| Latest | 0 Rplys |
06-26-2012, 09:35 AM | #1 | |
2002 suburban rear axle seal
trying to replace axel seal have removed rotor and have rear cover off i see a pin held in with a bolt will i get in trouble if i remove it also see a clip that looks like it holds axle in place
06-26-2012, 09:51 AM | #2 | |
A990 racer
Re: 2002 suburban rear axle seal
Removing the small bolt, be careful they break easily, then you can remove the cross shaft pin, push the axle in and remove the c clip, try not to lose the position of the spider gears or it can be a pita to get it all back together.
06-26-2012, 07:39 PM | #3 | ||
the bolt can break. If it does I used a reverse drill bit. only occured once for me. when installing the bolt clean threads and use medium lock tight. torque to the proper amount. |
