View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. Fuel delivery problem solved
  2. Bad coil pack symptoms
  3. noise when stopping
  4. Gas Mileage mpg city hwy fuel economy
  5. Power Sliding Door Adjustment
  6. Help solve a mystery. . . .
  7. 02 Windstar Battery Dead Intermittently
  8. Use the right spark plug cap tool
  9. Going after the BUMP isuue..
  10. 2001 Windstar blending door vacuum line
  11. why the brake/abs light on with 2002 windstar?
  12. 2000 windstar stalls; how to check IAC
  13. intake manifold gaskets
  14. Help with cruise control
  15. 00 windstar chugs and bucks fixed!!!
  16. 2002 Windstar 3.8, P0171
  17. Upper Intake torque sequence/specs?
  18. ABS Light On
  19. Radiator Fan Always On
  20. Timing Upgrade
  21. Timing upgrade
  22. Going in for Trans replacement today
  23. Windstar rpms going up and down at idle
  24. grille question
  25. Tranny (Neutral Slams)
  26. Need Headlight Assy. 2003 Windstar
  27. B1
  28. Rear wiper won't work. 1998 Windstar.
  29. Fixed power seat, and electric mirrors 1998 Windstar.
  30. Trying to fix criuse control, 1998 Windstar.
  31. Ultimate Windstar
  32. does valve cover have defect on 2002 windstars?
  33. 2000 Windstar Issues
  34. How to know defective EGR Valve Windstar 99 3.8
  35. 2002 windstar probs
  36. How to use Compression Tester on my Ford Windstar 88
  37. No spark/no start condition
  38. Anyone else getting downshift clunk? 99 LX
  39. 2000 Windstar LX, how to know if equiped with load levelling
  40. Location of DRL
  41. Lower Intake Manifold Gaskets Failure Question
  42. P0174 - Replaced isolater bolts, port seals, "U" shaped vacuum hose, still cant pass
  43. Windstar Oil viscosity
  44. Bad Tie-rod Ends & Ball Joint
  45. Strut Mount Noise
  46. codes p171&174 and also p0401
  47. 01 windstar won't start or Jump
  48. 2003 windstar 1131?
  49. One Issue or Two ???
  50. Engine Vibration at 2000 RPM WINDSTAR 99 3.8
  51. Camshaft Synchronizer Brand - Opinion
  52. Rear Brakes - Drums & Pads
  53. Location of REM (Rear Electronic Module) on '98 LX Northwood
  54. gasline antifreeze in windshield washer fluid?
  55. MT 2500 scanner info fyi
  56. Battery Died, now speedometer and odometer aren't working
  57. 2002 Windstar Rough Idle, Spark Plugs, Coil Pack?
  58. Infamous heater blend door
  59. ABS Light On. Are codes in computer?
  60. '99 Driver's Power Window Not working
  61. 96 ford windstar instrument panel and headlights flashing
  62. Serious starting problem/no code info
  63. windstar 96 3.8 how to clear coodes
  64. If you lose 3rd gear and no back-up lights
  65. Rear Brakes Squeak - solution?
  66. tranny games
  67. 1995 windstar 3.8L loses power after 1.5 miles of driving, restart solves problem
  68. P code 1450
  69. 1995 Ford Windstar 3.0 Liter
  70. power sliding door adjustment?
  71. 99 windstar OD light flashing?
  72. rough idle after restart
  73. cruise control & abs problem
  74. cruise control@abs problem
  75. Key issue - 99 Windstar
  76. Ford Windstar 1998
  77. Spark Knock
  78. door keypad code
  79. Rear Window Washer
  80. same problem new info quitting while driving
  81. battery light flickers and car shuts off 99 windstar
  82. air bag light
  83. How do you change PS fluid?
  84. Uninstalling upper intake manifold for FPR?
  85. Our 3.8L Throttle Bodies
  86. Just replaced lower intake gaskets.
  87. Clunk Over Bumps (Not same scenario as other posts)
  88. parking aid sensor in bumper
  89. Where is my cooling leak? 3.8L 2000 WS
  90. 2000 Windstar not responsive when first started
  91. 2000 ford windstar brake pressure switch
  92. Headlight problem
  93. 99' tranny gone with no warning!
  94. Windstar Interior Disco Lights
  95. 03 LX 3.8 L; Drain Coolant Advice
  96. Spark Plugs
  97. flex pipe question 2000 3.8
  98. '99-'03 Windstar Headlight Adjust Tools?
  99. Smell Radiator Fluid inside & outside when using Heater
  100. 98 Windstar coolant dirty, cel flashing, rough running...
  101. Pass window and rear wiper do not work Related? 98 SEL
  102. po 300
  103. 2001 sel died while driving
  104. 2001 sel died while driving
  105. 1998 Ford Windstar Clock Spring???????
  106. Rpm Drop When Hot
  107. Blend Door Jerry Rig?
  108. Windstar Massive Chugging
  109. 2001 Ford Windstar
  110. Front end vibration at highway speeds
  111. Headlight Oxidation
  112. 1999 (3.8) Windstar Hesitation When Cold
  113. tranny cooler
  114. Changed every thing but cam shaft sensor is still
  115. Billy Beckman
  116. Rear Liftgate Strut Support Pins
  117. Power Steering flush works GREAT!!!
  118. Rough working engine
  119. '02 loud clicking/rattle on high rpm
  120. Parking brake light
  121. the dreaded PO304 code
  122. 01 Windstar Intake Manifold
  123. 01 Windstar Rough Idle
  124. help...random misfire detected ?
