View Full Version : C/K
- Help !! Truck is showing codes 36,33 & 78
- clicking after intake gasket repair(97 silverado)
- passenger side dash
- Analysis of Tahoe complaints at NHTSA
- Won't start
- electronic cooling fans
- 99 Tahoe heater blower
- Relocation
- did search,97 tahoe programing ?
- Has anyone used this for lift?
- '99 Tahoe
- suburban woes
- Two other sweet truck forums
- Right front brake is squeaking
- 2003 First Mods??
- Anyone have wiring for power seats 2000 silverado
- Remote Start
- 99' Tahoe Oil Pressure and Steering Problem
- Right rear turn light out
- 2000 Suburban Brake Failure
- Tire Tread
- 2000 LT interior noise
- 1995 Silverado Exhaust???
- Idle arm/ Pinon arm replacement
- P0446 Code
- Spray Liners
- Cooooold air intake
- Head Lamps won't work
- PDA-Dyno™ & OBD II Scan Tool
- Remove Tahoe Headlights....How?? Please!
- 2003 Tahoe Performance
- Small Emissions leak 99 silverado
- jerking suburan
- 2000 siverado stepside bed rail caps suck
- questions for Carmelfrapinator
- Shifts out of gear on inclined stops
- Aftermarket CD player
- Cam Upgrade?
- More Power?
- PLEASE HELP - 88 Burb - Intermittent Vibration
- Po442
- 2000 Limited Tahoe Differential Fluid Change
- 305 into c-10
- tsb question
- 04 Suburban Help
- Temp Select Switch
- 2002 Silverado
- Need help disabling auto locks
- Where is the oxygen sensor ??
- "seervice engine soon " light
- 99 2500 7.4 L Hard Start
- Suburban 1985
- Racing Trucks
- brake pedal goes to the floor
- 2003 radio question
- 1997 Chevy Truck igintion problem
- Gas Tank
- 88 G-van stalling??
- ??? on esclade gauge cluster?
- I am looking for a Wiring Diagram for 97 Tahoe
- Speaker Boxes
- Buying a 'Burban, what to look for? (Trouble spots)
- 2003 Silverado JVC head unit install - OK
- New Wiring??
- 01 slower than 99 5.3?
- More 1996 C3500 starting/electrical problems
- 89 suburban stalls
- Vibrations
- towing an A/T Van with a tow dolly?
- 01 tahoe LS questions
- Contact the EPA about your injector problem
- best oil additive?
- aftermarket radio
- power sterring fluid
- 1993 Suburban Amplifier wiring help
- dash removal - cd player install
- Cast Aluminum Oil Pan
- Cams
- Anyone need Rear Rotors? Brand New?
- Throwing a 44 code
- worried about high mileage
- Smog/Non-Smog Legal Heads?
- Bright Lights Question
- hard starting and rough idle
- Cold Air In Passenger Compartment
- Awesome forum www.gm-trucks.com
- 01 Suburban Lights Dimming (Different than post below)
- What the....? (can't set timing)
- 2000 door lock left side switch & remote not working
- Belltech drop kit
- Lights Dimming
- axle problems w/ lifted 99 chevy
- Fipk or programmer?
- changing spark plugs?
- Heater Control
- brake/transmission interlock
- front differential doesn't engage
- Looking for OEM GM fender flares for a 99-04 Pewter
- Where is the pcv filter on a 99 5.3?
- 1988 brakes
- HP & TQ on an 89-5.7L?
- shift clank
- Service Engine Soon
- Electrical Issues with Heater & AC
- Engine Misfire
- Fuel Pump loud
- How to replace fuel filter?
- Help finding the yr and model
- program keyless remote 2001 tahoe
- Change climate control from manual to auto
- Help...Kill Switch Install ??
- 99 Silverado towing/trailer lights
- Water Leak- Cargo area
- slight knock/ping during acceleration
- 95 Tahoe locks automatically
- Hot Start?...
- '99 Silverado 5.3 Starts, then dies
- Lights and locks
- 91 chevy V-6 rough idle and rough running
- " Z " height range 2003 Tahoe
- P R N D 2 1
- More stall
- 1 ton turbo diesel transfer case fill plug?
- CB install with SWR meter
- trailer wiring
- Any Bad Auto Trac push button 4x4's?
