View Full Version : Focus | C Max
Pages : 1 2 3 [4] 5 6 7
  1. Automatic Blinkers?
  2. ZX5 on Sedan
  3. Alloy wheels (oem)
  4. Front brake rotors/pads
  5. Diesel focus wont start
  6. Transmission type
  7. Problems with moon roof
  8. Need help with engine swap
  9. left rear turn signal
  10. Suggestions on Extended Warranty
  11. Other Belt On 2000 Focus Zetech Engine @@@@@@@@@@
  12. Keycode Radio
  13. 2006 focus belt noise?
  14. Trunk lock
  15. Easy Fix For Stuck Key
  16. Clicking Noises??
  17. Clicking Noises??
  18. intake install problem
  19. Electrical Gauges dying while car is running, eventually leading to the car dying
  20. Noisy Turn Signal / Flasher
  21. Mustang on Focus
  22. Manuel to Power Windows
  23. Switching Body Parts on Focus
  24. Transimission CLUNK in Cold start
  25. sticking ignition key
  26. Antifreeze leak? Advice requested
  27. Need help with Engine Mods.
  28. Trunk Lock
  29. Engine is knocking
  30. Fuel Cap
  31. Has anyone swapped an engine?
  32. door wiring loom
  33. Digital Tachometer/Speedometer
  34. rear brakes
  35. Power folding hardtop?
  36. What can I expect from the base ZX-3 drivetrain?
  37. ANswered my own quetion!!!!
  38. Odometer/Trip Display Burnt Out? Rest of gauges fine
  39. Odometer/Trip Display Burnt Out? Rest of gauges fine
  40. Question about DTC from self test
  41. Whats the biggest size Rim you Can fit on a Zx3
  42. White powder on pos. post
  43. White powder on positive post
  44. first year svt question
  45. Focus bucking problem
  46. starting problems
  47. Dies at idle. Rough Idle. 2000 Focus
  48. Ford Focus Pos
  49. Quick Focus question
  50. Factoy CD player
  51. Focus Transmission Chirping
  52. 2003 Ford Focus Wagon Ignition Problem
  53. Where is Focus-Central?
  54. how do I bleed the clutch on 2000 focus
  55. bleed clutch on 2000 focus
  56. Official Focus RS Keyring
  57. Projector Headlights
  58. 2006 Ford Focus ZX4 ST
  59. 5speed o5 focus ST idling probs and check engine light
  60. Idle Motor
  61. Gage malfunction
  62. 06 street appearance package
  63. supercharger for ST
  64. need more brakes and grip....
  65. Installed wrong oil filter............
  66. economy?
  67. Radio Clock
  68. Tie Rod Help Please
  69. Tie Rod Help Please
  70. Modern Performance Clearance Stuff
  71. voltage regulator
  72. 2000 Focus Wont Crank
  73. battery died
  74. 2005 Focus power train
  75. 2003 ford focus running rich
  76. 2000 Ford Focus LE
  77. Svt swap or just tranny swap? Zx3
  78. Svt swap or just tranny swap?
  79. Zetec head $95
  80. Zetec/SPI Throttle Body Swap
  81. tail light lens
  82. 6 disc changer won't play burnt cd's
  83. ford focus 2003 LX-key will not turn in switch
  84. Turn Signals whackin out
  85. Need more go go
  86. Center dash consol removal with a nut driver and a coat hanger
  87. funny smell
  88. Where does the clutch cable connect to?
  89. 2000 Focus Heater Control
  90. Dashboard Center Console Removal
  91. mystery all doors lock.
  92. question about the rs model
  93. does it happen to everyone at the same time?
  94. brake light switch?
  95. Engine Cuts Out
  96. 2002 ZTS will not idle
  97. Headlight Wiring
  98. This is why Ford sucks
  99. Cold startup, bit of a whine
  100. All-New Ford Focus RS WRC 06
  101. Clutch on 2000 Ford Focus wagon w/automatic
  102. Largest Size Tires
  103. '05 ZX4 Squeaky Wheels, Grinding Brakes
  104. High fuel pressure
  105. snow in the gas tank
  106. So thaaaaaat's what that is...
  107. any advice?
  108. Dash and console
  109. SPI...how much of a gain?
  110. Exhaust System
  111. Left turn signal not working
  112. 2000 Ford Focus zetech Rough Idle Cold but doesnt Stall sometimes Rough Idle at stops
  113. light weight windows
  114. head tourque specs?
  115. HELP!!I'm lost
  116. Strut Tower Brace
  117. two problems- related?
