View Full Version : LeSabre
Pages :
[ 1]
2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
- 2000 LeSabre, gremlins in the modules!
- 3.8L P0171 High STFT
- 02 Buick Lesabre Custom occasional hard start, backfires occasionally, manifold exploded
- 2003 Buick Lasabre transmission hard shift
- 2003 Buick Lasabre blower control lever
- Introducing PAG oil
- 1999 LeSabre Air Ride Delete
- Random noise????
- 2004 Custom jerks when braking
- Another way to re-calibrate Throttle after cleaning it---programming
- Fault code P0300 misfire, P219A Air/Fuel Ratio Imbalance, 2 codes clear at once
- 02 Lesabre custom ignition help please
- Quad Driver failures - 1995 Lesabre
- 1995 Lesabre Check Engine
- 2005 Lesabre , fuel gauge alarm when full
- 03 LeSabre: Rack & Pinion replacement
- 2001 Buick LeSabre won't Run
- '92 LeSabre Limited - how to fix driver window regulator
- 2003 lesebre limited problems lighting
- Rattaling Lesabre
- Windshield washer nozzle retrofit
- 1995 LeSabre engine revving (Accelerating)
- 95 LeSabre Bucking
- 1992 Buick lesabre no power to blower A/C blower
- 2001 Buick Lesabre P0446
- common code 0446
- temperature of catalytic converter
- AC water on passenger front carpet
- 01 Limited: Driver mirror
- Question after upper and lowergasket rplmnt
- 01 LeSabre: Poor drivability and P0102
- Bolt broken off on hub assembly..
- 2001 Buick LeSabre - Transmission dead?
- 2005 won't start need to know something about testing Fuel pump
- Grinding noise after pump replaced
- 2001 limited only blows thru ac vents
- 03 lesabre wiper motor plug pin out
- Need help asap 02 Buick Lesabre
- 2004 Buick Lesabre Crank Issue
- 1999 Lesabre won't start or even click
- 2005 ran hot and shut off now starter just spins Please help
- 98 lesabre
- All exterior lights flashing with turn signal.
- Radio and hvac demons
- 2003 Buick LeSabre Electrical Problem
- 1989 LeSabre HVAC doesnt blow
- Lesabre car inspection
- Popping Noise From Back When Braking
- Are these problems related
- 03 Buick Lasabre Rear brake cable
- Oil leak at sensor abouve the filter.
- Stumped by Wheel hub etc
- Coolant leaks when Buick is not running.
- 2000 lesabre all dash lights stay on after starting
- 99 le sabre hot no start
- Shock / strut problem in 2000 LeSabre
- 97 lesabre cooling fans wont come on
- 97 lesabre ghost stall wont start for about 1 hour
- 2001 LeSabre: Exhaust leak
- Another GM Security Problem!!???HELP!!!!!!!
- 1987 Lesabre Occasionally won't start without battery dis/reconnect
- 1997 Buick Lesabre coolant leak mystery!
- Replacing tail light in 2000 LeSabre
- 87 LeSabre intermitten spark
- Thank You For All The Good Years On This Forum
- 1999 LeSabre Cannot turn off high-beams via on/off switch
- Grinding,screeching noise stop when AC is turned OFF !!??
- power seat switch 2005 Lesabre
- 1998 LeSabre Security Malfunction
- 2002 Lesabre Ltd - Plastic twist on ignition switch
- 2001 LeSabre AC just stops working, please help!
- 94' Buick Le Sabre brake problems
- 1997 buick lesabre
- Wire Harness...
- 96 buick lesabre periodically stalld
- '92 Buick Lesabre Limited - brake fluid leak issue
- HELP - 97 3.7L oil pump won't prime
- After dead battery, now won't start
- 2002 Buick Lesabre A/C settings after battery replacement
- Fuse purpose?
- 2003 bad shaking
- Cracked plastic in engine compartment
- Intermittent No-Crank On 95 LeSabre
- V6 Engine miss
- 2004 Lesabre no heat
- HELP!! 95 Lesabre No Start
- 1994 buick security light and alt, temp lights not working
- Manual Transmission in a Lesabre?
- Anyone owned a Lesabre and a Century?
- 1997 Lesabre - Blower case disintegrating?
- rear camber way too high (negative)
- Please help real quick: 95 LeSabre Tensioner Pulley Bolt Threads
- '97 Lesabre - Bad Alternator?
- Cheat Sheet on Elbo Replacment
- Putting Series III in '04 LeSabre
- Power steering line leak - rusted
- Cam Button Issue?
- HELP!!!! Vibrating and do not know what to do
- Noise in engine area
- explain the VSS (vehical speed senser) in a Lesabre
- 97 laSabre hvac
- Dies suddenly and restarts immediately
- Is there a usual problem with a horn not working?
- 3 Lights or 2, What Models?
- 1987 LeSabre Fuel Pump
- High Idle, Delayed Shifting - 03 Buick Lesabre 3.8L
- Fuel Pump
- obd fuse? '04
- 2001 LeSabre: Rear locks/windows no worky
- 2001 LeSabre: Air conditioner 20 deg warmer on driver's side
- 1994 Buick LeSabre revving
- Courtesy Lights Stay ON & Run Battery Dead
- 01 LeSabre Custom AC low pressure service port
- Plz help
- 1994 Buick LeSabre Blend Door Actuator location and removal
- orifice tube
- 1990 buick lesabre wont start
- 2003 Lesabre Limited
- 2001 Buick Lesabre losing coolant
- Power windows
- 1989 LeSabre no spark on 4 cylinders
- front subframe fell down?
