Go Back   Automotive Forums .com Car Chat > Automotive Art > Car Modeling > WIP - Motorbikes
Old 05-13-2011, 04:31 PM   #1
M.Boy
M.Boy's Avatar
Custom Version of Honda Super Cub Fujimi 1/12
I decided to build the same Honda Super Cub as my friend Macio but as the custom version
I will try to rebuild my Honda like this one
But I will not be reconstructed at the rear of the frame as was done in the above Honda. I stay with the standard version with a sprung rear wheel.
I started from the cut. This is I cut from my bike
but let's start from the beginning.
So it looks like a standard frame
I have to cut the engine mount and a box with air filter
after
I'll have to mill the excess material from the head cylinder.
I changed the front fork mount.
This is standard solution by Fujimi
I want to redo a mounting solution that is used Tamiya in most of their models of motorcycles
WIP: Custom CUb F100 Ducati 916 STUNT YAMAHA
GALLERY: VW Ducati 916 Custom CUb
Mark
Porsche 935 Tamiya 1/12 with Scale Motorsport Super Detail Kit FOR SALE
M.Boy is offline   Reply With Quote
Old 05-14-2011, 12:00 AM   #2
YongGun Park
Registered User
Re: Custom Version of Honda Super Cub Fujimi 1/12
WOW... You only need a small portion of the kit.
YongGun Park is offline   Reply With Quote
Old 05-14-2011, 10:56 AM   #3
M.Boy
M.Boy's Avatar
Yes, only most important parts
Mark
Old 05-14-2011, 12:27 PM   #4
cinqster
cinqster's Avatar
What a cool project!
That 1:1 is the absolute dogs b*ll*cks...so much so, that I am looking for a second-hand Cub to build a full-size one for myself!
cinqster is offline   Reply With Quote
Old 05-15-2011, 05:25 AM   #5
M.Boy
M.Boy's Avatar
Look in the net there is a lot of interesting modifications of this Honda.
It will be an additional inspiration
I started to modify the front fork
On my bike will not be front fender so I removed the mounting - red 1
I will change the way the wheel fixing. This is standard version
I'll use the axis and the nut so I cut the pin and plastic nut - red and green 2.
Plastic nut green 1 and 3 I will change for metal parts. No. 1 is too big.
From the inside I did plugs in accordance with the original
I removed the bolt which mount fender - green 4.
I also removed cap and I made such a specific hole with 2,4mm styrene tube - green 5
Mark
Old 05-23-2011, 07:02 PM   #6
YongGun Park
Registered User
It's very difficult.... But I understand. Ha Ha...
Old 05-26-2011, 03:02 AM   #7
M.Boy
M.Boy's Avatar
Continued work with a fork.
Fork glued together. I made such an overlay on top of the fork
after installation and initial treatment
I noticed that the fork of a set is different than at the motorcycle on which I was inspired.
So it looks fork from the box
and this is fork in this small chopper
I'll try to do something similar
Mark
Old 06-08-2011, 08:40 AM   #8
M.Boy
M.Boy's Avatar
I added some imitation of seams and edges of sheet metal
after primer
To attach the wheels and the fork I will need a long screw with a diameter of 1mm.
I decided that I'll do it myself
Mark
Old 06-09-2011, 04:18 AM   #9
M.Boy
M.Boy's Avatar
I started doing the mounting handlebar to the fork
from the bottom plate will be used to mount the lamp
and this is a lamp
I also tried to do handlebar
looks nice but I think that is probably a little too thin.
Mark
Old 06-13-2011, 01:31 AM   #10
YongGun Park
Registered User
Fantastic progress... Wow.............
Old 06-15-2011, 06:12 AM   #11
M.Boy
M.Boy's Avatar
Thanks.
Today I have a little more work with handlebar.
I used to bend the handlebar rod with a diameter of 2mm
compared with the earlier
and this is complete handlebar
Mark
Old 06-20-2011, 01:20 PM   #12
M.Boy
M.Boy's Avatar
As you can see at above pictures I also work with the bike frame
I cut right side box
filled rear arm from the inside
the left site I cut of the box and the chain guard
prepared complementary element
Mark
Old 06-21-2011, 07:04 AM   #13
YongGun Park
Registered User
Great progress as usual.
It's very nice to see your WIPs.
Old 06-22-2011, 02:06 PM   #14
davesans
davesans's Avatar
Excellent work the front fork is outstanding.
Regards,
Dave
davesans is offline   Reply With Quote
Old 06-22-2011, 02:34 PM   #15
M.Boy
M.Boy's Avatar
Thanks!
Continued work.
I forgot to mention earlier that the cylinder head has been milled
before
after
Thanks to my friend Maciek (Macio4ever).
I rebuilt internal reinforcement which previously I had to cut
also prepared a place for a new rear swingarm axle
corrected and added a twist of the screw motor
also I changed the bolts on the front of the cylinder head cover
Mark
Honda Super CUB Fujimi 1/12 Macio4ever WIP - Motorbikes 40 08-25-2011 01:24 AM
1966 Honda S800 - Doyusha 1/12 edwing666 Completed Projects / Gallery 5 04-28-2010 09:35 AM
Fujimi 1/12 Skyline Schnitzermann Car Modeling 10 08-01-2009 12:25 AM
LEAD: Honda Super Cub output exceeds 50 mil. units+ - TMCnet Automotive News Automotive News Desk 0 02-08-2006 11:10 PM
fujimi 1/12 R32 GTR martinu Car Modeling 3 09-01-2002 03:07 PM
