View Full Version : Lumina
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. possible to do supercharged 3.8 bonnie ssei motor in 97 lumina base
  2. rebuild that transmission!
  3. replacing seatbelt on 93 lumina
  4. The plague of coolant leaks
  5. Looking for warning hazard knop
  6. 1992 Lumina 3.1 sedan, oil leak between oil pan and tranny pan
  7. remove rear door with broken latch
  8. 98 Lumina wont move at all in either Drive or OverDrive
  9. 91 - 92 3.1. T.vin to 93-94 3.1 T.vin lumina
  10. 98 lumina alternator plroblem
  11. 1997 Lumina Won't Start
  12. Replace Radiator
  13. problems with dash lights
  14. 93 Lumina Euro tail light problem?
  15. Could someone describe the wiring in my 1992 Lumina 3.1 Sedan?
  16. Could someone describe the wiring in my 1992 Lumina 3.1 Sedan?
  17. 1997 3.1L new starter issues
  18. 1998 Lumina LTZ-sunroof gear stripped out
  19. 92 Lumina rocker arms noisy
  20. how to clear ses light.
  21. Transmission oil cooler
  22. 1999 LTZ driving lights
  23. do i have keyless entry?
  24. 2 different 98 Lumina transmission quirks
  25. 96 lumina newbie
  26. malfunctiong tranny question=-
  27. Transmission "Band Stop" Function
  28. Radiator for Lumina
  29. 91 lumina, acts up one minute, then fine
  30. How much coolant in the heater circuit
  31. 1998 tranny question=
  32. Didn't find the right parts for 3.8L 98 Lumina
  33. Newbie with a problem
  34. brakes make mechanical whine noise
  35. Anti Lock Light is on???
  36. mixing engine oil question=-
  37. seatbelt stuck:/
  38. 98 brake problem=
  39. 2003 Lumina LS doesn't have dashboard lights
  40. 97 Lumina, Randomly wont crank,
  41. Need help with keyless remote
  42. 95 3100 swap
  43. '96 3.1 Blown head gasket
  44. p/s fluid for lumina=?
  45. 91 lumina has bad hesitation after warm up
  46. OBDI scan software
  47. Thermostat replacement, 3.1
  48. Replaced Fuel Pressure Regulator-Worse than before
  49. What hose on the vacuum canister on tank?
  50. what ECU do i have
  51. Engine is shaking
  52. 93 lumina cant seem to find problem
  53. low coolant light, and no fans...
  54. 2 seperate issues, i think
  55. alignment every 160,000 miles=-
  56. 1990 Lumina Euro Odd Probelm when braking
  57. 95' Lumina Sedan, no overdrive? 4th gear?
  58. Antifreeze Leak
  59. Intermittent hard-starting, no codes
  60. Cooling problem
  61. 1992 3.1 Lumina occasional miss - bucking
  62. Weird Thing with the Turning Signal
  63. '96 Lumina Shifting Problems.
  64. 97 Lumina ABS Light On
  65. How replace valve cover gasket on 3.8L
  66. 97 Lumina won't start when it rains
  67. Change your subframe bushings!
  68. 98 lumina
  69. Locate the real problem of oil on exhaust (recall from GM)
  70. need knowledge on how to change out motor mount 95 lumina LS 3.1L
  71. Can anybody help 3.8L vacuum line
  72. 98 hgh brake light problem=-
  73. Right turn grind
  74. Which age of belt?
  75. 98 lumina, couple of things (strut, dash lights blink 90 times)
  76. Need help I must replace the tensioner...
  77. drivers seat belt
  78. '90-'94 Chevy Lumina Headlight System
  79. which Oil I can use?
  80. blowing ecm bat fuse
  81. Replacing ball joint
  82. 97 lumina fan control #3 25 amp fuse
  83. P0300 multi cylinder misfire
  84. have a question or maybe call it a favor to ask
  85. 98 Lumina Neutral Safety switch
  86. Won't start like its in gear.
  87. 98 lumina brake problems, NEED HELP!!
