Honda
> Prelude
View Full Version :
Prelude
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
automatic transmission fluid level
my 89 prelude doesn't always start.......
Demon Camber!!! Help!!!
Water getting into Trunk
anyone need a Bridgestone Potenza
mysterious hole.....
97+ Lude's what does SH add from BASE?
Idle problem... seems different
Japan Motor
HELP 89' lude possible swaps?
Motor from Japan
Gas pedal getting stuck
Flowmaster NEW SPECS!
looking for a 4th gen options list
88 prelude swap question
5gen suspension
h22a in an 86 lude?
Prelude Speaker System
If you can figure this out you are god to me
more powr no $ were 2 start
is my 86 a worthy prelude?
86 lude body kits please help
header bracket
type s lip
Cruise Control
aftermarket mirrors
leather seats
1997 pricing
Aftermarket clutch?
Swap?
Neebie Question
Where to get Emblem's
? bout broke timing belt 89 SI
Rear Tire wear please help!
how much is my prelude worth?
i need help installing my oem spoiler
Accord/prelude distributor
Ques About 91 Si Prelude Spindles
prelude type s model question
Distributor??
Camber kits??
H22a Prelude Wiring Info
newbie question!
engine light is on and wont idle.
92 prelude crankshaft / pulley repair
In-freakin-credible
lsd
pk2 on 88 lude trouble
Turbo a 92 SI or drop a vtec in?
installing a clutch
Any clue on cost
How to Make ur Lude weigth LESS?
2000 Prelude rpm speeds.
drag tips needed
Jdm?
Celica GTS vs Prelude
93 Prelude Si vs. 93 Prelude vtec
Problem with VTEC
anyone know the code for check engine light
98 Prelude SH 4 sale in Indy In. $9995
carbon fiber side skirts
Clutch H22A & Flywheel
Skid Plate??
6x9 Speakers on 93 Prelude Rear Shelf? Possible?
problem in starting
technical info regarding emissions failure
good deal?
Noise When Shifting
how much would YOU pay?
Has anyone heard of this?
Finally
'91 SI Timing Help Please
Turbocharging my '98 Lude
trunk leaks in 88 lude
H23 engine H22 transmission?
Wings West Question
'87 Prelude Alternator - stuck
no fuel pressure after engine swap
The elusive V6 Lude actually does exist
92 prelude Si vs. 88 Mustang 5.0 GT
1996 Prelude 2.2LS SOHC nonVTECH
swapping transmissions?
tap
88 lude suspension
From Sofast to Soslow
86' prelude question
WTB: Prelude SH Wheels
got 2 ridiculous tickets
SH's harder to mod?
Switching from a CRX to a 97 prelude
prelude got me in trouble
Thermostat problem
'91 Prelude SI 2.05 ECU Identification Help!
Transmission/clutch fluid??
won't reverse
99 f-150vs s2000
possible engine swaps for 89' prelude?
Rims FOR SALE!!!!
Spindle nut size
A few questions
Problem with gauges
Timing, help please
1989 Prelude SI for sale.
Paper racing help please!
89 Prelude Window probs.
Who makes the ABS for the 92 Prelude?
exhaust problem
How bad is insurance?
dumb question
rear wheel drive Prelude
Trans 4 sale
Need new Engine
slow wipers
88 Honda Prelude Timing Belt. . . bad luck
white spark plugs
Cost of Body touch ups??
95 Prelude No Start Condition
h22a rebuild
Distributor shorting out
S beats a Vtec.. Unbelievable
Mugen vs. Wings West R.S.
wheel bearing
Prelude F-----D
Need alot of INFO on turning the SH into the Type S
OEM body kit! where do i get one?!?
prelude emblem?
Any other good place to buy cars ither than Ebay?
Cat. Converter
V6 Camaros no threat
Idling problems
can't find prove
idle control valve
Wicked Headlights
Car Parts on Ebay ???
My POS Prelude
92 lude problems
Upgraded ECU
Need heater/AC controls before winter
door lock cylinder??
Camber help
AXIS Reverb fitment
Matrix coilovers
New Dilemma.
Fuel running rich/trim malfunction
Keeless Entry/Alarm System Remote Doesn't Work
main fuel relay (cant find)
RSX Wheels fit the Prelude?
rs-r exhaust
problem w/turbo
VafcII & Rom can make more hp ?
jdm engines from ebay?
prelude suspension question
Headlight removal
help on JDM engine
Dash lights/ climate lights HELP please
Head or Block problem??
Honda Antifreeze/Coolant
type of headers
JDM Sir S-Spec Wing
timing belt
4th gen h22 swap hesitation
6th Gen Prelude?
OEM brake pads for 01 lude
91 h22a?!
ricer in s-10
stock wheels or 18's
Need HElp aDjusting RPMs
old dude's lude
Rims's
lsd vs. stock tranny?
Remove A-pillars on 4th gen
blown headgasket? hope not... 93' lude
engine running HOT
92 si 0r s?
Valve cover paint
R34 Urethane Body Kit?????
f20b or h22a
is this authentic?
92 prelude..timing problems PLEASE HELP!!
Where to find a 97+ prelude JDM front cut
engine build confusion
small question on the prelude types
What's the weight on 3rd Gen's??
From Neutral to Drive, takes 2-3 secs
90 Prelude Si 2.05liter Gas Mileage?
A Discovery: More Ponies after I/H/E
Prelude wallaper request
Just got my pistons!
buying ATTS or adding
Bouncing Techometer
h23 crankshaft
rebuilt driveshafts
ECU Upgrade
2nd best in show
good quality kits???
Trouble Code: po505.... need info!!!
Lude Exhaust, looking for a quiet one
93 lude idle to low
prelude 2.0S upgrades
Head gasket problem on 88 Si?
supercharger options?
5zigen Exhaust
Can use Ecu B16 with an h22a
turbo help
h23 tranny durability?
white smoke coming out of tail pipe
Turn Signals on 5th gen prelude
Tranny Problem . . Hydrolic System going bad?
SR20 powred RWD prelude
interior buttons... what goes in these holes?
Need help WitH intErior Neon lights
Weight Reduction
low price costume
wanna get the answer to your questions?
head torque
tips on 97 prelude
Prelude 5th generation
i need help in a very important decision!!
h23 swap questions HELP!!!
#3rd Gen HID question
Shopping around for Lude rims . . any ideas?
How To Turbo Ready My Lude
Cam tutorials
I'm tired of getting exhaust TICKETS!!!! HELP!
prelude headlight conversion
R34 Tailight Conversion for the Si...
buying the type S
H23
What Exhaust to get, that is the question?
01 lude SE
Prelude vtec, installed CAI, rough idle now! help!
difference in sh and base model?
Dallas Texas body shops needed
Japanese engine swap
What do you think?
99 civic EX vs. 97 prelude sh
carbon fiber hood?
Need to replace Airbag! Help!
White vs. White
Reset codes ?????? 96 Lude
Performance ECU for 5th Gen Prelude?
'92 Lude blowing fuses...HELP!!!!
Venom 400
I need speakers--PLEASE HELP!!!
Good price?
I just need some advice...
Brethren , I need your collective heads of knuckle
swaping tail light
Prelude O2 Sensor
90 Prelude 2.05 liter DOHC looses power sometimes