- Vibrations from 15 mph up?
- Heavy Duty vs Z71
- Heavy Duty vs Z71
- 1989 suburban info
- Temperature Gauge
- Heater not working
- Slight knock when accelerating
- new member
- chevy heater cores
- 2/4 drop kit 96 CK extended cab
- aftermarket headlamps 96 CK
- My minnesotian sisters big bad truck...
- Power window repair
- Hypertech vs. Superchips
- 2002 noise in front end
- 2001 Yukon SLT Engine Dies
- 95 Sub door handle assembly removal
- 1999 2dr Tahoe question
- headlights not coming on
- Gm Truck Owners Sue Over Engine Noise
- Hesitant Engine
- Fuel lines into Intake manifold sub1999
- $$$$$$$$$badass Silverado For Sale$$$$$$$$$$$
- air intake and flowmasters questions
- 1997 Chevy Silverado Rear End
- Adding keyless remotes to '99 Tahoe
- Replace oil pan
- 1990 c1500 with many problems
- 2003 Engine Droan
- heat, ac switch
- front suspension
- what mods have people done to their trucks?
- Brake lights not working all the time
- tranny swap
- Billet grill installation
- '99 Tahoe fuel pump-replace or not?????
- Best All Season Tires
- Vortec Question for a Guru....(heads)
- Engine misses under load
- 2000 Tahoe Keyless Entry
- 98 Chevy Tahoe Tranny problems
- Free press artical on piston slap
- HYPERTECH questions
- Check Engine Codes Specifics
- 1999 Silverado Keyless remote programming (New Body)
- Ticking in top end.. i think..now missing?
- Air Intakes...Factory Warranty question?
- 5.3 Vortec Oil.......What is best?
- Should I..?
- Swapping a V6 for a V8
- Sticking throttle while driving
- More Power
- 1999 burb brake system
- brake systems
- Center Console
- 1997 Silverado Interior lights
- Anybody upgrade to fullsize from an S10?
- Exhaust
- Governor
- 1995 Tahoe remote programming
- Help Fuel Pressure Regulator Location!
- 4L80E help
- 2002 Front end squeaks
- Groan or Grinding noise in Steering wheel -2003 Suburban
- Gentex Factory Mirror Wiring?
- bucking from dead stop
- Lights dim when accelerating?? 2002 LT
- 2000 Z71 (old style 5.7L) Replacement Shocks?
- '88 Sierra 3500 4x4 questions...
- 2003 Suburban: Poor brakes, front end noises gas pedal buzz, AC noise
- OBD II codes on '96 C1500
- 95 6.5 Diesel shuts off while driving
- Modified 1980's silverado
- Rear end Vibration. Any Help!!!!!
- 98 keyless remote part#
- automatic thoughts
- Vibration AFTER installing Flowmasters????
- fix it or replace it????
- Roof Marker Lamps
- 03' Tailights
- vent control not working
- 99 Stock Fog Lights
- Where is #1 on cap???
- adding buckstop bumper?
- tire sizes
- backfiring in the TBI
- Front Hubs or CV joints bad?
- Just bought a 2002 LS Tahoe 5300 - steering klunk question
- Antilock Brakes causing vibration
- New Duramax motor!
- Looking for modification ideas...
- new bed
- changing bed
- Exhaust
- 1999 4x4 maximum tire size
- Back Seat headrests
- 84 silverado c10 vacuum lines
- Vibrations at 57-65 mph!
- I'm gonna go crazy, does anyone have any ideas?
- What temps are you guys running at?
- Heat vs. A.C.
- Lift Kit
- Re: Hard starting and surging lighter loads
- Radio light out,how to repair?
- hesitation
- 1991 K1500 Rough idle
- Water sound under dash when accelerating
- 2500 Crew Cab!?!
- Drl Lights Not Working
- QUick Help w/ Radio question
- used silverado
- wheel lugs
- 1997 Tahoe will not start
- Rearview mirror w/temp
- lifter ticking in 2001 2500HD
- Tail lights not working properly
- electrical
- getting a better ride
- 02 tahoe keyless entry, Please Help
- 2000 Surburban stalls
- Keyless Entry Programming for a 1997 Silverado Z71
- how do i post pics
