View Full Version : Park Avenue
Pages :
1 2 3 4 [ 5]
6 7 8 9 10 11 12 13 14
- Wheel Covers?
- Fuel related problems...
- High mount brake light socket
- '92 PAU with EGR valve issues
- wobbly steering wheel
- Problems Valve job
- Knock/rattle at idle in my '93 PA
- 95 P.A. traction light, no overdrive
- New PA owner with transmission shudder
- oil pressure/ cabin air filter
- engine replacement for 97 PA
- External Temp Sensor vs A/C - 1999 Buick Park Avenue Ultra
- code 45
- 1995 buick parkavenue ultra supercharged runs rough
- 95 buick color
- my 95 buick park ave
- The Great Debate
- 1998 buick park avenue ultra.... stalls
- 1988 Park Avenue Power Steering Issue
- Fuel Trim ?
- 96 pa strut knocking
- Pissed!!!Rear shocks
- 1997 PA Dash & Instrument lights
- Help with cut off riding along
- Lower Intake Manifold Replacement Questions
- 1989 Electra/PA Front Cover Gasket Leak after Timing set change.
- Can a stock PA have the ultra supercharger installed?
- trade off?
- has anyone experienced this???
- Buick Horn is so damn loud!!!!!!
- Hard start / dies when hot.
- 95 Buick PA park/turn signal Lights
- 92 buick park ave, turn signal flasher
- r-134 potential problems
- 2001 PA Ultra Brake Problem
- A/C blows warm on Drivers side-1999 Buick Park Ave Ultra :-(
- Park Avenue vs. Lumina
- Electrical Problem to Fuel Pump PAU 97
- Adding bass to stock system
- 1992 electrical issue??
- 89 park avenue automatic climate control dead
- 1992 Park Ave. Ultra unsteady idle
- 91 Park Ave. Won't Start After Reverse Jump Connection
- Another 1988 PA A/C Problem
- 2003 Ultra ed. - Air conditioner problem - no air
- 96 park avenue low coolant warning light
- rotors
- '98 PA seat adjuster panel
- Cassette Player error
- 92 PA oil issue
- need help 94 pack ave
- Re: Gas mileage & A/c ?
- 1995 Park Ave shift issue
- 97 PA A/C problem/noise?
- 92 PA, Engine Mount/Water Pump
- 1991 Idle/Over Drive Problems
- '91 Park Ave Half shaft
- Code 41? on a 91 PA
- Transmission ?
- 92 rocker panel replacement
- coil pack maintenace
- 1997 PAU Serpentine Belt Replacement
- Blows Fuses Shortly After Installing It
- A/c ?
- 93 park avenue charging trouble
- Rocker arm pedestal bolts
- 1992 cam sensor error question
- Park Avenue 1999 transmission bucking.
- 1999 buick park ave engine problems
- help for a stripped bolt
- Lowest Miles for 91-95? Continued.
- 97 PA Ultra problems!
- 92 parking brake light problem
- Replacing mirror
- Sunroof Problem
- 96 PA passenger door lock
- 96 P.A. Belt Replacement HELP, Is There A Trick To It???
- tag light?
- PCV valve problem-96 Park Avenue
- 92 PA miss when cold under 1500 RPM
- 96 P.A. repair maual and parts list non supercharger
- PCV Valve location on 96 P.A.
- Re: 1988 P.A. Tune-up & A/C problem
- brake help
- 94 Sputtering Problems over 50MPH Runs Rough, Hot
- Beautiful 96 Buick Park Ave P0102 Code plus few other problems
- 93 Buick PA Ultra glove box lock cylinder removal
- Buick Park Avenue /Electrical
- whats the differance between supercharged 3800 and a NA
- 94 Buick P.A. tune up
- Pictures
- 01 park ave keyless entry
- Squeaky Alternator
- 1997 Park Avenue Fuel Gauge
- quick tech questions 01 buick pa
- 95 PA starting & sputtering problem
- 1996 Park Avenue Climate Control
- 94 Park Avenue dying
- 91 PA Crank Position Sensor gap
- 1994 Park Ave Ultra Keyless/dome light problem
- Keyless entry ?
- Rear Passenger seat vanity mirrors
- Replacing my 96 PA heater core
- 95 Base Transmission noise when shifts to 3rd?
- 1995 Buick Park Ave Electrical - Engine cutting off
- 88 park ave
- rotor?
- sluggish turn signals
- Fog lights
- Climate Control Display
- abs light help needed
- Change Oil Soon Light
- 89 buick park avenue/ Starter fuseable link?
- 91 Park Ave Question
- 91 PA a/c driving me nuts
- Oil change question
- 91 PA A/C compressor seal leak - PW driver side inop
- 1999 park avenue supercharger idler pully
- 92 Park Avenue Blower Fan & No Start
- 88 buick park ave.
- 96 fuel pump control module
- radiator fan
- PA Vacuum Question
- 93 Buick Ultra dash trim
- Where can I get these parts?
