Go Back   Automotive Forums .com Car Chat > Car Audio
Old 10-14-2003, 01:30 PM   #1
whiteracer
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
ah dangit, screwed up my tach
I was bored this morning and i found my package of my white faced gauges on my porch at about 9:00 in the morning, Went and put them on and everything went smoothly, I started at the fuel/water gauge, kinda touched the needle a little (ok a lot) and it went on and seems fine, the speedo was no problem, I barely touched the tach needle and finally when i got it all back together, the tach goes from 0k to like .5 k and didn't move when i hit the gas.
what to do?
Name's David.
whiteracer is offline   Reply With Quote
Old 10-14-2003, 02:07 PM   #2
T!mmy
Send a message via AIM to T!mmy Send a message via MSN to T!mmy
Ok for future reference...educate me on installing new gauge faces...why aren't you supposed to touch needle etc etc.
Thanks
The Dr. tells me too much masturbation is unhealthy...So when is "too much" masturbation "too much"???
Check out our car club site which I made http://www.almostperfectcc.com
Originally Posted by 18c5sol94
we go from a stop he pulls a little on me (only cause i can't keep the wheels on the ground)
T!mmy is offline   Reply With Quote
Old 10-15-2003, 10:17 PM   #3
60hz163.5db
60hz163.5db's Avatar
touching the needles is bad because they are very sensitive but they should move that much. if it's only the tach trying revving while holding the needle lightly at the base also make sure there is catching under the needle base..
Past that i don't like to touch gauge faces i do it when i have to.
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
60hz163.5db is offline   Reply With Quote
Old 08-18-2004, 09:36 PM   #4
94cordvtec
Re: ah dangit, screwed up my tach
how had is it to put on white gauge faces on. do the guage faces come with slits or something to go around the needles?
94cordvtec is offline   Reply With Quote
Old 08-18-2004, 10:49 PM   #5
TheOutsider
Send a message via AIM to TheOutsider
mine did the same, but after a good day in the hot sun, my gauges laid flat and i havent had trouble from them since
TheOutsider is offline   Reply With Quote
Old 08-18-2004, 11:09 PM   #6
T-Racer
T-Racer's Avatar
Send a message via MSN to T-Racer
well i know if you got a jdm cluster it is as easy as pie to instal. take out the screws holding in ur stock one, take the plugs out, plug in, and screw back together.
My name is Tyler, don't be afraid to call me it.
Originally Posted by BlaZeNSmoKe
So next time I see a deer and I can't dodge it, best believe I'm gon' speed up. Cause he ain't gon' get the best out of a accident with me, no sir.
T-Racer is offline   Reply With Quote
Old 08-19-2004, 08:58 AM   #7
juicy19
Send a message via AIM to juicy19
Check to make sure the needle is hitting the new gauge face. That could be keeping the needle from going any higher than 500 RPM.
2001 Honda Prelude SH
DC Header
3" Intake with K&N
GReddy Exhaust
Unorthodox Racing Pullies
JET enhanced ECU
10.3 OBX Plug Wires
juicy19 is offline   Reply With Quote
Old 08-20-2004, 01:12 AM   #8
SilverY2KCivic
Cali Guy
SilverY2KCivic's Avatar
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
I'm heisitant to help, I saw the ClubSi post....
In any event since I try to be a helpful guy, I'd say like above make sure the needle isn't touching any part of the new guage face that you put on. Next make sure nothing is holding the need itself back from moving beyond the 500 RPM mark. And if all else fails, time for a new tach meter which can be had for a moderate price (though a bit less than local dealership) from off www.hondaautomotiveparts.com
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
SilverY2KCivic is offline   Reply With Quote
1999 LeSabre - strange short-term fix for speedometer and tach that sometimes works Taurus1997 LeSabre 8 01-07-2011 01:29 PM
Max AC Clicking/Tach Problem tominton Cavalier Problem Diagnosis 1 07-09-2009 03:27 PM
Display thingy dangit MN Hunter Aurora 5 06-11-2005 10:04 PM
Dangit!!!!!! silverstangs Mustang Talk 4 04-07-2005 09:05 AM
DANGIT! Transmission P.O.S. PLEASE HELP! thoboyz Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 06-23-2004 11:27 AM
