View Full Version : Pick-Up
- how do I bleed the gas rail
- 92 Toyota rims
- thanks
- Code help...
- Truck is driving me crazy........
- 86 toyota p/u wont start
- Front brakes freeze up after driving!?!
- I want to turbo my 1993 22R
- Transfer Case Stuck In 4wd
- 1992 deluxe toyota pick-up
- 84 toyota pickup-starting/electrical problems
- Excessive Pinging
- 1985 Hilux 4 speed to 5 speed ?
- Driving without doors
- 85 toyota aftermarket gauges
- 82' yota sr5, stereo removal and installation!
- 22r-e S-AFC?
- 1990 toy carburated running poorly
- 89 toyota will not turn over W/ new starter, batterie, and alternator
- 22r to a late 80's Supra Swap?
- 22r Can you convert to EFI(fuel injection)
- My Pick-up rides ROUGH!!!!!!
- rough starting
- gargling gas
- 82 22r carb problems
- 5 bolt to six bolt swap questions (hubs/rear end)
- Replace 5 bolt 1 ton rear end with 6 bolt
- 22r-e to 3RZ?
- No dash lights...HELP!
- Speedo cable replacement?
- 1984 Pickup, how to install antenna
- Toyota Diesel wont turn over
- Rebuilding 1986 Pick-up 22R engine with A/C
- 1992 2WD llits kit
- Steering wheel...?
- 82 toy truck charge lamp
- 1986 22R-E Rough Idle
- timing chain too short or too long
- seized fill plug
- timing chain questions
- stereo wiring probs
- 1984 2WD pickup, adjusting choke...what allen wrench size?
- Any A/C guys out there???
- release same as slave?
- Rotor to Pad Clearance
- 93/4x4/offroad/parts/money
- Brakes-Can't get piston back in caliper
- 22r-e timing chain problem
- 5.0 engin swap
- 1991 4X$ Toyota Pickup hard to start when warm
- How to disconnect speedo cable...1984 Pickup
- No dash lights and won't start
- Throttle senser
- Rotors
- 1984 2WD pickup, tracking down a short...isolating circuits
- 3.0 v6 swap to a carb. 22r need help!!!!
- Quick shout out
- Cigarette lighter help
- Brake pedal travel
- Problems with 1982 Toyota 4x4 pickup
- Clutch Fan?
- 89 toyota pickup V6 EFI Won't start
- 89 toy pkup 6cyl Ignition Ignitor test
- 89 Toy Pkup 4x4 6cyl (3vz-e) No Spark
- '92 toyota pickup won't start
- 1990 Toyota Pickup 22R fails CO2 emissions
- emergency brake light
- big lose of power running lean help
- ignition timing irratic
- Preformance headers
- 92 4wd gas mileage
- Turn sigs, fuel gauge, temp gauge don't work, Haz light works 1984 2WD pickup
- 22r to 22re engine swap
- Tire Noob Question
- coolant leak
- Power Steering
- differences in years
- Front Differential Removal
- 86 toy 4x4
- Wiring Diagrams
- 92 having problems
- 92 4wd 3.0 ext cab 57000 having issues
- Parking/Emergency Brake BROKE?!?!
- problem with ignition
- High and low idiling after warm up
- Click / Flap Noise
- Heater core
- 85 4X EFI Firing only 1 & 3. Test says RPM Help
- date of manufacture
- Congested noise at high rpm
- 86 toyota pickup, clutch swap, questions
- clutch woes
- tacoma or Regular PICKUP???
- 1989 Pickup Oxygen Sensor mounting nuts.
- 1989 4WD 22RE real high idle!
- 1989 toyota pickup- gas leaking out of charcoal cannister
- need advise on tranny and possible motor swap
- 22re makes loud tapping sound
- '92 Toyota Engine hard to turn over and will not start
- 91 Sr5 V6 3vez Does Not Start
- front end tie rods for steering...how hard is this to do?
- overheating problem!
- 1988 toyo p/u 3.0 smokes badly from oil filler and has no power
- Hesitation, is this fuel related?
- Backfires Crazy Like
- Is it the brake booster?
- 1989 Toyota pickup 22RE won't fire
- Ring and pinion issue
- how to change cluster light
- 94 pickup gear shift removal
- Totally f****d up 88 toy 4x4 pickup....please help?
- how important is it to replace the timing chain?
- whistle / ringing noise at idle ??
- Excelleration Vibration
- New Engine Won't Run
- engine swap
- prime oil pump 3vze engine
- Wiring harness diagram
- Reverse lights
- Toy twuck with a hiccupp
- 1986 toyota pickup
- Help for my 19 yr. old son
- What's Normal Compression for a 22R
- No Trailer Brake Lights on 89 Toyota Pick-up
- '94 pick-up 2wd acceleration issue...
