Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-20-2009, 06:44 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Seting the timing on the 4.6 L
What am I supposed to line up here? What position are all the marks supposed to be in ?
http://cmasalvage.com/95ltc46l_tdc2.JPG
Next question has any one ever heard of these engines jumping time? Or is one side more prone to jumping?
Mike aka JYD
Old 10-20-2009, 07:23 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Seting the timing on the 4.6 L
They will jump time, but usually just one tooth. Usually the problem stems from a timing guide failing. I will put a picture here too.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-21-2009, 06:01 AM
Alright good deal. In that picture, I set that engine to what I believed to be TDC. Looks like I'm on track. Thanks for the drawing you posted.
Mike aka JYD
Old 10-21-2009, 02:14 PM
way2old's Avatar
TOKEN HILLBILLY
No problem. Just wondering where Peasticks is.
Old 10-21-2009, 08:53 PM
It's in the sticks of course, by Owingsville.
I have a fairly good idea of how to check the timing with out un necessarily tearing the whole front of the engine down. I need to pull the valve cover and rotate the engine up to see the timing marks and check to see that the brass links on the chain line up to the marks.
Mike aka JYD
Old 10-22-2009, 06:23 AM
way2old's Avatar
TOKEN HILLBILLY
OK I know where that is. You are right on checking timing. You do not necessarily need to line up the copper links. Those are there for installation puropses. If you want to try to line them up, go for it. Look closelu at the chain guides and the tensioners. If thwe chain is really worn. the ternioners won't be able to adjust the guides out to hold it in place. Then you sould skip a tooth.
Old 11-09-2009, 04:58 PM
danielsatur danielsatur is offline
The 8th cylinder is the last cylinder to fire on a 4.6L.
Remove all 8 plugs, and put a paper wad in the spark plug hole on cylinder 8, turn the motor over until the paper wad pop's!
This will put cylinder 8 @ TDC for guidance.
Turn the crank by hand to TDC on cylinder 1, and check all your timing marks.
I like using brake cleaner, so I can see the timing marks better.
Yep!
The primary cam tensioner can go bad , and derail the chain.
This canbe real fun with a DOHC, and leaving the cam chain cover on.
