View Full Version : Skylark
- Skylark Engines
- Thermostat replacement in 97 Skylark with 3.1 L engine?
- 3.1 Liter very poor mileage, no engine light
- 86 skylark, somerset 3.0
- Airbag Replacement 1995 Skylark
- Hard Shifting/Cruise Control Intermitten
- p1697 Diagnostic code
- How to check window/switch 1996 Skylark Custom
- 96 Skylark - Crank No Start
- Airbag Readiness Light/Horn Won't Work
- 96 buick skylark not running
- 94 buick skylark manual
- noisy engine
- 97/98 skylark service service manual (and horn relay)
- Engine Acting Up
- 1991 skylark 2.5l rough idle, puffing exhaust
- 1996 Buick Skylark HELP!
- Buick 81 code 44
- 350 motor to 455
- 1996 Buick Skylark Torque Specs
- 1996 Skylark Passlock Bypass
- Trans stuck in park
- 1992 Buick Skylark starting problems
- what kind of coolant?
- buick stalling
- 1981 Buick ECM
- Heater core
- torque converter cover (dust shield)
- Problems with stalling on car while in motion
- 96 skylark fuel filter
- Water on floor of 1996 skylark
- Transmission problems...
- 98skylark cooling and heater problems
- running lights are out
- 1994 Skylark Transmission
- My moms bad week(95 Buick Skylark Cstm 3.1L)
- 68 Skylark Tranny
- 1976 skylark radio
- 89 Buick Skylark
- rusted firewall
- 98 skylark fuel pump location
- 91 Skylark Speedometer
- 1969 buick skylark....Need parts.
- Engine Swap
- 92 electrical problem
- Battery drain
- oxygen sensors
- 1991 buick skylark pcv
- 1996 Buick Skylark Question
- 89 Skylark Transmission Swap
- 95 Buick Skylark Custom 2.3l Problem with Parking
- 96 with a slew of problems
- 94 skylark 3.1 codes?
- '93 Skylark hard/cold starts
- 90 Skylark, 2.5, 80K mi. Acceleration problem
- thermostat valve on dash
- 92 Skylark 3.3 Oil pump?
- 92 Skylark Quad 4 Sparking From Crank Pulley to Timing Cover Bolt???
- 97 buick sylark 2.4 quad 4 engine
- 3100 engine bogs down
- 93 Skylark..puzzels me.. help!!
- 92 Skylark 3300, died, fuel pump? ugh, no
- 96 Skylark rear speaker(s)
- Engine turns over but getting no spark
- '94 Skylark 6cyl Won't run in drive, but will in D3..
- 91 Buick Skylark Custom
- 97 skylark electrical issues
- 98 Buick Skylark Driveaxle
- 91 buick skylark engine and tranny question
- 91 buick skylark-transmission low fluid??
- 1994 Buick Skylark Hazard Relay Replacement
- 96 Skylark starting problem
- 1996 skylark power steering hose replacement
- 95 buick skylark - recharge port for a/c?
- missing out when warm?
- 1996 gas gauge not accurate
- 89's skylark converter prob please help!
- Fluctuating Speedometer Gauge
- 1981 skylark doggin me
- need help
- Aftermarket Radio Issue
- 91 buick skylark- need help please
- '97 Skylark - scanner unit
- 1983 buick skylark g. s.
- 1994 Skylar 2.3 liter 02 Sensor problem
- 97 Skylark LEAK!!! FIREWALL??
- 93 Skylark heat issues
- 1997 ABS System activating unexpectedly
- 1997 Buick Skylark 2.4L AC Bypass Pully
- Timing ?
- 95 buick skylark headlights dont work
- 92 skylark wont start intermittantly
- rear brakes
- 1994 Buick Skylark air bag light on
- 89 2.5L starts then dies immediately
- 1994 Buick Skylark Gs 3.1 sfi
- 1991 Skylark race car help
- 1996 skylark Back window problems
- 98 Skylark horn relay location
- 91 Skylark Ecm
- 93 Buick Skylark - ca'nt turn the key off
- Coolant loss
- 94 Skylark low pressure port location?
- 88 V6 3.0 tuning
- Odd problem
- 94 Skylark 3.1 high idle on cold start
- '90 skylark 2.5 window, speedometer, & odometer problems
- Transmission slip?
- Dash blinking lights and says Theft
- Transmission pan part
- 1993 buick skylark
- could someone please tell me
- New Owner of a 95 Skylark 3.1 V6 PLEASE HELP!!!!
- Radiator transmission lines/coolant flush
- head gasket snake oil
- Need help/fuel gauge
- 1992 Skylark GS V6 w 3spd auto, converter lock up schedule
- how do you put a heater core into a 92 skylark?
- 91 skylark not getting fuel
- 92 Buick Skylark, Automatic, only drives okay in reverse
- looking for relays and fuses under hood 95 skylark
- 94' smoking from spark plug
- Buick Skylark 1993 Floor Leaks H2o
- No tail lights
- 94' Skylark 2.3L - Rebuilt Head and Now Overheats
- getting codes on a 91 skylark
- Just doesn't start =[
- Wheel Cylinders
- 92 Skylark GS Electronic Shocks, Where did they go?
