View Full Version : Sebring | Sebring Coupe | Convertible
Pages : 1 2 3 [4] 5
  1. no heat- Electrical
  2. Help!!
  3. Water pump & timing belt
  4. vanity mirror light
  5. New carpet & Upholstery
  6. Auto Dimming mirror needed
  7. turn signal stuck
  8. 2002 Sebring Heater
  9. my sebring mod list
  10. Is this possible?
  11. Serpentine Belt
  12. 98 sebring lxi parting out
  13. Shocks or Struts on 97 coupe
  14. Seat heaters
  15. '98 sebring emergency brake
  16. cruise control speed, is it accurate?
  17. Engine removal 2000 2.7l
  18. High Idling
  19. Heater only on high, after restitor change
  20. dash lights won't work on 98 jxi limited
  21. 1998 Chrysler Sebring Overheating
  22. Is $550 to much?
  23. Speaker Removal
  24. MORE transmission trouble
  25. Keyless Entry Problem
  26. '98 convertable leaking water into the cabin
  27. Can't remove Plug Coil!!
  28. 2001 Convertible (top)
  29. 2001 sebring battery dicharging
  30. Need Exhaust Tips
  31. radio compatible
  32. 97 Sebring JXi Fuel Gauge Problem
  33. Data Link Connector Numbering
  34. new owner
  35. Starter Removal
  36. smoking sebring
  37. Problems starting
  38. 2002 Sebring Programing key
  39. 98 Sebring Conv. stalls at low speed
  40. 95 Sebring
  41. 1998 sebring has no spark, it wont start
  42. engine fuses blowing
  43. 98 Sebring JXI Remote & Radio
  44. Post Tune-Up Problems - ALL Advice Appreciated
  45. How to diagnose radiator fan issues
  46. 98 Sebring Convert RF hum
  47. 98 Sebring Conv - oil level
  48. 2001 sebring conv.2.7 engine needs a boost
  49. Installing Airbags
  50. 97 Sebring Blower Switch only works on high
  51. please help me with brake light
  52. 99 sebring # 8 fuse blows
  53. Chrysler letter
  54. electrical issues
  55. RPM drops to zero while driving
  56. 99 Sebring LXi Coupe
  57. Engine Problem
  58. Electrical Short Possiby???
  59. 98 Sebring Interior
  60. remove the governer on trotle fro more speed
  61. Factory 17 inch alloys for sale
  62. 05 sebring signiture
  63. Door locks
  64. 96 Sebring Won't Restart After An Hour
  65. Keyless entry?
  66. looking way to unlock trottle lock
  67. Code 301
  68. "98 Sebring convertible problem
  69. Help with replacing front bumper for Sebring convertible
  70. Electrical Problem
  71. Turn the key, then nothing.
  72. Convertible Top
  73. Transmission Shift Noise
  74. Help! Oil pressure HIGH????
  75. PROGRAMMING INSTRUCTIONS for 04 Sebring
  76. 1998 chrysler sebring conv. battery issues
  77. Water in Rocker Panel
  78. fuel pump problem
  79. Spoiler Needed
  80. Fuse problem? Wierd electrical
  81. Antifreeze leak
  82. wiring schematics
  83. o2 sensor on 98 sebring convt
  84. After new battery put in it starts but wouldn't idle at low rpm
  85. what is the problem with starting
  86. 1995 Sebring LXi "FOR SALE"
  87. Tranny not shifting
  88. squeaking in front end area
  89. Chrysler Sebring Blower
  90. Fuel guage all messed up!!!!!!
  91. 1996 sebring tranny problem
  92. blower switch does not work at all!
  93. idling on rev high
  94. Most bizarre thing
  95. Several more problems with 96 Sebring
  96. loud roaring at higher speeds
  97. gas tank for 01 sebring lxi
  98. 1996 Sebring Convertible Headlight Bulb
  99. Spark Plug Change & Timing Belt
  100. A30 Fuse issue
  101. Owners Manual Info
  102. Chrysler Sebring Transmission problems
  103. Advice? Looking at '05 to buy.
  104. blower works on 1,2,3; not High
  105. 2001 Chryler Sebring won't start
  106. 97 problem with power steering/AC/battery
  107. water dripping from underneath pass floor board
  108. Lack of power
  109. Seat belt problem
  110. 95 Sebring SRS light won't go out
  111. missing at 55 mph - 99 Sebring
  112. idiling problem - 99 Sebring
  113. Timing Problem?
  114. Low Fuel Level Warning Light
  115. key programming...
  116. ignition wires
  117. Power top hydraulic line replacement
  118. Does anybody have a 1995-2000 sebring convt?
  119. 01 Sebring Convertible Side Skirts
  120. It's the motor mounts, right?
  121. 96 JXA cooling fan won't start HELP
  122. Horn Problem... Unbelievable!
  123. Help with flushing the radiator
  124. 97 Sebring JXi: Loosing all electrical and getting "Ccd" Error Message
  125. Sebring overheating
  126. 98 Conv JXI Oil Pressure Switch Leaking
  127. common problems in Sebrings?
