View Full Version : C/K
- No heat from blower
- Rear axle seal radial play
- Simple Tow Bar Attachment for C/K
- 1998 4.3L V6 exhaust flange studs
- Rear bumper interchangeability
- In-dash HVAC control head non-functional (mostly fixed.)
- Crank No Start
- Stoplamps out - CHMSL OK - Is Shop manual wrong?
- 95 1500 hard starting
- Broken heater hose connector repair
- Brace from motor mount to Transmission bell housing
- '97 K3500 Dually Defrost Only On Passenger Side.
- 6.5 Detroit
- LED Headlights Dim Switching from day running to full on.
- Electric Fans For 1997 K3500 W/454 Vortec?
- 1997 K3500 4X4 Dually Performance Questions!
- Cold start
- 4L60e replacement - year compatibility
- 1995 k1500 v6 turns over but won’t crank
- 99 3500 dually 4x4 rear drum stuck
- Pitman Arm - Can I avoid breaking P/S line joints?
- Restoration costs ????
- 1994 chev 5.0 tranny
- 1999 k3500 brake problem
- Ticking noise
- '94 K1500 Transmission Problems
- 1993 k1500 lights not working
- 1996 Silverado K1500 - LOST KEYS
- 93 c1500 no crank no start doesnt hold a charge
- 1998 K1500 Air Conditioning is intermittent
- K1500 K2500 Front Control Arm Bushings (Polyurethane)
- 1997 K2500 7.4L Starter S wire repair *Fixed*
- Eliminate Power Steering?
- 1998 Silverado misfire in overdrive
- Starter?
- 1988 TBI injector feed positive wires red and white
- 1997 Silverado K1500 - No brake lights or head lights
- '97 K1500 No 4WD, no lights on switch
- 1997 k1500 will move and then not move
- 96 2500 money pit
- Power surges 96 2500
- Pulse / Delay / Intermittent Windshield Wipers
- 1993 4.3 cheyenne swap
- 1976 GMC truck c/k 15 Engine Vacuum
- Hydroboost conversion
- Question for those who rebuild, not replace...
- Headlight Relays
- Need Advice on headlights
- Reverse / Backup light / Trans position switch
- Spits, Sputters, falls on face once warmed up
- 4L60E Transmission Interchangability
- Im planning on swapping out my 4.3L tbi for a carbureted 350
- Plastic timing cover
- K2500 goes into and stays in Open Loop
- Chevrolet C-10 3/4 ton 4x4 long bed 1967-1972 chassis
- 96 3500 4x4 no speedo
- 2 new can shaft sensor/ still throwing code?
- p151 only code 1997 5.7
- 5.7 l sprider injector leaking
- 1997 k1500 leaks fuel at intake manifold
- 96 chevy 2500 cheyenne
- Questions about swapped engines- 5.7 TBI from 90' into my 94'
- 94 chevy k1500 ignition HELP PLZ
- Lower control arm bumpers 1997 z71 need
- Problems with headlights on
- 4L80E problems
- 98 C/K 4X4 Automatic Tranny Problem
- 94 Chevy 350 overheats when temps fall below 0 deg
- 4H for 2 Hours at 65 MPH
- calling all ck1500 mark 3 owners
- 1994 - Engine Swap or Rebuild
- Purpose of 4WD axle actuator?
- 1990 Chevy 4 wheel drive blows fuse
- Bell housing help!!
- 94 Chevy k2500 lack of torque
- engine rubber splash guard
- 89 K2500 windshield wiper issue
- 95 C1500 window defrost problem
- 1994 C1500 V6 - fuel injectors won't spray
- Air Conditioning Repair C30 Chasis
- Bench Seat Levers
- 98 k1500 misfire
- New found problem help needed
- 94 k2500 fuel mileage terrible
- 70 c10 drum brakes not coming off
- 94 k2500 no low end power and horrible fuel mileage
- 2000 C2500 stuck in closed loop.
- 4L60E slipping out of overdrive
- Ckp
- 1995 Chevrolet k1500 Transfer Case 4wd problem, Please HELP!!!
- 1996 Chevrolet k1500 Transfer Case 4wd problem, Please HELP!!!
- TBI 350, Taper & Out of Bore....
- 89 Chevy c1500 Oxygen Sensor Problems??
- 88 5.7 l oil pressure gauge pegged at max
- 97 K1500 fuel pump and engine issue
- stainless bolt in exhaust system
- 79 c10 blower motor
- Edelbrock TES Header repair
- It's gotta be the starter...doesn't it?
- door jamb light switch issue
- need help with factory keyless entry
- door won't open from the inside
- pass. seat back won't lock into place
- Speedometer running fast
- 1991 Chevy 350 V8 5.7l -CONVERTED-!!
- 1982 C-10 6.2 L Diesel
- 1991 chevy 2500 engine knock
- 97 305 to 350 swap issues
- 454 injectors?
- distributor installation 98 5.7
- 1998 K1500 Blend Door
- 1991 chevy silverado k2500 big block no spark
- 92 k1500 with serious steering issues
- Press-on or heat diff bearings?
- still having issues with 92 k1500
- 1991 idle/running problem
- 88 chevy 2500 runs poorly (help)
- '91 K1500, 700R4 won't shift into 3rd or OD
- 92 k1500 hesitation/power loss problem
- Truck box replacement lock - make your own?