  88. A/C not working right
  89. Wondering if its possible to swap a 3.1 motor from a Lumina and drop it in a 92 Chevy Cavalier Z24?
  90. Simple question about ac ports... Hopefully
  91. radio nightmare
  92. 3.1 runs when cold then dies, won't restart
  93. 99 shift cable replacement problem
  94. Bench Bleeding 96 Lumina sedan
  95. Need help! fuel problems...
  96. Any ideas
  97. 2001 3.1 engine replacement
  98. In desperate need of help!!!!?
  99. Help on Installing Serpentine Belt
  100. Lumina 98 ltz (wheel bearing replacement)
  101. Lumina ltz 1998 idle problems
  102. 2001 Lumina 3.1 cooling fans don't work
  103. Vacuum Canister?
  104. 95 Lumina 3.1 died suddenly
  105. Battery voltage increase when car is turned off
  106. 2000 lumina ac
  107. 98 Lumina LTZ (engine replaced)
  108. Fuel Sender Unit
  109. Weird A/C Cooling Fan Problem
  110. speedometer not working
  111. Thermostat & temp sensor
  112. Radio goes dead
  113. 90 Lumina 2.5 4L cant start
  114. 99 lumina 3.1 heater core inlet hose
  115. 1996 Chevy Lumina ignition problem!
  116. Injectors?
  117. Lumina won't go over 30!
  118. 90 Lumina 3.1 Euro - Gas mileage
  119. 90 Lumina 3.1 - ICM Removal
  120. 97 Lumina transmission shifting problems
  121. 97 Lumina brake problem
  122. 93 3.1 lumina where's my heater core?
  123. The last stubborn vibration left on my Lumina...
  124. 90 Lumina 3.1 - Tips on changing Crank Position Sensor
  125. 3800 to 3800 Supercharged
  126. Overheat
  127. Piece 'o' Cake!
  128. Engine light on after replacing Fuel Pump
  129. 90 Lumina, fuel pump not working
  130. 92 Lumina won't crank
  131. Wtf?????
  132. Lumina Stater Noise
  133. 90 Lumina 3.1 - Cutting off while driving or accelerating
  134. Trap Door To Access Fuel Pump
  135. 93 Z34 Leaking Water/Coolant from Radiator Outlet Tank
  136. Strange noise
  137. 98 lumina ltz hydro locked
  138. location of theft deterent module??
  139. air care no power 95 lumina
  140. Overheating issues
  141. 96 Lumina: Random Multiple Cylinder Misfire
  142. Are Products from "Standard Motor Products" good?
  143. 1997 Lumina looses power
  144. 90 Lumina 3.1 Oil Change Choices
  145. Bad Idle 98 Lumina 3.1
  146. 98 Lumina wont move
  147. 98 chev lumina gear shift issue
  148. Same f*cking problem
  149. 98 Lumina LTZ Idol problem
  150. Best OBD 1 scan tool for our cars
  151. 96 Lumina wont start
  152. 96 Lumina - leaking heater hose connector
  153. 90 Lumina 3.1 - Does your Lumina like non-ethanol gas?
  154. 91.3.1 'warm' starting issue
  155. 90 Lumina 3.1 - Where does your temp guage stay?
