View Full Version : Sorento
  1. 2016 Horn Wiring Harness
  2. 2004 Kia Sorento 3.5L V6 Upper Oil Pan Removal
  3. Rattle in Steering Column - 2016 Sorento LX FWD
  4. 2014 Sorento EX - P2098 code
  5. 2008 Sorento A/C fan
  6. Marker light will not shut off!! Help! :(
  7. What milage to trade in your Kia Sorento.
  8. 2015 sorento 3rd gear transmission lag
  9. Tune up help 05 Sorento
  10. 07 trailer light plug problem
  11. Buy or not to buy Kia Sorento?
  12. Kia Sorento Door
  13. Sorento no start. Crank sensor ????
  14. Dont's buy a Kia, they are junk
  15. The car alarm sounds when I try to start the engine. Engine does not turn over.
  16. Brake issues??????
  17. 2008 Kia Sorento code P0504
  18. tpms for Sorento
  19. 2014 KIA Sorento 5Minute Drive Episode
  20. 2003 Sorento the starter turns over slow
  21. 2003 Kia Sorento wont shift into overdrive and ac/heater has no play
  22. 2003 Sorento banging at speed Help
  23. 2003 Sorento 3.5 V6 Only has spark on 2 cylinders
  24. Limp Home Valve Malfuntion (P2106)?
  25. 2006 kia sorento won't start.
  26. 2003 kia sorento Gauge
  27. KIA Sorento 4x4 stuck on 4x4 low
  28. Kia Sorento 3.5L 51,000 collapsed tensioner
  29. 2006 Sorento Heater Core Replacement
  30. Another headlight problem
  31. Maintenance Costs
  32. 2006 KIA Sorento mis firing
  33. 2004 Sorento 4x4 just comes on at random speeds while driving???
  34. Kia Sorento fuel pump diesel
  35. Headlight ground
  36. 2006 Kia Sorento head light
  37. Transmission filter kit.
  38. Gas Filter Number
  39. 2011 Sorento EX AWD
  40. Is a salvage Sorento worth buying
  41. 06 crankshaft bolt broke ? is this common with less than 60K ?
  42. Help!! Is the timing belt a warranty covered issue?
  43. 4LO engages on its own while driving
  44. New Kia Incentives and Rebates – Dealer Negotiation Tricks Email
  45. 2005 Gas Gauge Problems
  46. Headlight retaining clip lost- Sorento
  47. 05 sorento ac diagram
  48. kia die's
  49. no acceleration going uphill '05 Sorento EX
  50. Top Tier Gas retailers
  51. 2004 Sorento overdrive light flashing....help
  52. Borrego or out the door
  53. Sorento vs Santa Fe
  54. Stand by me
  55. Sorento's for Hairdressers?
  56. VA/NC/WV/MD Anybody?
  57. Is a Rover Worth 22K more?
  58. Quiz Question
  59. 2003 Sorento ex with no acceleration at times
  60. Sorento U Joints
  61. 2006 Kia Sorrento Rear Pads
  62. fuel tank temp sensor
  63. Timing belt
  64. Driveshaft problem
  65. Remote door programming
  66. new 2007 sorento owner, so far so good but a concern, knocking
  67. 2010 Kia Sorento replacement
  68. How I arrived with KIA
  69. An Old Fart’s simple answers to all the really important car questions
  70. Oil filter for Sorento 2008 3.8 EX
  71. Great video
  72. Kia Re-sell value
  73. Driveshaft Bearing?
  74. used 2003 Sorento,snow button?
  75. Need you guys to check something in your Sorentos for me.
  76. Sorento (D) light burned out on guage cluster?
  77. New Kia Sorento 2007
  78. Kia Sorento Video
  79. brand new kia, lemon? help!!
  80. 2006 warped front brake rotors
  81. Sorento Reliability
  82. bad switch in power driver's seat
  83. Help replace front & rear differential fluid
  84. Rust on 2003 Sorento trunk door
  85. '05 Sorento EX fog light bulb replacement
  86. Daytime running light problem? 2004 Sorento LX 4x4
  87. P0507 Help
  88. Takes a lickin', keeps on tickin'
  89. Kia Smells-new girl help please
  90. Kia Smells-new girl help please
  91. Kia Smells-new girl help please
  92. AC smells
  93. Step bar fasteners
  94. Keyless remote programming
  95. Looking...
  96. LED turn signal headlights and taillights?
  97. I need an OEM Stereo
  98. Rustproofing and warranty.
  99. Just bought an 05 LX.......
  100. Climate Control
  101. Sorento Blues
  102. Lights burning out
  103. Shocks
  104. Kia Sorento Rearend problems
  105. kia sorento wheels
  106. Wood Trim on 2005 EX
  107. fog lights...need help/info!!
  108. Tail Gate Rattle
  109. Engine ticking and harsh metalic sound
  110. Muffler Question
  111. Twice burned by KIA
  112. Sorrento Brakes
  113. 2005 sorento
  114. Side impact results
  115. Whats that button do??
  116. Car seat covers
  117. Buying Sorento - need info
  118. Buying Sorento - need info
  119. Kia Sorento in Commercials
  120. Why isn't there a sorento forum?
  121. Frustrated... Sorento
  122. New Sorento site
  123. Back Window Wont Latch, Sorento 2004
  124. 03 Kia Sorrento Maintenance
  125. Sorrento 2004 rumble
  126. What should I pay for the Kia Sorento?
  127. Kia Sorento... good car ?
  128. Kia Sorento is a knockout!
