| Latest | 0 Rplys |
11-15-2005, 05:05 PM | #1 | |
Lexus Gas
What can happen when you use "regular" gas in a 99 (or other v-6) Lexus?
Charles ('90 Camry LE/ '99 Lexus/ '94 Celica/ '98 Camry) "Time flies like the wind; fruit flies like bananas" |
11-17-2005, 10:13 AM | #2 | ||
AF - Advisor
Re: Lexus Gas
Toysrme257th - AIM about anything, anytime; including v6 turbos. World's second ES 300/3vz-fe Turbo. |
12-11-2005, 11:15 AM | #3 | |
Thanks, ToysRMe. So far, no pings or anything abnormal from using regular gas. I don't drive the Lexus hard anyway. (I also use reg. in my 1990 Camry V6-being the cheap SOB that I am-and haven't had problems in 205k miles).
I heard that using regular gas could screw up catalytic converters on some cars; just curious.
12-11-2005, 11:08 PM | #4 | ||
AF - Advisor
Re: Lexus Gas
The entire VZ family is known for being low tuned & deonation resistant & would most likely run fine on 80 octane gas, if they made it. Raw gas kills cat's & o2's. The higher the octane, the more can go unburnt, causing higher emessions, higher exhaust temps & killing the cat. High octane should only be used when specified by the OEM. (It's not just a waste of money) Reset the ECU on the Lexus. Pull the EFI fuses out overnight.