- 2000 Lesabre suspension noise, 132K
- Has any Buick owner solved the high idle issue yet???
- lady needs assistance asap..blower problems
- 1994 buick ltd custom service engine light help
- please some one help with my blower problem
- exhaust noise "at times"
- 2001 Lesabre Pulls to the left while driving
- Turn Signal light trouble
- 97' Lesabre won't shift IN park. Can shift without brake
- 1997 Buick Lesabre - oil on spark plugs
- Front sway bar bushing noise
- Alcohol causing problems?
- Should I replace the fuel pump?
- Tranny, or something else?
- Gas/Fuel Gauge wacky
- Replacing Front Seatbelt
- Camber kit required for alignment?
- aldl connector location in a 1990 Lesabre
- Strut mount bushing/bearing replacement..help
- 01 Lesabre won't start after tranny issue
- 1995 LeSabre - PCM
- How Long Does It Take For The EGR Valve Light To Go Off?
- '94 Tie Rod Replacement
- 1995 LeSabre - Cruise Control issue
- 2005 Lesabre vibe after mount change
- '94 Multiple Trouble Codes at once
- shiftkit for a 4t65e
- New tires for 94 LeSabre
- 2003 Buick Lesabre Ltd
- 3800 engine noise at idle and shut down
- Headlights wont turn on 2001 LeSabre
- Help
- Air Suspension 2003 Lesabre.
- Replacing 1994 license plate light?
- Loud door dinger
- 95 Buick LeSabre Stalls
- 2000 Buick Lesabre ABS unit lines to rear. What hole
- 1994 - New Compressor, Clutch Not Connecting
- 1995 Lesabre - EGR Valve
- key relearn issue
- A/C question
- 2002 Buick Lesabre Ltd A/C Question
- 1990 Buick LeSabre rear Fuel Line leak
- 1998 buick lesabre steering pump
- DIC displaying "Turn Signal Still On?"
- TechII On the Money
- Ignition Cyclinder Lock
- 98' Charging issue
- 95 LeSabre Power Window problem
- Change Harmonic Balancer
- Engine noise knock
- 95 lesabre extremely rough idel
- Mixing Coolants
- Rusted right rear wheel well
- 1997 LeSabre heater won't turn off
- P0440 code
- 2000 lesbare fuel filter replacement question
- 2001 Lesabre idle speed
- 2001 Lesabre TSB info needed
- 2002 Buick Lesabre electrical issues
- 2001 Buick Lesabre almost starts but won't
- Body Man Needed!! Door Panel and Light Switch Question
- 94 Lesabre running rough and backfiring
- Need to put Seat Back
- 95 Lesabre leaks antifreezer near intake manifold
- how many motor/tranny mounts ?
- sick of it
- check engine light
- radiator
- HVAC and water leak
- tranny issue
- 2002 Buick lesabre radio questions
- 1998 buick serpentine belt
- Torquing bolts as 25 degrees.
- 2000 lesabre shudder when braking at 50 mph
- 91 buick lesabre heater blower
- I think I broke my Park Avenue by overfilling the oil
- 94 LeSabre 3800 Series I misfiring
- 92 LeSabre 3.8L Will Not Start
- Fuel pump and Fuel line diagram?
- Timing cover oil leak
- 3800 engine
- Transmission Questions
- 93 LeSabre
- 2000 Lesabre - Massive vacuum at oil cap
- Oil leaks on 98 leSabre--where from?
- How do you adjust the camber in 02 Buick?
- rattle in 95 lesabre
- 1997 LeSabre stabilizer bar
- Gas pump fail?
- Transgo shift kit for 4t65e
- warped brake rotors - 1997 LeSabre
- tranny mount 2000 lasabre
- 03 coolant leak
- 2002 Lesabre Drivers side outside mirror problems
- tech 1 or 2 for a 93?
- 93 lebsabre brake line
- 87 LeSabre timing marks
- 2002 lesabre fuel gauge problems
- SPID or RPO Code List
- 95 LeSabre AC problem
- Brake pad bent
- ECM Questions
- AC Recirculation (MAX) Not Kicking In - 95 LeSabre
- Radiator
- HELP! Auto Climate Control doesnt work.
- Vented battery
- blower motor not running
- 1987 Buick LeSabre not starting
- Snap/Clunk noise in front end
- 01 LeSabre misfire
- Still has hiccup
- 97 headlamp removal help
- 2002 Buick won't stay running
- Engine noise during warmup
- 98 Buick 3800 Smokes BAD!
- Rearview Mirror has fallen off!
- 95 lesabre brake trouble.
- 95 LeSabre Coolant Collecting Around A Bolt
- 95 LeSabre Misses During Heavy Throttle
- ALC auto level control pump rear air shocks
- '93 lesabre won't start
- Engine Hiccop
- High idle
- Replacement seat belt?
- 1995 Lesabre fails emission test
- 97 leSabre tcc problem
- 96 LaSabre Flasher doesn't flash
