| Latest | 0 Rplys |
04-11-2004, 04:16 PM | #1 | |
Slow Starters are great movers ?
Hye Fellas
I have a ThunderBird 96 Lx I just (less than a week or so ) got it and drove it 6 hrs to bring it home. At that time things seemed pretty well. Then all of a sudden the Check Engine Light came on. Diagnostic Code was read (it came from 2 sides of engine) and Mech told me , its nothing to loose Sleep on. Couple of days passed, and now when I start the car, it DOES not change gears immediately . There is a "lag" , sometimes short and sometimes not so short (where the car just idles slowly) & then it abruplty "picks up" after that ...runs ( and runs fine). Any association with the "check engine" light and this prob. Is this prob solvable ? or serious trans prob ?.....I hope this was'nt another damned lemon...... Someone to enlighten .... ? Thanks folks....Enjoy the Easter !!! |
04-11-2004, 05:00 PM | #2 | |
Re: Slow Starters are great movers ?
does this happen when you shift out of park into any gear all the time? or is it just when shifting into/out of reverse or drive? do you "start and ride" or do you let the car warm up for 5-10 min? do you notice any difference when doing so? is your car a 3.8 or 4.6 and have you ever had it serviced/flushed/replaced filters? details are necessary for diagnosis.
04-11-2004, 06:32 PM | #3 | |
Hi there
Thanks for your promptness: Here are the clarifications ,Sir: * does this happen when you shift out of park into any gear all the time? or is it just when shifting into/out of reverse or drive? It happens when I shift out from P to D. I have'nt distinctly noticed when I go D to R. I'd say only from P to D *do you "start and ride" or do you let the car warm up for 5-10 min? do you notice any difference when doing so? I owned a manual Trans (old 87 Corsica) so I always am set to go. i.e. I always "Start and Ride". I will like you suggested , try the latter. *is your car a 3.8 or 4.6 and have you ever had it serviced/flushed/replaced filters? It a 3.8 V6 . Have'nt replaced the filters.......would that be a possible reason ? I just got the Car for a whopping $3.3 Gr "as is" . I am not sure now looking back , if it was the wisest thing.... the only reason that being done to avoid those costly monthlies that dealers were asking for Newner Hyundais,Toy'a etc . I had a passion for the T Bird ...to be my first "good for good car" ..hope it will be so . Thanks again for your help.... Sam |
04-15-2004, 04:00 PM | #4 | |
when i say filters, i meant the trans filter and the intercooler filter for the trans. if the the trans has never been serviced, flushed, filters checked/replaced, it 'could' be a simpler solution. always start with the most obvious or easiest solutions and work up from there.
sounds like a belt or plate in the tranny doing it, but the only way to know is to have it pulled out and inspected, which means $$$. you should have an IRS suspension as well, and Ford recommends that the IRS bushings be inspected at 80k and replaced at 100k miles. soooo... the lag (and possibly a "clunk" sound when dropping gears from P to D) can be attributed to that (the bushings fail to support and absorb the shock within the tranny), therefore lagging and/or 'kick/clunk' when plates engage. just a thought. . . let us know how it works out.
04-15-2004, 11:34 PM | #5 | |
Thanks a plenty. I 'll have the mechanic check it out at ease. Hope its not something that demands fast attention...can buy a few months time.
Thanks Sam |