- '89 C2500 rear brakes lock up
- Seats
- 93" chevy. stalls
- died, won't start
- abs light on, no dtc
- Wire Auxiliary High Middle Stoplight?
- brown goop oil
- DIY fuel pump question
- 84' c10 stalls in gear
- 1980 K10 ignition issues
- 1995 K2500 Rear End noises
- Oil Pressure Sending Unit--TBI V-8 dash gauge
- 1997 K1500 CTSY Fuse 3 Parasitic Drain
- TBI runs rich
- 1996 Chevy C2500 Suburban 350 V8 Hydroboost brakes.....truck pulls hard left
- Replacing front reading lamps
- 89 C1500 clutch problems
- 97 K1500 - Key will not go fully into door lock
- Coolant AND Oil Leak
- CEL & P0441 Code, 98 5.7/350 Runs Rough
- stalling
- 68 C20 Custom Camper CST
- Rear brakes on my 1998 3/4 ton chevy Cheyenne
- 1995 C/K Factory Service Manual
- Towing Options - 1998 Silverado 1500
- 94 6.5 5spd nasty rattle help
- Replacing Lower Ball Joint 1996 Chevy 3/4 Ton 4x4
- Emergency Brake Cable Replacement Troubles 1996 3/4Ton 4x4
- Wrong Anti Freeze Type Cause Damage
- gauge question
- Do I need to replace my ignition cylinder?
- Changing Outer CV Boot 1996 Chevy 2500 4x4
- 92 c2500 heater control problems
- 1993 K1500 runs terrible when hot
- 1981 C-10 Left turn signal issue
- 350 TBI seized, rebuild advice needed...
- 1996 Chevy K 2500 upper contol arm bushings
- ABS Wheel Sensor Replacement 1996 Chevy 3/4 Ton 4X4
- Jounce bumper bracket rusted bad
- 79 350 misfire question
- What engines will fit in my 1975 3500
- overheating issue
- 94 k2500 axle wire harness
- 1998: Mobil 1 Synthetic Trans fluid for Power Steer. fluid?
- keyless entry not working well
- Crank Sensor Location on a 94
- replacing door handle
- 2000 GMC 3500 rear brake bleeding
- 1990 Chevy K1500 Ground issue?
- Misfire
- 97 305 vortec starting issues
- 1988 K1500 5.7l 350 wont start
- 99 K15005.7L-Replaced timing chain and now won't run
- coolant temperature sensor issue or not
- 1982 C-10 6.5L Diesel Air Compressor
- Speedometer decreases at 60mph
- 350 tbi shudders
- Cold start resolution?? - '90 K2500 5.7 TBI
- '99 Vortec 350, Code P1509 (High Idle)
- engine just stops
- 1994 chev c10 4.3L V6
- stutter
- "buttons" for airbag, cargo lamp, etc not in place
- removing dash to install stereo (cargo lamp, airbag, 4x4)
- Question on CV axle shafts
- possible timing advance issue
- 454 won't idle
- engine crankshaft question k1500 93 tbi
- Broken bolt: Good idea or bad idea?
- Changing mains and con rod bearings while motor in truck
- 97 C1500 350 Erattic Misfire and Detenation
- fueling issue possibly
- Chevy K1500 5.0 L wont start
- K1500 Steering Box Upgrade
- motor swap
- motor swap
- motor swap
- slow to start
- installing the overhead compartment
- Starting Issue?????
- posting diagrams
- what is this on my visor?
- how rare are 5 speed trans' in these trucks?
- 93 Chevy C1500 (Cheyenne) Idle Issue
- 1995 chevy c/k1500 electrical
- Exhaust pipe.. size matters?
- Will a camshaft help performance with stock computer?
- replacing headrest?
- gas mileage 5.7L
- In Dare Need, 95 K1500 Speed Problem??
- eaton g80 vs detriot truetrac
- 95 k1500 rear axle
- Leafspring eye bolt
- Chevy 350 rebuilt
- 97 k2500 Brake issue
- Beefier Tires?
- Need Trans Help, Turbo-400
- Lifting 1997 C1500...need opinions
- series of odd problems leading to one big issue NEED HELP!
- Turn signal lights electrical problems after washing engine bay
- my 97 silverado ac works for a short time then stops blowing thru the vents
- Full mechanic check
- 1995 1500 Transmission shifting issues.
- 1997 C1500 SIR ASM COIL removal
- 1997 C1500 Steering Wheel Motion Sensor
- 96' k/1500 305 Nothing will happen!!!!!
- need help! k-10 with issues
- Passenger footwell rain leak
- 88 k2500 silverado
- 1988 k2500 Silverado
- Check guages light on 1988 C/K 1500
- no gas and no fire
- brake lights ??
- Check engine light does not come on..
- Little help here
- 98 k1500 is a mess please help
- 1995 3500 6.5 Diesel Started Yesterday, Dead Today
- '89 Burban Delco stereo help?
- 95 chevy 350 no spark
- 96 chevy cab lights
- Distributor tower or coil problems
- 2001 Suburban Problems after arc.
- Brake problems 96 chevy 1500
- 97 K1500 - Drove it to dealership for program, left on a tow truck. Help!
- K2500 Brake issues
- Fuel Gauge reading full all the time
- 92 K1500 5.7L Cooling system temp fluctuations
- stalling
- 1992 k1500 cooling system and missfire issues
- 4wd/cv axle?
