View Full Version : Let's get Technical!
Pages :
[ 1]
2 3 4 5 6 7 8 9 10 11 12
- 2014 Honda Civic Eating Batteries
- Does car wash vacuum pressure cause display gets trouble?
- LED Headlights
- Drivers Window half working
- Voltage for my cars system seems off..?
- 2006 crv long starting
- Petrol Smell
- Possible To Over Drain Engine Oil?
- honda pistons
- 91 accord wont start
- Rubbing/Grinding noise continues even after changing both front W bearings
- Diagnosing P0420 Code (need help)
- Gasoline in oil
- Pre-Sale check up?
- help.. Need to align balancing shaft to oil pump gear
- 2006 Odyssey imbalance driver/passenger air temperature imbalance
- Intermittent Pump / Purge Noise - 2008 Honda CRV
- Please tell me about these parts...
- Honda valve cover gasket
- 2001 Accord question
- 1996 Accord VTec with white smoke
- 93 Civic AC enaging/disengaging quickly
- Car Won't Start. HELP!!!
- civic 1.5 engine problem
- Can you tell the Year of Accord by the Vin #
- How to remove scratches out of the screen?
- revving and holding at 3000 revs
- Civic starter cuts out--is there another relay?
- How much power should E85 K24 make?
- TSB's and free download of Electrical diagrams
- F22B1 In Acura CL 97 replacing with F22B Help
- need help with a b16 trans doghouse
- 94 Accord LX With F23 Installed
- Electrical Question 1991 Honda
- hook up oil pressure gauge not using sending unit
- silly question axles/trannys/vtec non-vtec
- 00 civic si mods?
- Car shut off while driving. Restarted shortly after.
- idle problem won't go away
- 1999 Honda Accord V6 transmission swap
- Intermittent misfire, bouncy tach, sparks out the exhaust
- Head swap to make my D15B7 VTEC
- 90 civic hatchback wont start
- D16Z6 engine rebuild
- Engine Misfire on 2001 Civic Ex
- Any Experience on 4x4 civic
- Poor Gas Consumption - 2006 Honda Civic EX
- Cruise Control Bumps
- help! my 92 LX honda's RPM's are running weird!
- 02 TL Type S Problem
- b16y4 head swap
- Tips ondriving safely with any honda car
- someone help!! crx b16
- high comression nippon racing b16 help
- Engine/transmission swap question
- does a 1987 honda accord have a carburator?
- When the engine is running does it still need battery charge?
- strange noise driving me crazy help!
- battery problem. plz help!!!
- HEEELLP!! CAnt FIgure Out this problem it might be electrical?
- Acura CL climate control
- My 92' Honda Accord H22A won't rev past 3500 rpm..
- Hard start
- Navigation Question - 97 Acura RL
- d16a6 swap to d16y8
- b16a with b18 crank
- All ash lights on, transmission stuck in low
- need some massive help PLZ
- 2000 honda coup died twice on the road tonight
- Help Understanding Performance Exhaust
- 1982 accord wont run.
- My. 99 honda civic ex wont start
- help! 90' crx si with gsr engine!
- Mini Me Swap
- i need help on my springs this is kindof a dumb question
- help with cam choice??????
- ZC valve adustment
- Valve Seals, Piston Rings?
- dizzy compatability 98 to 93
- acura cl 3.0L cylinder misfiring
- Shifter Rod Part
- No heat
- Honda Passport Transmission
- 95 Civic tranny in a 93 Civic
- Honda Tech's-Ventilation system problem
- starter problem !! PLEASE HELP !!
- flooded pls help
- 6 speed legend=unreal???
- B18B1 with a D16z6 manual trans?
- windows won't open in Accord LX
- 00 Accord SE will not idle
- Stripped bolt on fuel filter...HELP!!
- Ac/ Heat problem
- Civic 03 a/t system malfunction
- design flaw in front suspension???
- torque specs for acura cl fr control arms
- vibration problem need an expert my rsx is falling apart need HELP!!!
- Engine Ac problem
- b18b1 inner springs
- What's that box BEFORE the air filter box?
- 97 Integra GS-R Not Starting Problem
- 2003 Civic start problem
- Broken Cam Shaft on '90 CRX DX
- d16 questions?
- CRV 2002 starting RPM malfunction
- My brake lights dont work.
- 2002 acura tl tranny
- b20 nitrous help
- Any tricks or tips
- ODB conversion help.
- Fuel mixture needs adjusting in 1999 CR-V
- Single exhaust better then dual?
- 86 Honda CRX
- 91 CRX fuel problems
- D16 future turbo plans
- heeeelp
- b16a with b18 ecu??