- Indiglo Gauges
- 88' pickup won't start?
- to 350 or not to 350
- 91 P/u
- Clutch Help
- 92 Toyota Truck V-6 engine lacks power, 3.0L, help!
- '92 4x4 with a Whine in the drivetrain
- 4x4 indicator light
- tailgate lock
- emissions control system cancelation
- V8 into the ole 83
- Engine swap--What clutch kit to use????
- Torsion bar adjustment
- '90 4x4 3VZE - really hard starting in damp/wet weather
- air bags
- How do I remove/install the sway bar??
- Toyota Classified Forum
- 89 22re oil in coolant resevoir
- 92 3.0 4x4 short bed delux.
- New Toyota Classified Thread
- 1984 Toyota Pickup
- Intermittent Door Rattle or suspension
- new electric fuel pump not working !!!
- need help from everyone!!
- need help with carb efi swap in 83 toyo p/u
- O2 sensor and Intake and Exhaust
- '85 straight axel noise in 4wd
- 89 Toyota 4x4 PU turns over but won't start
- 85 toy pu engine swap no spark
- 1989 toy 4x4 Intermittent Start clicks
- Disc brake conversion 91 2wd 22re
- 22RE Timing - 1994
- Transmission
- Gear Reduction help
- 22ret value
- want to buy
- 1992 Toyota 4WD Pickup-22REC
- 22re performance mods
- 22RE valvetrain
- want to buy
- LSPV Rod
- buick engine or ring and pinion swap
- mileage ?
- Off-road Tires
- 94 sr5 need hinge for moonroof
- AC problem
- Car bras?
- Rear Diff 1989 4x4
- 22RE Issues
- sagging door
- 84-88 wheel wells
- do it yourself 83 Toyota manulas?
- Climate control panel light dead after CD player install
- '92 Pickup - Removing Door Panels?
- Toyota 1989 4x4 / new to forum
- Charcoal Canister Overflow
- 87 Toyota 22RTEC?
- 81-83 trekker
- 1994 Pickup auto tranny problems and crappy gas milage
- cheap cheap dirt cheap body parts needed
- 1989 Toyota 4x4 truck power steering gearbox.
- tach install question
- 1991 Toyota Pickup Interior Door Panel
- Is this a good idea???
- wierd overheating problem
- car battery
- 87 toyota 4x4 22r rod bearings
- throttle cable
- water hell
- transmission
- 1989 6 cylinder. check engine light after 20mph
- oil leak
- Heater light...
- BAttery cables or Alternator...HELP!!!
- 85 toyota pickup question
- wiring problems...
- have 35x17.50x15 what to do
- cluch start cancle
- belt squeal
- Grinding noise when starting
- Oil Change Frequency?
- Headlight problem--very strange
- recycled oil in a rebuilt 22r?
- Oil Leak (head gasket)...How Do I Fix
- 94 toyota pick-up truck front shocks
- chirping when clutch is out
- 94 Toyota pick-up SR5 V6
- blowing fuses
- Crakced Block or Head gasket
- conversion
- Idle too high and too low
- Exhaust Help
- Speedometer and 4X4 On Light
- Tail (running) Lights Out!
- 1994 tachometer installation trouble
- 1990 Toyota 4x4 Front Alignment
- Barrell connectors near coil
- 22R-Te Ignition Timing
- 89 4x4 Timing Belt
- 1988 Toyo 4X4 clutch help needed
- extra cab longbed-why did toyota stop making it?
- timing 22re
- 22re engine suddenly dies
- How to Install Cd Player in 93 Pickup
- yoda problems again
- 22R Engine swap What years interchange
- Bench seat in 87 4x4
- HELP swap 22re in my 84 toyo and then turbo
- Downey Header On 3.0 Auto
- 86 Toyo PU Minor Starting Problem
- seats in a truck bed
- I Need One!!!!
- 89 Toyota PU been sitting, won't turn over. Possible kill switch?
- dashboard removal?
- what trucks are the same
- lifting a 2wd '85 yoda
- Engine specs
- Tranny wont shift into high gear
- Low rpm misfire - 91 22RE
- 1994 Toyota Pickup 4x4
- grease like sludge in radiator HELP!!
- Vibration between 45-55 mph 91 2wd shortbed
- Manual tranny pops out of gear
- Looking for a blue v6 Ext cab Toyota 4x4 89-95 in Tacoma/Seattle!!
