Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 09-26-2016, 09:10 AM   #1
dgdowli
2004 Grand Am AC issue
I have a 2004 Grand Am GT with 30,000 miles AC went out replaced compressor dyer orfice filter and high side valve recharged and worked great for 2 weeks now will not cool at all have vacumned and recharged the system 3 times temp starts to go down about 10 degrees then goes back up will not go lower compressor and fans are kicking on and running fine the system is full of freon just will not cool at all any ideal?
dgdowli is offline   Reply With Quote
Old 09-27-2016, 04:53 PM   #2
Tech II
Re: 2004 Grand Am AC issue
Why was all this replaced in the first place?
So you replaced, the compressor, the drier(accumulator?), orifice tube and hi side valve.....you evacuated the system, and added freon by weight?
With the A/C off, normal operating temp, is the temp out of the register, 140-155F with control at full hot? Does it drop down to ambient air temp, when control is set to full cold?
If it does, the temp actuator is working.....now, read the ambient air temp(use a thermometer or infrared gun) with A/C off, and full cold setting......now turn on the A/C, MAX setting....is the compressor running? it should run constantly......What was the register temp, and how much does the temp drop with the A/C running? What was the ambient temp at the time, and any guess what the humidity was?
Tech II is offline   Reply With Quote