  156. 90 Lumina 3.1 O2 Sensor Connector Location
  157. '91 Lumina Euro power steering failure
  158. 90 Lumina 3.1 idle surge / hesitation
  159. Lumina keeps dieing??
  160. 98 Lumina 3.8 L Change Oil Pan Gasket
  161. 98 Lumina - Over Heating, Can't Nail Down Issue
  162. 91 lumina stalled / wont start
  163. low volt issue & then 3000 rpm when put in prk
  164. Motor dies and stumbles
  165. 96 Lumina LIM gasket replacement
  166. 95 3.1 dies intrmtntly, restarts for sec, dies
  167. when it rains it pours=-
  168. signal switch drama continues=-
  169. Replacing Starter on '95 3.1L
  170. 96 Lumina how to check if oil pump needs replacing
  171. pass-lock work=-
  172. Lumina 96 LS | 3.1L
  173. 95 Lumina oil level sensor
  174. 98 Lumina intake or head Gasket
  175. don,t replace multifunction lever=-
  176. Where exactly is the Transmission Vacuum Modulator
  177. Shaken Engine Syndrome
  178. Some problems with my Lumi
  179. Idle Air Control Valve quick ?
  180. buy new combo signal switch=
  181. 96 lumina random misfire after repair
  182. 1998 Chevrolet Lumina Engine Stottering
  183. Trouble with read troublecodes
  184. fuel pump relay controls? 3.1L
  185. 98 Lumina Code P0102
  186. '95 Lumina 3.1L
  187. vacuum and compression testing 3.1L
  188. 1998 3.1 no start only once=-
  189. Code P0305 check light on
  190. 1998 harmonic balancer unbalanced=-
  191. 1998 chevrolet lumina ls - instrument panel
  192. temp sending unit 3.4
  193. 1993 Chevy Lumina
  194. 1993 Chevy Lumina O-rings for Fuel Pressure Regulator
  195. Another Lumina won't start
  196. 96 lumina wont start
  197. Brand or No Name Gasoline - Does it really matter?
  198. Possible transmission fluid leak?
  199. 1990 2.5 NO spark in plug #3 and #4
  200. Loose Gear Lever-96 Lumina
  201. inner tie rod replacement
  202. 96 lumina instrument panel
  203. 1997 3.1L a/c by-pass pulley?
  204. Ack. I turned my Lumina into a LeSabre
  205. Weird Vibration from Rear
  206. Lumina loses power
  207. 1998 paint color code
  208. Which battery stock Lumina LTZ
  209. Stuttering at 40-45 mph
  210. 98 Lumina crank no start
  211. 98 lumina wont start
  212. crankshaft position sensor broken in engine.
  213. 95 lumina missing, shutting off intermittently.
  214. Transmission Fluid Capacity?
  215. EGR Flow PO401
  216. What size injectors in 1992 Lumina
  217. Transmission Qwirkyness
  218. 90 3.1 Lumina Stalling out.
  219. clicking brakes
  220. O-Rings for Fuel Injection
  221. 1990 3.1 Euro having the 'stall when warm/will only crank, no start' issue
  222. Does anyone want 98 shop manual?
  223. Moonroof issue
  224. Which oil should I use?
  225. Need Advice from the Experts
  226. 97 Lumina Electrical Starting Circuit
  227. Quick Lumina Starter Question.
  228. 1998 headlight lense replacement question=-
  229. Vacuum line on MAP
  230. Looks like a gasket went
  231. Gas coming from the vacuum connection on the fuel pressure regulator
  232. Steering Column/Shaft Disaster
  233. '91 3.1L V6 auto -- speedometer fluctuation issue
  234. A/C Compressor Replacing - How?
  235. Just bought 1998 Lumina 2 weeks ago!
  236. 96 lumina -lost my ignition keys
  237. Subframe Bushings
  238. 1998 Chevy Lumina Engine Scratching/Rattling
  239. 95 Lumina radiator fans
  240. '95 Lumina Sedan: Auto windows to manual?
  241. Ready to junk my 92 lumina
  242. 93 lumina starts idles high shuts off
  243. Spark plug wiring diagram
  244. Minor issue - rear luggage rack
  245. 92 Lumina will not start
  246. '98 3.8 oxygen sensor
  247. Possible hub bearing issue?
  248. Short in wiring harness: can it cause these problems?
  249. Steering Wheel Replacement
  250. 1996 Overheating, all coolant in expansion tank
