Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon
Old 03-20-2005, 12:11 AM   #1
tequilajo04
SRT-4 Stock Fuel Injectors
I know this has probably been asked before but I could not find it. I am currently building a custom turbo kit for my '02 Dodge Neon. Will SRT-4 stock fuel injectors work on the 2.0l SOHC? If they will, they should be good to run 4-6 psi right? Thanks for any info
tequilajo04 is offline   Reply With Quote
Old 03-20-2005, 07:44 PM   #2
tequilajo04
Anybody know???? And what I ment ^ was, it should work with bigger fuel pump for 4-6 psi right?
Old 03-21-2005, 05:12 PM   #3
chexmixa
Re: SRT-4 Stock Fuel Injectors
Well in theory it should. All depends if the injectors from a 2.4 will fit up to a 2.0
chexmixa is offline   Reply With Quote
Old 03-21-2005, 09:55 PM   #4
TEXSRT4
the injectors will fit, you will however need a source to control the injector pulse. otherwise you will flood the motor. 04 and up injectors are WAY bigger than will work on a low boost neon without control! but yeah they will work for you
TEXSRT4 is offline   Reply With Quote
Old 03-30-2005, 05:01 AM   #5
ieatimport
i have a 2001 r/t that i just turbocharged, i'm running the stock fuel system at only 5psi. I have been looking for answers to the your same question, and cant seem to find them anywhere. I know the srt injectors are perfect for our application, but how do we control them? do we need to re-programm the computer? get a standalone system? or can we just use one of those apexi fuel computers like the hondas do? does anyone know whats the cheapest way to control your fuel injectors?
ieatimport is offline   Reply With Quote
Old 03-31-2005, 03:49 PM   #6
TEXSRT4
pick up an AFC fuel air controller. it will run everything just fine and dandy for you. you will be set to go after a little adjustment
Old 04-07-2005, 09:00 PM   #7
vamc
vamc's Avatar
try summitracing.com. I live close to summit racing, and they have alot of fuel injectors and cpu to controll them
vamc is offline   Reply With Quote