  125. 99 windstar still chugging really bad.. Help please
  126. 2001 Windstar blows #14 fuse shifting into/through reverse
  127. egr...camshaft sensor problem
  128. %%%**poll**%%%
  129. Lower intake gaskets...OEM vers aftermarket
  130. 99 Windstar misfiring -will that make it fail etest?
  131. 95 Winnie 3.8L Tranny Problem
  132. RPM limited to 4k
  133. Worked on the 98 today CEL gone for now
  134. steering wheel hard to turn
  135. 96 windstar LFC 41
  136. steering wheel repair/restoration?
  137. Stuttering 99 Windstar
  138. Front right tire wobble- cause ideas?
  139. Blend Door Actuator issue
  140. Odd P0171 & P0302
  141. speedometer cable lubricant
  142. Hubcaps falling off
  143. Cruise Control Problems
  144. Help - Engine light flashing, chugging - 99 Windstar
  145. 2001 Windstar SEL
  146. Electrical?
  147. NOW is the time to prepare for winter
  148. 2000 Windstar p1151, cant pass emissions
  149. 01 Winstar with studder at idle
  150. Ignition coil replacement?
  151. Help w/ changing ABS module on '03 windstar
  152. Help w/ changing ABS module on '03 windstar
  153. 2002 Windstar Code P1450
  154. will a transport key work?99 ford windstar
  155. 99 ford windstar i tried something & it didn't work.wet key problem!HELP
  156. 99 windstar erratic gauges door lock/unlock
  157. Opinions on Ordering a FSM From Helm Inc?
  158. 98 windstar front wiper not stopping
  159. oil changing time....
  160. Windstar with codes P0171 and P0174
  161. key got wet won't start 99 ford windstar van
  162. poor fuel mileage help
  163. Sliding Door adjustment
  164. Non Flat Line Headlights available?
  165. 99 Windstar - door in heat/AC box flapping. What's up w/ that?
  166. Windstar 13.1 miles per gallon and smell like gas
  167. 99 Windstar Lock Actuator question
  168. Is That A Pump I Hear at Engine Start??
  169. 1999 Windstar Alarm Question
  170. 2003 windstar transmission has no gears but Park.
  171. What I thought was trans issue was IMRC
  172. How to put the 96 Windstar3.6 head gasket?
  173. ac clutch problem
  174. 2003 windstar ABS & Brake light on
  175. 98 windstar EGR issues, bogs down, P0401 P0301 P1780 P1408
  176. Windstar Transmission Support
  177. bg fuel service
  178. '99 Windstar - Brake Problem
  179. Sway bar bushing replacement
  180. ping
  181. dropped pan, only go 4.5 liters fluid?
  182. dropped pan, only go 4.5 liters fluid?
  183. 2000 no start
  184. Windstar Real Gas Mileage?
  185. Power steering fluid overflow
  186. FYI - Transmission Chatter
  187. 2001 Windstar P0401 EGR Insufficient Flow
  188. 03 windstar electrical problem
  189. 99' AC question
  190. Rear view mirror question
  191. good oil
  192. bucket seats?
  193. No speedo, A/C, Ometer, ABS light on etc. etc.
  194. about miss at idle or low speed on 2001 3.8L windstar
  195. Munching sway bar bushings like peanuts
  196. 99 Windstar Lean
  197. Fading Break Pedal
  198. Signing out
  199. Engine Oil Stop Leak - Good or Bad Idea?
  200. 2000 Windstar - Timing Belt or Chain?
  201. 2000 Windstar w 3.8L
  202. Overfilling oil while away due to Gustav
  203. Front end problems.
  204. HELP Please Power Steering Pump 99 Windstar 3.8L
  205. no dash bord lights help plzs
  206. miss at idle or low speed on 2001 3.8L windstar
  207. sheet metal parts supplier?
  208. quaker state multi vehicle atf ok for 2000 windstar
  209. Changing brake pads in my moms 99 3.8 windstar
  210. Brake Drum Question
  211. 99 windstar oil light, light assembly you name it
  212. TSS sensor
  213. 1999 3.8L Windstar knock/ratrle under load
  214. My WIndstar drain plug thread stripped
  215. 2000 Windstar electronic transmission issue
  216. Windstar 1998 Service Engine Light Code
  217. 1996 Trans Problems???
  218. 99 Windstar SEL Brake Questions (Maybe too simple)
  219. question about quick strut problem
  220. 2000 Coolant Leak from under throttle body ??
  221. 96 ford windstar trans problem
  222. no power
  223. AC refrigerant crimper/joiner tool
  224. Rear AC Hose Leak
  225. Rough idle/stalls when put into gear
  226. Replacing Catalytic Converter
  227. 2003 Ford Windstar Right Turn Signal out
  228. Changing out Compressor for AC
  229. fuel pump turns, but not pumping
  230. Steering, and bucking?? HELP
  231. Motor & Transmission Mounts
  232. 98 Ford Windstar issue
  233. Can this be true.???....................LOL
  234. What is your Fuel Pressure in PSI?
  235. 02 Windstar torque convereter
  236. Front door actuators
  237. 2002 Winstar Sport Edition. Hoses wet - REAREND - (Driverside) are those for the AC?
  238. '96 3.8L Misfire / Engine Sputters when Fan Turns On
  239. 99 Windstar SEL Simple Question
  240. MAF cleaning (time?/miles?/ever?)
  241. Power Steering Blues
  242. Help Please!
  243. 98 windstar trans go boom!
  244. 03 Windstar...PO303 & PO102
  245. I think is the power steering pump...
  246. Turning On Headlights Disables Cruise Control
  247. '02 Windstar RSS not working
  248. 1999 problem with gauges
  249. 01 Windstar Rear Blower Inoperative
  250. Vacuum leak 171-174 and more!
