View Full Version : Older Pickups
- Nissan Hardbody 2.0l 16v
- Need recommendation for replacement exhaust manifold
- 1996 Nissan hardbody xe 4x4 won’t crank
- 1995 Nissan SE, idle surge
- 1995 SE pickup..Warning chime
- 1983 nissan pickupwith 2.4 L z24
- 1977 Datsun 620
- 94 nissan starting problem
- Intermittent check engine light
- 1994 4x4 nissan pick up
- 97 nissan d21
- 1985 nissan 720 4x4 rear cylinder valve knock NEED HELP
- 1997 Nissan P/U turns over but wont start
- 97 4x4 hardbody wont start but will if jumped
- 1993 D21 oxygen sensor
- 87 hardbody truck- hesitates turning left
- 1986 Nissan Z24 ignition Problem...
- 1983 Nissan Hardbody 4X4 pickup w/1986 Z24 engine
- Do z20 parts crossover to z18?
- 95 XE-V6 - Cold Start Issue
- Won't idle at different times
- Timing Issue?
- Runs rough at times
- Squealing Brakes on 93 pickup
- 97 Nissan Pick-up XE won't hold a charge.
- 97 nissan running rough
- Sensor Location
- 1988 D21 z24i acceleration problems.
- really need help finding a taillight lense for 82 datsun 720
- 1995 Nissan SE transmission
- 1995 nissan steering shroud
- 1985 Nissan 720 4X4 Fuel Gauge
- 1994 Nissan D21 2WD 4CYL, standard transmission wont crank/start
- 92 D21 cranks, just doesn't want to start
- 97 nission pickup blinkers not working
- 94 running rough
- 1995 Nissan SE.. no cruise control
- 1995 Nissan SE iddleing too high
- 89 nissan pickup wont start or run
- 97 Nissan Hardbody Manual RPM Issue
- Will 15x10 wheels fit my 4x4 89 king cab?
- 1995 pickup screeching noises
- Need Timing Specs for Z18, 1979.6, 720 4x4
- Compression Specs for my 720
- Cracked Insulator on Ignition Coil A Problem?
- Which 720s Came With a Z18 Engine?
- 720 4x4 w. New Timing Chain now Stalls
- 85 Nissan PU 24Z loses power.
- 15x10 wheels will they fit
- Idling ? Please help
- No Power to Fuel Pump on 89 Nissan Pickup
- 1985 Nissan PU Electrical Problems
- Speedo bounce
- 1985 720 4x4
- Valves noisy after Timing chain replacement
- How do I find TDC on #1?
- Timing chain replacement instructions
- need ecu 86.5 4x4 nissan truck
- 1985 pickup strange behavior
- 1997 Nissan Pickup Truck (need help)
- 88 4x4 wont start
- Quick Question regarding Water Pump
- 1987 D21 alternator charging issues
- 1996 nissan pickup
- 89 D12, No Overdrive, where's the relay located
- truck not building up pressure in radiator
- 1985 720 nissan
- 96 nissan 2wd
- 82 720 datsun timing help
- Valve Adjustment Procedure - Anyone Still Here??
- 1987 d21 rear drive shaft needed
- 4 cyl truck shows missfire in #4
- Trans Interchange 1986 1/2 V6 to 1987 I4
- 1984 nissan 720 won't start after changing dist. cap and rotor
- 1997 2.4cyl wont start
- 1989 d21 starter drawing too many amps
- 85 nissan p/u help!!!!
- KA24e swap to DE
- A/C Clutch
- ECU fuse blown
- center support
- recharging air conditioner
- 1996 nissan hardbody clicking noise evap
- 87 idle issues
- 86 to a 87 engine swap need help no spark
- 1990 wont start when warm
- '89 Nissan pickup drive shaft
- How to retrieve codes?85 720 pickup
- No clearance lights
- 1985 720 no power in 4th or 5th
- ABS light on, 94 XE pick up
- Power Mode Not Working On A/T
- Here's a real stumper!
- 85 720 2.4 Carb Cant get rid of low idle miss??
- 1985 720 z24 carb need picture of distributor cap and wires
- 1987 nissan pickup
- Little Black Box (83 King Cab)
- Help, help, help - 86 Nissan Pickup Heater Core Issue
- New Clutch but some problems on 84 720
- 84 720 changing engines and trans-advice please
- 91 SE V6 Extended Cab
- 85 2.4 with super high idle
- 93 Nissan king cab 4x4 4cyl.
- 1995 nissan trk,fan/heat control panel lights
- do I have a bad Exhaust Gas Sensor
- 1988 nissan has fire has fuel won"t start
- 86 to 87 engine swap distributor problems
- Dead in the water?
- Nissan D21 Z24 Z24I Tach Wiring help!
- Hard to start when cold
- Brake Issues
- Help with an 85 King Cab Nissan 4x4 pick up
- How To Read The code's ?????????????
- I need Help bad with my 85 4x4 Pick-up
- MAF sensor prob
- Looking for interior parts
- 86.5 Nissan 4x4 3.0L 5spd Trans noise.