- 1993 Buick Skylark V-6 wiring or fuse problem
- 1996 Skylark starter relay ?
- Blower quiet and low flow
- Hello! New owner
- Motor Mounts N body 1992 Buick Skylark GS
- 1996 Buick Skylark gas gage
- 1995 3.1 buick sylark coolant issues
- 96 skylark i'm getting code P0420
- crankshaft sensor
- 1996 buick sklark gas gage werid
- ABS Light problems
- '96 skylark brakes help
- Car won't start after installing used instrument cluster.
- 1993 Skylark Custom 6cyl. Slow, shuddering from a dead stop.
- '94 2.3 quad 4 thermostat
- 1993 Buick Skylark 3.3L ignition problem....location of Fuel Pump Cut Off Switch?
- 1996 Buick Skylark -water, water everywhere!!!
- 1992 Skylark 3.3l No Fuel through injectors
- no brake lights
- 1996 SKYLARK Sparkplugs
- 1993 Buick Skylark A/C Retrofit
- mid 90's Skylark vert.
- buick 455 engine decode...Need help
- How do you install a driver side electric window motor? All helpers get a virtual hug
- 93' Skylark *whole Slew of Problems*
- wanted 1969+ gm a body roof top section
- 72 skylark rear axle posi installation..Help needed
- Car key and ignition problems
- '97 Skylark shudders, dies
- Hrspwer tips on older car
- 69 skylark SCO ,info needed.
- Buick Superbeast
- 1996 BUICK SKYLARK... HELP!!!! please
- Need info about parts that fits on a 1970s skylark
- 96 Skylark window relay
- automotive flashers
- sea foam engine stall
- 91 Skylark #1 and #4 cylinders quit firing
- steering column will not lock in place
- 97 Skylark Temp problem
- 96 skylark tranny
- 88 Skylark,engine stalls after warm-up
- 1994 Skylark Custom SVC ENG LGT - 55 up
- Wiper motor question...
- Crumbling Blower Motor Cover
- 93 skylark 2.3 wont start
- 88 skylark - alternator belt tensioner replacement
- Radio Issues
- 96 skylark overheating- help
- Need info on Skylark...I think...
- 1996 Buick Skylark 3.1 No Start Problem
- 94 Buick Skylark, intermittent starting issues... Help!
- 96 Skylark stalls in hot weather
- Keyless Entry/remote Issue
- 1997 Skylark Horn Issue
- 1996 skylark a/c question
- Help! 94 Buick Skylark 3.1 overheating issues
- Tranny Swap
- Need help with heater problems
- 86 buick skylark
- 1998 skylark turn signal location
- 94' Skylark power steering belt change
- 89 Skylark, transaxle solenoid
- Need Replacement Light
- 1995 Buick Skylark Voltage Regulator
- 1998 Skylark Running Ruff At Idle
- 94 Thermostat Location
- 1995 Buick Skylark service engine light
- ignition problems
- check engine ant ETS light = bad EGR valve
- need help with 02 sensor 92 skylark 3.3
- 96 passlock I ?
- 94 skylark changed bulbs now won't start
- thermostat for 95 skylark gs
- 1977 Skylark, more power.
- transmission problem code
- 94 skylark no crank / start problem
- Problem of slow on my Buick
- 1971 Skylark
- 92 3.3 engine swap
- 93 3.3l
- 94 skylark, overheating ?
- 1997 Skylark Re-Learn Theft System...
- 1998 Buick Skylark stall,leak,key probs.Good car
- New and Old Members Please Read
- Need help!
- 81 buick skylark tranny trouble. Please HELP ME!!
- 95 skylark stalls when put in gear
- 97 Skylark Knock at high speed - HELP
- Need Help With Firing order on 98 Buick Skylark 3.1
- 1967 Buick Skylark convertible
- Vacuum Diagram for 1998 buick skylark 3.1 engine
- 96 Skylark 3.1 V6 fuel pump relay location
- 96 Skylark rear window motors
- 96 Skylark 3.1 int start issue
- Need help on how to build a buick 350 1968
- '91 skylark 2.5 question
- 1992 Stalls out
- 65 Special/Skylark
- passlock
- 1992 buick skylark does not restart after running
- P1134 HO2S - Code?
- 94 Skylark - Running lights but no headlights
- Water leaking into the oil pan
- 89 Skylark 2.5L fuel not going thru injector
- 1989 3.0l crank-camshaft sensor
- 97 Skylark Keyless Entry
- Range on key remote-Buick Skylark
- 1996 3.1 Thermostat
- 1989 3.0l engine
- 1991 Buick Skylark Seat Seat Problem
- 88 Skylark wont start anymore
- Buick newbie. '72 Skylark.
- 97 Buick Skylark Quad Four
- 95 Skylark horn relay location
- 93 Skylark 3.3 Sputtering Badly Please Check Out
- 1996 window motor keeps burning out
- 3.3 V6 Engine Trouble
- 1991 skylark, Wide open idle problem
- transmissions