  128. top will not go up.
  129. Anti Freeze Leak 2.5 V6 1997 Sebring
  130. Cruse Control Problem
  131. one bad rim need to buy replacement
  132. wanted and looking for keyless entry program for sebring 2001
  133. No Start Situation
  134. Car For Sale!!!
  135. 2001 Sebring Power Mirrors
  136. 2001 sebring keyless entry programing
  137. Electircal Problem? Dash Radio Flicker
  138. Convertable Performance Mods
  139. 99 sebring key wont turn!!
  140. Daytiem Runnign Lights
  141. Tranny problem
  142. '97 Squealing Brakes
  143. Difference In Sebring JXI and JX?
  144. oil coming out of exhaust
  145. 98 cnvt front end thumping sound
  146. convertible tuneup,is it easy?
  147. Air bag light keeps coming on?????
  148. 98 JXI 6-CD changer adapter
  149. Location of OBDII port
  150. changing air filter
  151. Warning about jacking up Sebrings!!
  152. Transmission Overheating
  153. where to buy accessories?
  154. 95 lebaron oil pump change?help
  155. 98 Sebring Lxi speaker sizes
  156. Good Tires????
  157. Sebring owners
  158. Timing Belt
  159. 98 Sebring Conv. Top Motor
  160. missfire and backfire
  161. Rusting Shock Tower
  162. Keyless Entry Remote Programming For A 97 Jxi
  163. Does it worth?
  164. Won't Start
  165. 1997 sebring jxi
  166. Engine braking during cruise control
  167. Rims
  168. programming keyless entry
  169. LXI w/Infinity Sound System
  170. 97 JXI starts when engine cold but not when engine hot
  171. location of the fuel filter on a 95 sebring
  172. turbo thoughts? help!
  173. transmission hesitation
  174. 1999 Sebring Convertible JXI
  175. 1999 Sebring Convertible JXI
  176. Eng. Noise
  177. Manual avail on 01?
  178. 200 Sebring Low Idle
  179. 98 LXI tweeters
  180. 1998 sebring won't pass smog
  181. Ignition lights went out & won't start
  182. digital odometer goes blank
  183. Sebring starting problem
  184. 2001 v6 starter location
  185. aftermarket stereo help
  186. overdrive vs drive
  187. 98 sebring conv. 2.5 misfires runs rich
  188. 2000 Sebring JXI Backseat removal
  189. dark transmission fluid
  190. Sebring loud squeling noise
  191. "01 Sebring Sedan with blown engine - HELP
  192. Need this answered...
  193. 2001 Sebring Conv - Radio lights blinking
  194. Need Help With OBDII CODE READER
  195. What does a EGR Valve do
  196. partingout 95 sebring & 96 cirrus
  197. 1998 jxi won't start when fuel < 1/4 tank
  198. Sebring cooling fan/ Please help
  199. LXI stereo
  200. torque converter
  201. Need info on 01 Sebring
  202. What are the best brand of tire to run on my 02
  203. Remote Keyless Entry - RC failing
  204. Smoke coming from heater vents
  205. should i buy this??
  206. 1999 Sebring Tranny Troubles
  207. Thinking about buying a sebring
  208. 97 sebring stalling and misfiring
  209. Exhaust ?
  210. kill switch
  211. electrical issues radio/door locks/fan dial
  212. radio wiring diagram
  213. Map Sensor
  214. '96 convertible 2.5L dohc timing belt install
  215. Starting problem
  216. dash board lights flickering
  217. AC mode panel problem
  218. Sebring power steering problem??? HELP!
  219. Blow interior lights (96 sebring lxi)
  220. Top not working and mirros out
  221. 2001 Sebring Sedan Water Leak
  222. 95 Sebring Transmission replacement
  223. help???
  224. wifes car wont start 1997 sebring
  225. Electrical glitch
  226. Electrical glitch
  227. WTB Sebring
  228. Brake Light Flicker
  229. Steering Wheel / Ignition Lock
  230. Location of the car battery for a 99 Chrysler Sebring convertible??
  231. What Works The Fan??????????
  232. 97 sebring coupe 3600$ is it worth?
  233. Radio differences
  234. radiator fan has stopped 4 days and then works again?
  235. Adding an inline converter
  236. Keyless Entry Remote Programming Instructions 00 Sebring ??
  237. Sebring convertible rear window unglued
  238. 99 Sebring Convertible jx
  239. help!!! having a electrical problem!!
  240. 2001 sebring cup holder/ashtray light
  241. 01 sebring heat cuts in and out
  242. 1999 Sebring Fuel Filter Location?
  243. 99 Sebring Convt stuck on Defrost
  244. 1999 chrysler sebring keyless entry reprograming
  245. 01 factory alloy rim
  246. ingition key not working
  247. sebring 01 was overheating now wont start
  248. Stalling problem
  249. wire colors
  250. Sebring Tire Pressure
