Go Back   Automotive Forums .com Car Chat > Dodge > Ram Van
Old 02-26-2011, 01:57 PM   #1
iwishuheaven
1997 Ram Van 2500
I need to replace the outer-right tie rod and sleeve. I may try this on my own. Do I need to raise the van up to do this? Is it just unscrewing nuts and bolts, or is there more to it than I realize?
iwishuheaven is offline   Reply With Quote
Old 02-26-2011, 03:07 PM   #2
alloro
Re: 1997 Ram Van 2500
Being able to raise the vehicle to remove the tire would greatly simplify the task. That aside, you should be able to change it on the ground. As you turn the old part off be sure to count the number of turns and reinstall the new part the same number of turns.
alloro is offline   Reply With Quote
Old 02-26-2011, 03:27 PM   #3
MagicRat
Nothing scares me anymore
MagicRat's Avatar
You probably need a tie rod pickle fork or press to remove the old piece.
Look here: http://www.youtube.com/watch?v=TYIDzXxeNwk
MagicRat is offline   Reply With Quote
1997 Ram Van 2500 Overheating iwishuheaven Ram Van 1 09-18-2010 02:17 PM
94 ram van 5.2. intermittent elec/start prob stnich Ram Van 3 07-14-2010 01:11 AM
HELP! URGENT! Shifter won't shift! 2002 Ram Van 2500 ammcf1 Ram Van 5 03-06-2008 10:48 AM
'95 Dodge Ram Van 2500 318 defiant79 Ram Van 0 08-30-2006 04:36 PM
96 Ram Van 2500 3.9l smoking, no power RamDodge Ram Van 1 08-04-2005 01:47 AM
