View Full Version : Lumina
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Not starting after new timing chain...HELP!
  2. Digital speedo
  3. 95 Lumina dash lights
  4. Pcv Question?????
  5. Cooling problem
  6. Brake fluid? Or some other Problem
  7. ac blows on the floor when i step on the gass
  8. Got The A/c Converted To R134a
  9. rear wheel seals
  10. 93 Lumina ... Gas tanks ?
  11. 1995 Lumina Intermittant Problems
  12. Hypertech Chip
  13. 1990 Chevy Lumina APV - need help with door handles/locks
  14. Lumina start problem
  15. oil cooler on 92 z34
  16. okay not much of a question but you know :P
  17. 97 Lumina Cranks, but won't start
  18. 2000 Lumina 3.1 Lights dim, tach jumps, often needs to be jumped
  19. 95 lumina won't shift
  20. In-Dash Brake Light Flashing
  21. Arrrrrrrrrgh!
  22. 97 Lumina Starter
  23. How do I reconnect the battery cable?
  24. 97 Lumina Starter
  25. Now What Wrong With It?
  26. 94 lumina electrical problem
  27. 92 lumina engine problem
  28. 1996 Lumina 3.1L No Power
  29. 1990 chevy lumina
  30. '96 3.1 exhaust leak?
  31. 1996 Lumina turning signal handle
  32. Need some help making a decision..
  33. 1993 Lumina Euro 3.1 Problems
  34. How much oil do i need to put in ac system?
  35. Remove pulley from power steering pump?
  36. Oil pan gaskets
  37. 94 Lumina will not start.
  38. What Is Your Lumina's Gas Mileage?
  39. Check engine light P0440, P0171
  40. 98 3.1 Lumina Tune-up Help
  41. 93 lumina euro abs light on , brake light is flashing & making a noise
  42. 4th Gear Problem
  43. 96 lumina overheating??
  44. '95 Lumina motor swaps
  45. Help with 1991 Lumina Euro
  46. 95 lumina 3.4 Tranny cooling lines
  47. 93 Lumina Wierd Idle issue
  48. Yet Another Intake
  49. A/c Question
  50. o2 sensor in 92 lumina?
  51. 96 Lumina 3.1, Plat. spark plugs or not?
  52. need help 92 lumina
  53. The Memcal(chip) in 92 Lumina Z34
  54. Low PSI (55) In 6th Cylinder
  55. why wont it work?
  56. 98 Lumina High Beam Indicator Light
  57. 93 Lumina z34 won't start
  58. 2000 Lumina starting prolem
  59. 92 lumina wont start
  60. Huge hydroplane/puddle = louder engine?
  61. 97 Lumina A/C
  62. 95 lumina over heating Help please :)
  63. Check engine light comes and goes
  64. what now?
  65. lumina problems
  66. Where you at?
  67. big deal or not?
  68. lumina "bucks" above 50mph then dies when brakes applied
  69. 97 engine swap
  70. 96 Lumina Alarm/Security Problem, Won't Start
  71. performance mods?
  72. transmission troubles
  73. 1994 Lumina Z34 Has A Ghost!
  74. Negative terminal on a 1996 lumina
  75. 1994 Z34 Keeps Stalling Doesnt Want To run.
  76. 93 lumina charging problem
  77. 95 lumina ls Issues
  78. What is your Cars history?
  79. Need New Engine
  80. Please recommend plugs and wires for 1993 Lumina
  81. 3.4L D.O.H.C Timing Question
  82. Starter?
  83. 95 Lumina - Overheating
  84. 1999 Lumina Heater Fan Servicing
  85. Lumina Z34 Stalling! HELP!
  86. Lumina Z34 Stalling! HELP!
  87. Help with cruise 1990 Lumina
  88. who are you?
  89. '94 lumina chugs funny and dies
  90. Windshield Wiper Problem on 93 Lumina
  91. 97 lumina door panel
  92. My solution to the warped/curling dash problem
  93. just a dumb question
  94. 92 Lumina stumble under acceleration
  95. IAC ? how do u clean
  96. Help ASAP w/ removing fuel pump? 92 lumina euro
  97. no spark /no power to fuel pump
  98. can anyone tell me?
  99. 97 Lumina Brake Light Problem
  100. Possibly buying a lumina?
  101. Things to get changed at 123K?
  102. 1999 lumina radio installation problems
  103. No Turn Signals - 00 Lumina
  104. 3.8L lumina Ltz smoking.
  105. Lumina 98 Transmission Cooling Problem
  106. 95 Lumina Window prob
  107. drivers doorz-34 lumina
  108. 98 Lumina Wobble.
  109. Fuel pump replacememt
  110. help please
  111. 1995 Lumina 3.1 lifter noise
  112. happen to anyone else?
  113. 95 Lumina Hazard/Signal flasher
  114. 92 3.1 water pump changed now enginge dead
  115. 1992 chevy lumina problem
  116. Code 32 And 42
  117. 97 Lumina car strut replacement
  118. Anybody need a hood? 95-01
  119. Cleaning removed fuel injectors yourself?
  120. 92 Lumina sometimes Shakes when hitting about 50-55 mph
  121. Pulling the ,96 Lumina's engine need some advice
  122. 95 Lumina Speedo problem
  123. I have a 1992 lumina 3.4 liter that sometimes needs to be gassed to start?
  124. INTERMITANT idle and stall problem
  125. 3.4 - 3.1?