- D15b7 head on a D16y7 bottom end
- This years crx si race motor setup help
- b16a will not start, please help, give me some ideas
- Flexpipe smoke?
- 92 Accord shift cable change, now with engine check light!????
- Backpressure: The myth and why it's wrong.
- Bad Alternator ?
- Power Lock can't lock the door from inside
- Smoking is bad
- Best way to flush
- o please for the love of god ...
- i need some help im my situation
- '00 Accord EX V6 Coupe Leaking oil
- ACURA 2003 TL-S, Transmission problems that cannot be fixed.
- Power Steering confusion :[
- Dimming Lights(dash and headlamps) in civic
- '90 civic / no start and/or fast rpm's
- Fuel PRessure regulators/Risers?
- Belt question. Please help
- really bad oil leak
- Im having a problem with my vigor please help
- cam help
- Putting a V8 engine into a Civic
- 98 accord v6, boggs really bad
- How do Hondas detect misfire?
- Honda Service Manuals
- resonator
- P0135 Heater Circuit Help! PLEASE!
- ZC starting problem
- Best high flow air filter
- P1166 P1167 Codes Honda Accord ...help !
- first gen 1987 crx pgm-fi engine light
- Honda Concerto D15b2 Engine 16v
- The best of the best
- help with code P1457
- S2000 transmission
- Air Pump / Misfires
- AEM V2 vs. Aem CAI for RSX Type-S
- exhaust manifold studs
- Newly built SOHC, overheat, white smoke
- 97 Ek swapped turbo civic...Won't turn over
- Is the Spark Plug the suspect?
- head design and compression = gas mileage
- oil thickness in stock engines
- b20 torque monster
- Rattling From Strut Tower
- Please Help Me I'm Freaking Out
- boosted single y8
- Con rods and Pistons
- 96 civic ex not running as good as usual
- b16a honda head
- 2001 Honda Crv - no air blowing
- distributor rotation problem
- anyone got a write up?
- 98 Sportshift Prelude tranny prob. lawsuit???
- Head gasket replacement gone wrong :(
- 93 Prelude H23 revving at idle
- need help
- Need valves for F20A DOHC
- Cylinder head?
- please i really want /need some educated opioion on my mods
- The cost for a nice street engine:
- street cams
- Camshaft bolt...AHH!
- Civic SI engine problem
- 97 Civic Engine Problem (bent valve?)
- Accord Hard Cold Start
- Resurface head
- Un-F**cking-Believable
- Prelude popping out of 5th
- bent valves on a 97 honda civic lx........Help
- specification needed ##
- car smokes at start up
- 87' civic gl motor swap.
- a sensible answer or a hammer
- Is this CAI legit, please i need help fast
- OBD II codes
- 100% new and a important question (Integra)
- CRX stumbles
- tight plugs
- Knocking Noise!!!please Help
- Is Lucas oil stabilizer safe to use?
- mini-me VTEC engagment
- does a 95 civic dx have power steering if its a 5speed?
- Ra Rodeo Hfv6
- Wanna pick your brains!?
- 3.5L bottom end diagram
- need help
- Need clutch help and opinion please
- ls vtech in 91 hatch
- Seatbelt Squeal
- d16z6 cam
- guys i need help with supercharger
- B16 Low power real problem
- BOSCH Oxygen Sensors Compatible?
- wacky turn signals
- tuning adjustable cam gears.
- need help bad
- fuel filter problem
- 97 CRV engine dies while underway
- i've got a problem
- honda civic 98 upgrade help
- Civic SI Intake Manifold problem
- engine break in.
- B16A swap into an Escort
- a little bit of smoke from engine
- "ticking" while idling
- Sluggish cruise control, pedal lets go
- i really need help bad
- What Are Cam Gears? and will they help my car
- Honda Diesel
- Complete tune-up...
- should i tune a 98 honda integra dc1, sohc, non vtec, zc engine
- Can headers be cheap ?
- Port Polish Help !
- Windows automatic function disabled after power was disconnected
- ecu harness
- 97 Civic Si
- engine, tranny fit?
- No coolant to lower rad hose
- tranny slips and car shuts off???
- fuel problem????
- b16a2 swap in a 96 civic ex
- Name brand turbo?
- 3rd gen civic 1.5 performance
- Turn Signal Problems
- 1.5 vtec question???
- tranny problem
- Accord EX Transmission - Strange Condition
- dual exaust
- Catalic Converter
- 90 Civic PGM-FI: Best Place to Check Fuel Sys Pressure?
