Go Back   Automotive Forums .com Car Chat > Ford > Thunderbird
Old 09-11-2011, 06:59 PM   #1
mudrunner80
95 tbird stranded huge puddle of tranny fluid
It seems to be coming above the tyranny mount drivers side. Too hot to check. Any ideas? I'm still 200 miles from home. :-(
mudrunner80 is offline   Reply With Quote
Old 09-11-2011, 08:02 PM   #2
Moppie
Master Connector
Moppie's Avatar
Re: 95 tbird stranded huge puddle of tranny fluid
How big is a huge puddle?
And has the car stopped, or doe it still run?
Get the dip stick out and check the level.
It may be something simple that will let you get home, but with out some more information we can't really help.
Moppie is offline   Reply With Quote
The Following User Says Thank You to Moppie For This Useful Post:
mudrunner80 (09-15-2011)
Old 09-12-2011, 06:36 AM   #3
mudrunner80
Its quite huge. The dip stick don't even read fluid. It still runs but its pouring out faster that I can pour it in. I pulled off in a park n ride. It was dripping down the back of the pan by the mount. Hoping its something simple but with my luck I doubt it. I still have. 160 miles till I'm home. :-(
Old 09-12-2011, 07:29 AM   #4
Moppie
Master Connector
Moppie's Avatar
Sounds like you maybe calling for a long haul tow.
I can only suggest you check simple things, like the drain and refill plugs are in and tight
Also check the tube that holds the dip stick hasn't come out.
Otherwise it's likely to be something more involved, thats going to need a lift and some tools to fix.
Old 09-15-2011, 02:30 PM   #5
mudrunner80
Problem found. It blew the gasket there the tail shaft and the transmission connect. One question I have is I can't seem to get the bolts connecting the driveshaft to the deafened. Are they reverse threaded??? Dont seem right they would be on that damn tight!
Old 09-15-2011, 08:27 PM   #6
97Bird
97Bird's Avatar
Turn counter-clockwise to loosen. Be sure to use a 6 point socket or wrench to avoid rounding the heads.
The Original 97Bird
97Bird is offline   Reply With Quote
The Following User Says Thank You to 97Bird For This Useful Post:
Old 09-15-2011, 08:38 PM   #7
mudrunner80
I've been beating on them for a day and a half and not one broke loose yet figured I'd double check. I've Never seen any bolt this tight except on the front axle shaft on my truck!!! 3 knuckles and 2 wrenches later and still 4 bolts to go. Grrr
Old 09-15-2011, 08:52 PM   #8
97Bird
97Bird's Avatar
You could also use a heat wrench (torch) if the kroil doesn't work.
The Original 97Bird
Old 09-15-2011, 08:57 PM   #9
mudrunner80
Was hoping to avoid heat since the fuel tank is inches away. The way my luck has been the past month I'm afraid to even use a q tip lol
Old 09-16-2011, 01:52 AM   #10
Moppie
Master Connector
Moppie's Avatar
I've once had to put a big breaker bar on the driveshaft bolts, put the car on the jack, take the axle stands out, and lower the car, using it's weight on the breaker bar to under each nut.
It takes a while, putting the axle stands in and out to be safe, but it works very well.
Just make sure you have a good socket so it's doesn't round of the bolt, and you have the bar going in the right direction.
Serpentine Belts & Tranny Fluid Don't Mix!- HELP! Alphabravo Caravan | Voyager 9 10-18-2009 04:47 PM
I Ran Thru A Huge Puddle And Now My Car Wont Start es_class Sebring | Sebring Coupe | Convertible 1 01-16-2008 10:45 AM
96 LSi Tranny fluid puddle on top of tranny bambambam Metro 2 06-14-2006 11:16 AM
86 Tbird turbo 5 speed tranny, T5? americustbird Thunderbird 0 12-19-2004 11:55 AM
Tranny fluid not gearbox fluid? 5_LiTeR_EaTeR Engineering/Technical 4 04-13-2002 01:15 AM
