View Full Version : '04+
- 2013 vw jetta code P0106
- 2014 Jetta Trunk Lamp Problem
- 2017 Jetta TSI dsg
- 2006 jetta reliability=--
- Jetta '14 did not start. Bad gas? Broken timing chain.
- 2012 Jetta 2.0 heater core
- 08 VW Jetta Battery Issue/ Question
- 09 Jetta Clutch Bleeding
- A/C compressor won't come on
- *#!#!**!*#...filter!!
- Intro...
- Shiftronic issue on Jetta 2012
- 2004 Jetta gl 2.0 sounds like a ricer.
- problem removing crankshaft position sensor HELP PLEASE
- bent valve?!? 2004 jetta
- Fuel pressure regulator location
- Fuel pressure spec's 2005 Jetta 2.0
- 06 driver door switches all dead
- Gas smell inside the cabin of the car, need some help
- 2011 Jetta headlights come on middle of the night
- 2010 Jetta TDI popping sound from radio
- 2007 Jetta blower not working
- 2006 User Manual
- Jetta 09 TDI Mud Guards
- 2011 Jetta S Transmission
- 06 TDI Jetta passenger side door dead
- 09 Jetta TDT Head Lamp Replacement
- Head light issues 04 Jetta deisel
- Red battery light is ON when the car stop.
- 2004 jetta needs help
- 04 jetta ac not workin
- 06 Jetta Ping/knock noise
- Jetta rims too wide?
- 2004 vw jetta tdi code p0230
- 2008 Jetta Wolfsburg cylinder miss fire issue
- 2006 Jetta Drivers Door panel and sensor
- engine code PO481 on 06 Jetta
- what am i driving
- cant wait for 2011 TDI
- Jetta 2010 2.0T, steering
- code radio anti thetf
- 2004 jetta 1.8t thermostat location
- 05 jetta transmission fluid
- 05 jetta torque specs
- Alarm Sounding Randomly and Hood Open Indicator is on
- 04 Jetta 1.8tdi WOnt shift while cold.
- 05 jetta air filter question
- jetta 2006 TDI
- 2006 TDi Cylinder head $4400?
- VW Jetta 2004 2.0 Several Engine Codes
- 2010 Jetta 2.0T, extra vacuum port
- Sun visor and vanity light
- Rear Bumper Fasteners
- VW Jetta 2006, Quick question
- 2005 cigarette lighter fuse
- 2005 Jetta 2.5L ECM location!?
- Front brake pads worn light
- 06 timing belt
- 05 2.5L removing the oil pan housing?
- 2004 Jetta TDI Hard starting?
- 2009 Jetta Wolfsburg 2.0T.
- Timing belt broke!
- Looking into buying a 2004 jetta 1.8 turbo anything i should know?
- 06 Jetta, rough idle/vibration, shuts off. Code P0343
- o4 Jetta tdi
- '08 something stuck on
- 04 jetta tdi
- 04 jetta tdi
- suspension noise over bumps... Please read
- 2005 Jetta. What kind of oil?
- 2006 Jetta
- '08 Jetta test drive....first impressions
- the 'broken wrench' light
- Dtc Po411
- Windshield frosts on the inside
- Grille
- front licence plate solution
- 2005 Jetta Station Wagon Smells Like Cat Pee Inside
- country of origin
- 2004 Jetta Alternator/Battery Problems
- 04 TDI lifter noise.??
- Fryaway veggie fuels
- 2005 Jetta 2.5 Lurches between 1st and second gear. Also sounds rough in the morning.
- 06 Jetta Alarm Questions
- Troubleshoot code for 04 Jetta 2.0L?
- 2005 Jetta GLI Intercooler?
- 05 Warranty Question
- 2004 Jetta GL bumber chrome issue
- Jetta's AC emits foul odor
- Dented Transmission pan
- 04 05 or 06 jetta
- Jetta/Bora Accessories
- That Damn Cigarette Lighter Issue Again
- FS: aftermarket cd player install kit
- 05 jetta
- Volkswagen Jetta 5 tuning by Caractere
- Dear Volkswagen Jetta Owner
- 06 TDI New owner Questions
- gli vs. si
- is gli a ricer..?
- another 04 gli question..
- tdi oil
- 04 gli questions?
- Tq Or Hp
- VW oem parts
- 2004 Jetta GLI noises
- 04' Jetta TDI, stalling when cold???
- Check engine light on on 2005.5 Jetta 2.5L
- 06 Jetta TDI Tranny noise in Park
- 0-60 time 2005 1.8t jetta
- Replace Air FIlter 05' Jetta???????
- droping my 04 jetta 2 inches
- 2004 High RPM problem
- Why no TDI in Liberal states?
- 2006 Jetta 2.5
- Navigation System
- show me ur jetta GLI's
- 2004.5 Jetta GLI for sale on ebay, only 995 miles
- RE: A5 issues resolved for now
- 2005 A5 died
- 0-60 time?
- Jetta wheels
- Jetta: Worst Car You Can BUY!!!!!!!
- jetta&jetta wagons
- 2004 Jetta GLI VIN problem
- Jetta TDI, should I buy?
- 2005 Gli
- Will 16" rims fit on a Jetta GLI 1.8T
- 2004 Jetta diesel
- Just bought a 2004 Jetta GLI VR6/new to the site.
- 2004 Jetta
- FS: 2004 jetta GL
- Strange noises from 2004 Jetta
- Buying 04-05 jetta gls tdi wagon
- my 2004 GLI 1.8t
- Buying an 04 TDI, any thoughts?
- 2004 jetta rpm
- 2004 Radio Cuts out
- 04' 337 Jetta?
- Technical questions, troubleshooting etc.