  126. 1997 Lumina 3.1 dies after 1st start, then hunts
  127. lumina Z34
  128. Which transmission fluid to use?
  129. how to deactivate alarm in a 95 lumina sedan
  130. Locking issue
  131. Replace 1997 Lumina Heater Core
  132. Seatbelt Light? uggghhh.
  133. Best way to drain out all coolant?
  134. 95 chevy lumina fans don't work
  135. help! driver door jammed shut!!!
  136. 97 Lumina EGR Valve and O2 sensor Question?
  137. Tailligths, dashboard lights off all the time
  138. tip for testing radiator fans
  139. Hard Shifting (1st to 2nd)
  140. 191 CID Aluminum Head Issues
  141. 90 lumnia won't start
  142. How to check Engine Code for '95 Lumina
  143. FS lumina ashtray. '95+
  144. Upsize wheels for 90 Lumina
  145. 98 Chevy Lumina Brake Light/Turn Signal Problem
  146. 1997 Lumina Coolant Leak.
  147. 97 lumina brakes clicking
  148. '92 Lumina Heater Controls
  149. 95 Lumina Sedan cooling Issues
  150. 93 Lumina Euro 3.1 - Idle drops every 60 seconds.
  151. 92 Lumina overheating
  152. 92 Lumina 3.1 missing at part throttle
  153. 1999 chevy lumina Stall and acellerate problems
  154. 93 Lumina Euro Trans Slipping
  155. I know this isn't Lumina But...
  156. 2000 lumina beeping noise
  157. I get 32+ mpg with 92 Lumina
  158. KNOCK KNOCK...ugh
  159. 97 lumina won't run
  160. 2000 Lumina - AutoTransmission hard shifts after warm up.
  161. 1993 z34
  162. Brakes acting strange 97 Lumina
  163. Radio installation nightmare
  164. 2001 Lumina 4t65E transmission problum
  165. Z34 Exhaust
  166. Alt Not Charging
  167. A tip to prevent getting stranded on the side of the road
  168. How to locate and install new TCC solenoid? Quick tips?
  169. Quarter Panel fix options
  170. Cant find Hazard Flasher
  171. 96 3.1 lumina runs horrible
  172. Remove O-ring for transmission filter?
  173. Lumina 1995 LS: Airco hesitation below 7 Celsius
  174. Cruise Control Quit
  175. belt tensioner question?
  176. 1996 Lumina Steering Problem Front End
  177. 1996 Chevy Lumina won't start
  178. Another fuse box somewhere??
  179. 94 3.1 - inconsistent spark
  180. 95 Lumina
  181. 96 Lumina Hesitation
  182. Change oil light
  183. 4t60E transmission
  184. 1997 Lumina End Links
  185. egr causing problem when disconnected
  186. Radiator coolant not filling up
  187. 1992 Chev Lumina 3.1L (T) Turn signal fuse blows out all the time
  188. Rear brakes... smoking
  189. Crankshaft Position Sensor
  190. '91 Lumina inj.?
  191. 91 3.4 Lumina Coolant Dripping from Tranny
  192. Intake for a 3.4?
  193. Help with door Panel
  194. RPM Drop while accelerating
  195. '91 Lumina electrical ? Prob
  196. Electrical problem???
  197. 2.8 or 3.1 fuel pressure regulator needed@!
  198. Leaking and dirty coolant. Need help asap.
  199. 92' z34 color codes
  200. 91 3.4 Tranny Slipping
  201. 97 Lumina Low Coolant Lite
  202. 92' lumina question
  203. '92 Z34 Tranny problem?!?!? (Help Quick)
  204. 90 3.1 Lumina dies then starts when cool
  205. 96 3.1 head gasket help
  206. 1996 Lumina losing coolant, head gasket?
  207. Help with outside door trim - Newbie
  208. 90 Lumina Water Pump
  209. HELP - Messed up my rear disc brakes
  210. Problem with Flashlight
  211. Emergency Signals and Lights + more ('98)
  212. Anyone know how to troubleshoot.....
  213. Help!!! Driving it off a cliff
  214. fuel, but no spark
  215. overheating 96 3.1 Lumina
  216. 1992 3.1 lumina
  217. Lumina Z34 Transmission issues
  218. help with sopmething simple
  219. no start 97
  220. lpg conversion lumina
  221. 1996 3.1L running funny after rebuild
  222. problem aiming headlights
  223. low coolant but no light
  224. How do you time a 92 Chevy Lumina 3.1L
  225. 1993 Lumina 3.1 low idle when warm
  226. Lower intake gasket, which one?
  227. 92 3.1L V6 runs rough/stalls only after a hot soak.
  228. question about lumi wheels
  229. Hard hoses
  230. Rear Struts
  231. code 43...knock sensor
  232. 94 Lumina 3.1 cranks - won't start
  233. Blower motor speed varies with speed
  234. 96 Lumina - Noone knows how to fix (dealers/mechanics)
  235. 99 Lumina overheating
  236. pushrod mix up
  237. swaping lumina engines
  238. 3.1 engine swap has different wiring harness
  239. 95 lumina heater controls
  240. 95 lumina head gasket
  241. 93 chevy lumina runs choppy!
  242. gauges jump with key on but won't start
  243. 1996 Lumina Issues
  244. Radiator cap
  245. 93 service engine, high rev, gas sucker
  246. 98 Lumina Trans/Suspension?
  247. 95 lumina radio removal
  248. disable security system
  249. 97 Runs rough..
  250. 2000 Lumina 3.1L EGR error
