- Replacing fuel filter on 2000 Sunfire
- Service Light - 03 Sunfire 2.2L SLX
- Help to Reset or Restart original computer value
- i need some help on a few questions
- Overheating ...now wont start
- '99 Pontiac Sunfire No Brake Lights
- ANyone use SeaFoam?
- Where are the o2 sensors located?
- questions for a friend
- radio hooking up from factory.
- AC mileage & overheat
- 97: New engine or total it?
- keyless entry not working
- Help!!
- Roll call kit
- Set up for supercharger/turbo.
- Need Help 1996 Sunfire GT Auto Tran
- A/C..02'Sunfire
- Need Help on 98 Sunfire alternator wiring
- install a cold air intake on my 97 sunfire
- WTH muffler hook
- power steering return line
- engine knock
- Ground straps on a 2000 Sunfire
- 03 front defrost dont work all air blows in front
- how do you remove the plastic piece
- Radiator Cooling Fan
- Found headlight defect in Sunfire and Cavalier.
- in need of a 2.4L crank
- How Hard is it too...
- Fuel Line Replacement!! Where do I start???
- Please Help Me!!
- 97 2.4 with steering and rad fan issues
- For Sale 2000 Sunfire
- 02 sunfire speaker connections
- Only ETS Stay on
- Interior Painting.
- where is the oil pan on a 99 sunfire
- Suggestion on Fuel smell in cab
- Sunfire help
- '99 Bad starting
- How do I replace a ignition key cylinder?
- Where is the EGR valve on a
- Will a 98 Sunfire interchange with a 97?
- Side Sunfire decal
- Sunfire 2000 Stub Axle Carrier?
- What should I do with this 2000 Sunfire
- rear light
- 1999 Sunfire Headlight For Sale
- Sunfire Head Gasket.....
- 2001 SunRoof Motor..
- 1996 Sunfire won't start. Dash acting
- Lomero
- Sunfire/Cavalier performance parts
- Hubs and Bearings, Eh? EH?!?!
- Hello? anyone on this board?
- Light bulbs/stereo display
- Power window motors 2002 Sunfire
- 97 pont sunfire overheats...HELP
- Question for Hotbug, Engine Swap
- 2003 Sunfire 2.2 start up noise
