| Latest | 0 Rplys |
#1 | |
![]() Join Date: Feb 2005
Sooooo...how hard is it to change spark plugs/wires on the v6 vortec? I've changed spark plugs before but as far as getting to the plugs, how difficult is it? Also what else should I do tune-up-wise while I'm doin this project? My service light went on and I found out it was a missfire, and I see other people's trucks are missing. Is there a known problem with sonomas that cause this or is it just a fluke? I have a 96. Thanx!
#2 | |
Problem?
![]() Join Date: Dec 2004
Re: Self Tune Up
It isnt hard at all, but it does require a little extra work. The easiest way is to jack up the side you are working on and go through the wheel well. To get to the #3 plug (middle one on the drivers side) you will need to remove the intermediate steering shaft. It seems like a pain in the ass, but it will save you a lot of problems and scrapped knuckles. There is one bolt holding the shaft at the bottom. Loosen the bottom and then the shaft will collapse into itself.
A complete tune-up requires: AC Delco platinum plugs Wires Distributor Cap Rotor Fuel filter Air filter PCV valve Remove, Clean and Reinstall with new gasket: EGR valve IAC valve You should also flush and refill your fluids. rear diff front diff (if 4wd) transfer case (if 4wd) antifreeze You should also replace your rad cap with a "Stant" brand. |
#3 | |
Problem?
Re: Self Tune Up
Another cause of misfires are clogged injectors or poppit valves. I usually use Techron Injector Cleaner. I put in two bottles and top off the tank. Most of the time it isn't recommended to do double shots of injector cleaner, but a bottle of Techron cleaner only does up to 12 gallons. So two bottles for a full tank isn't a dangerous concentration.
#4 | |
Re: Self Tune Up
Awesome..thanx a bunch!
#5 | |
Thanx a bunch..I'll write all of this down and get to workin on it. Is your 96 Impala on cardomain? I'd like to see some pics of it. Your blazer too actually, they sound pretty sweet. Thanx again for the help though.