- 86 D21 pu intermit. starting problem
- 95 pickup with no reverse
- 86 720 Z24 2 barrel, A/T won't idle after warm up.
- 89 Nissan
- 1997 XE Brake Backing Plate Replacement
- Need a good off road bumper for a 86.5 hardbody
- 1987 nissan pick up cooling problem NEED HELP!!!!!!
- Help!
- FS 1989 Nissan Truck Owners Manual
- Parking Brake Stretched
- Block Heater Install
- 94 pickup stumbling/hesitating
- 92 D21 timing?
- 92 D21 fuel? or no fuel? Can't tell!
- 92 D21 all crank, no turn over?
- 93 to 97 dash conversion help
- 97' nissan pick-up, clicking/tapping sound on Idle
- Truck Box / Bed Removal
- Code 32 on 94 with 102k
- 97 nissan pick-up question
- 1986 King Cab bed size?
- 87 2WD Pick Up - Two Decades of Starting Problems
- 94 Pickup Spark Plugs?
- 86 pickup running rich
- 86 D21 6 cyl 4wd engine stops running
- 96 nissan truck charging problem?
- 1996 nissan truck cluster
- Answers? 1994 Nissan Pickup (D21)
- Spark plug cables
- Whats the tow capacity?
- Parking Brake Question ('93 2WD 4 cylinder)
- 1995 XE 4 cylinder pickup electrical problems
- 1983 Nissan Carb 720
- Solid axel swap.
- 94 with clutch issues
- Block Heater on 1993
- 86 D21 Hard Body
- wont start, need help!
- 95 nissan p/up.blower motor
- 92 nissan pick up
- 97 Nissan Pickup
- 92 hardbody, spin but no spark
- 1996 nissan pick up runnig rough
- 86 1/2 D21 Charging light glows faintly
- '84 720 2.4 carb prob..
- Carrier bearing?
- Rear Brakes??
- 84 nissan thumps in reverse
- remove window crank handle?
- 1984 Pickup... left rear wheel locks up when braking.
- 250,000 miles!!!
- reset button after a crash?
- rearend clicking noise gmc
- ABS and brake light on 95 Nissan pickup
- 86 pickup hardbody wont start
- What will this cost me?
- 84 z24 will not start
- CNG Kit for 84 720
- Help
- '91nissan pickup interference motor ?
- need help
- 82 720 idle update
- 86.5 nissan truck
- 82 pickup rough idle
- 86 1/2 nissan truck won't start.
- 95 Nissan 5-speed won't go!
- my 94 nissan hardbody wont shift from first
- 84' 720 Z24 Rough Idle
- Nissan Pickup won't start after sitting for 3 months.
- 88d21z24 reborn to 86v63.0 King cab
- Replace Carrier Bearing on 87' 2-wheel drive d21
- Changing out head gasket?
- 94 nissan pu Grease/Zerk fittings
- 96 nissan p/u speed sensor
- 94 pickup, headlight relays?
- 86 1/2 Nissan Hardbody truck
- Transmission Problem help!!!
- Air conditioner
- I need help
- Nissan Pickup Alternator Wiring.
- What is a Solenoid??
- Oxygen Sensor Light for 86 Nissan Pickup
- Easy Question, but I don't know
- 86 Hardbody 4x4 V-6 just stops running
- Back-fire 1988
- 93 nissan pick up tranny
- No heat...brrrrrr!
- 95 Nissan Truck Help
- Squealing noise when accelerating in 1st and 2nd
- Oil in Radiator
- 1993 Hardbody
- 1988 low power
- 88 z24 dies at half throttle
- Speedometer and Odometer stopped working
- looking for ext cab passenger window
- cooling problems
- read codes for 95 6cyl 4WD
- Noisy valve train '94 2.4l
- 1984 Nissan Pickup just died...
- problem with 88 z24 2.4......please help!
- '85 Nissan Pick-UP Z25 fuel and temperature gauges fluxuating
- Mid ninties Nissian P/U starting SOLUTION
- * * * 94 V6 4x4 Engine bogging * * *
- These Trucks Are The Real Deal!
- '85 Nissan Truck Z24 looses power and sputters at high RPM or going up a hill
- after market parts
- 1988 Nissan Pickup Radio Wiring Diagram
- Front end squeal
- Is the Haynes owner's workshop manual a good book to buy?
- '88 Hardbody low-to-high fuel combustion chokes
- gauges not working
- Brake Drum Nightmare Is Not Over!
- WTB 92 fuel pump assembly
- Brake Drum Nightmare!
- Emergency Brake Adjustment Question
- Engine Light Came on at 100K
- Fuse Box on 1986 Nissan?
- 1986 Nissan Pickup doesn't hit a lick.
- 1990 Nissan Pickup not starting
- datsun not firing
- 1986 1/2 pick up want stay running
- "Clunk" noise?
- Manual vs. Automatic transmission
- Hitch Receiver, drilling?
- WTB: Nissan 720 w/ SD25 SD22
- Alternator problem 95 Nissan Pick up
- 88 z24 intake problem
- Trouble shooting 93 V6 4x4
