| Latest | 0 Rplys |
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
10-24-2004, 09:11 AM | #1 | |
Water Injection Cooler Vs I/c
If You Were To Use A Water Injection Cooler On Your Ztt Would You Still Need To Upgrade Your Stock I/c?
10-24-2004, 11:21 AM | #2 | |
Re: Water Injection Cooler Vs I/c
each one cools
i read about a guy that got a drop from 320F to 170F using water injection, another about another 40F drop when he used an intercooler too depending on how much boost u want to run depends on whether ull need to upgrade the stock ICs, but if u havent upgraded the turbos then i doubt ull need more than the stock ICs and water injection since they cant boost past about 18/19 anyway (and if im not mistaken, at these levels youll get injector float) so ud need to upgrade injectors and turbos before u needed a bigger intercooler if u had water injection
dan says: theyre talking about intercooling like its a good thing ????????/ |
10-24-2004, 01:14 PM | #3 | |
Z Cars Fanatic
yeah you will definitely need alot more to out run the life of your stock IC's or to use water injection. stock intercoolers can handle quite a bit of modding. but if i were you i would add water injection and just boost at the same levels you plan on. say 14-15 psi. i would boost there with a water injection kit. even though you dont really need it if you have a ECU and what not. i would do it just to be easier on my motor. my opinion.
ZedEx Crew Member #4 |
10-24-2004, 01:41 PM | #4 | ||
10-24-2004, 04:14 PM | #5 | |
Whats Water/alky?
Do You Mean Methanol. If So Who Sells This Kits? |
10-24-2004, 07:11 PM | #6 | ||
Re: Re: Water Injection Cooler Vs I/c
Below is the fact about water/alky injection, and instructions for the DIY people. http://www.geocities.com/rad87gn/tech/alcohol.html http://members.cox.net/stevemonroe/AlcoholInjMod.html |