  118. Duratec 2.0 Turbo?
  119. engine swap
  120. 05 focus zx4 cd error
  121. 2000 Focus runs fine cold then judders and dies
  122. Turbo???
  123. auto trans leak '05 focus
  124. Door panel removel
  125. explain the zetec
  126. 2001 Ford Focus Horn
  127. clutch pedal, leaking inside vehicle
  128. Bent 16" rims
  129. Where is the auxiliary port in a 2005 Focus?
  130. 05 Focus Wheels
  131. "bumping" feeling in the clutch pedal
  132. Duratec or SVT
  133. Ford Fuckus rear window
  134. horrible idle on focus and check engine light
  135. top speed limiter removal
  136. Check engine light...Need help!!!!
  137. 2002 Focus SE (Sedan) Window Problems...Please Help!!!
  138. Car stalls when shifting into park or reverse too quickly
  139. Focus Won't Start
  140. Tach for my 2.3L duratec
  141. rear grease seal?
  142. Standard Trans Clutch Replacement...
  143. bodykit questions
  144. Help Me With My Bumper
  145. 03 svt focus shift cable slips off
  146. battery light issue...
  147. Suspension upgrade
  148. Fuel filter location?
  149. 2000 Ford Focus rough idle now stalls
  150. Bad TB position sensor - "need new TB" WHAT!?
  151. My car problems
  152. loud noise+vibration
  153. I've got a brain buster of a problem w/my zx3
  154. 2000 Died at low RPM
  155. Eibach Sportline
  156. 2004 Focus Power Locks, already there?
  157. funny noise from engine
  158. ZX5 transmission problems.
  159. FS: 02 Focus ZX3 (35K Miles, CLEAN!! 5Speed, LOW PRICE!!)
  160. SPI or Zetec?
  161. Lag In Acceleration
  162. Exhaust tip question
  163. Focus w/ Mustang Engine
  164. won't start, won't shift out of park
  165. My Duratec needs more power
  166. lowering
  167. Normal to SVT exhaust change
  168. Vibration in front-end
  169. Pirelli P6
  170. focus problem
  171. ZX3 electrical problems
  172. Zetec Flywheel
  173. Ford Racing Tachometer
  174. 2005 Ford Focus Radio Removal
  175. SOHC Performance Parts
  176. Factory Cluster Swap
  177. Not able to shift into 5th or Reverse
  178. brakes
  179. ZTW Wheel Nut Caps...Disappearing
  180. Horse Power???
  181. Cryo2
  182. just got my '03 ZX3...
  183. speakers
  184. 2000 Ford Focus SE
  185. ignition problem
  186. Idle Speed Control Valve (iscv)
  187. Wheel Bolt Patterns Question
  188. Focus Wheel Alignment...'Shims' Needed???
  189. 2002 Focus no power won' rev up, Code p1507
  190. focus vs 156
  191. Oh!! No!!???
  192. How to replace fan speed switch on 2000 Focus?
  193. focus upgrades?
  194. I hear all of these problems about the Focus...
  195. 02 Focus ZX3 FOR SALE!!!
  196. 2000 ZTS Altenator or Processor problem?
  197. transmission?
  198. Speed Kills
  199. FS- 03 ZX3 factory 16" rims
  200. Carbon fiber focus hood
  201. Back Door Windows
  202. civic killa
  203. Everyone with a 2005 focus read this.....
  204. I Bought A 2005 Ford P.o.s.!!!!!!!!
  205. Wanted to buy...
  206. Focus Limited for sale.
  207. Body kit install
  208. 2005 ZXW - unfortunately a lemon!
  209. Engine Swap?????
  210. Focus Overheats when A/C is off
  211. remote entry not working
  212. Focus Acronyms and codes
  213. weird sound from the read while using A/C
  214. what can be done to them
  215. 1996 Focus TDI smoking and whisteling
  216. where is the fule shut off valve and relay?
  217. nedd help with check engine light!
  218. Focus wiring diagram needed for grounds
  219. fuel pump or fuel injector problem
  220. check engine light
  221. problem with tranny
  222. how good is the focus really
  223. EGR valve? Need Help!!
  224. '05 Focus "noise"
  225. Hole In Firewall
  226. 2002 Focus ZX5 - 63Kmi // for sale
  227. ZTW Tire Follow Up
  228. ZTW Tires (Options?)
  229. engine light on??
  230. Major problems with 2000 Ford Focus SE at 48,000 miles.
  231. What's the total cost(All installed turbo)??
  232. 00 SE A/C Recharging
  233. 2000 SPI Auto Transmission Problems
  234. 2001 Focus Se 4 SALE
  235. What do you think is faster?
  236. funny sounds....
  237. kinda off topic but can u help me?
  238. Engine lopes when idling
  239. Focus ZX3 Overheating Problem
  240. Echeck!!!!
  241. Automotive Extended Warranties
  242. zetec turbo header?
  243. Focus fuel Pump.
  244. focus for VW corrado
  245. can xtra feature be added at the dealership?
  246. good car for noob drivers?
  247. Focus 1.8 petrol - battery charge light - intermittent
  248. Break in period?
  249. question for ALL of you
  250. no help on focus