- 97 A/C problem
- 97 PA electrical problems SOLVED
- A/C on the Fritz, Please help
- Best Gas
- Shaking while Braking
- 91 Park Ave Hard Start
- 1990 Buick Park Ave Keyless Entry Programming
- 97 PA idle problem
- Park avenue climate control flashing
- 94 park ave stalls while driving
- Seeking Eaton Supercharger M62 (or OEM/aftermarket)/rebuild
- little light by the alt guage 94 PA
- 99 PA Ultra Daytime Running Lights/High Beams
- 92 Park Ave
- 89 Park Avenue Rear Shock Replacement- Yikes
- 1998 park ave. rear suspension 2 full
- Oil pressure 97 PA
- 97 PA tire pressure warning
- 97 PA starting Issues
- 97 Park Avenue Driver Power Window Motor Replacement
- License plate lights removal...
- 1995 PA Seat Control/Window Lights
- 97 PA Trans kickdown
- 97PA voltage drop
- 94 PAU Intake Manifold Bolts
- 92 Buick Park Ave
- Alternator question
- 2003 Ultra Stability Question
- Repair/replace heated seats
- Mystery Radio Code
- 1996 Park Avenue air mix actuator
- Fuel rail removal
- 1995 PA Electrical Problems
- 97 PA What Changes?
- 1989 Buick Park Avenue starting problem?
- 97 PA Hums and Buzzes
- 95 park avenue starts but wont run.
- 1989 Buick Electra Park Ave T-Type Timing Chain Cover
- A/C question
- keyless remote fob programming
- 96 PA stalling problem
- 95 PA base radio swap
- Help with power seat
- 94 PA Turns Off When Hot Outside
- Vatts bypass
- Fuel injector question
- Engine infreq stalls code p0102 and p0300
- Engine light and infrequent stalling
- Engine stalls
- 91 PA starts when cold
- Lower Intake gasket Torque specs.
- 96 PA - Noise from the passenger side
- 1999 Park Ave homelink wiring questions
- Buick Fuel and temp gauge fix
- 1997 Buick park avenue - windows and door locks will not work
- Transmission issues - 2001 PA
- Weird lighting issue on '97 Park Avenue
- '97 Park Avenue - passenger heat goes cold then hot then cold, etc.
- 96 Park Avenue transmission filter seal
- what is this?
- 92 PA intermittent starting problem
- Intake manifold hose connector snapped
- 1993 park avenue horn
- 2003 Park Ave Ultra Grill
- 91 buick Starter Enable Relay
- 91 Buick Scanner Codes
- '92 Park Avenue Ultra with SES Code 57
- 91 Buick Park Ave Wont turn Over
- Got the new front struts on the 01' PA
- 99 Park Ave engine is racing
- 97 buick park avenue no radio, door locks, sunroof, or daytime running lights
- 94 PA, Dash Brake Light on, feels like no power assist
- left turn signal steady on
- Darn ABS/Traction control light intermittent...
- Buick Park Avenue Lights Keep coming on
- 1991 Buick Parkave Lugnut Size
- 97 Park Ave electrical problems- FRUSTRATED
- HELP! Intrument Cluster Lights Went Out!
- Trans Fluid Question - Dextron VI
- The '92 Park Avenue Ultra Acceleration Blues
- 97' PA Oxygen sensor/s location/s
- Water noise when it rains
- 1999 Park Ave Ultra Door Panel Removal
- 1991 park ave
- help with water pump
- 95 Buick PA falls off at higher speeds
- 1995 Park Ave early upshift, poor mileage?
- 97 PA Cooling Issue
- PAU '94 loses idle at times
- Any specialized tools needed
- 97 Park Ave Ultra - shf
- 1995 PA Stall/No start & repair?
- 92 Park Avenue won't start & security light flashes
- No Heat 97 Park Ave
- It just died!
- 92 park ave / heater
- 98 PA low oil pressure
- Removing Shift Knob?
- 89 Buick Electra/Park Avenue Valve Cover Bolts
- 1997 Park Avenue Belt Change
- 93 Park Avenue power seat, power mirror, and power lock
- coolant loss=head gasket?? and more q's
- 94 PA: Battery being drained by Lighting Monitor Module?
- Need some advice...
- Humming noise from the front end
- 91 Buick PA Ultra - Parts questions
- 91 PA Backfiring and No Power
- '91 Buick Park Avenue - Blower Motor?
- Temp gauge shows 0 all times
- 1998 park avenue ultra
- Flickering lights, battery dead
- Help needed on 91 PA: Service Engine Soon, Error Code 41
- Help needed on a 91 PA: central locking system & remote control
- Help needed on a 91 PA: Safety Light
- New to Buick and this Forum, some help please..
- '03 ultra, coolant loss, ticking, and ping?
- Intake Manifold destroyed-replacing it
- 95 Park Avenue Horn
- 98 PA flickering headlights with clicking sound in dashboard
- 90 PA emissions problem? Maybe?
- 95 buick park avenue need diredtion to program keyless remote
- Help with 91 PA
- 1989 Buick Electra/Park Avenue Hard to start/runs funny initially.
- 97 P/A a/c ?
- 2001 Buick Park Avenue Rear Defrost Issue
