Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-15-2006, 06:09 PM   #1
billindelicato
billindelicato's Avatar
Persistant Clunking
ok again let me set the tone for you...i was noticing a loud clunking noise from in and around my right rear wheel so i took it as well time to replace the shocks...so i did 4 monroe sensatrack shocks...BUT THE CLUNKING IS STILL THERE!!! i go to look for inlets to possibly lube the parts THERE ARE NONE!!!...perhaps its the leaf springs? upon inspection i didnt notice any cracks at all in the springs. any idea?
billindelicato is offline   Reply With Quote
Old 02-15-2006, 06:54 PM   #2
Gizmo42
Gizmo42's Avatar
Re: Persistant Clunking
Most likely suspect to me would be body mounts. They have been known to cause clunking if bad or loose. Next I would susupect rear spring bushings. Its a start.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Gizmo42 is offline   Reply With Quote
Old 02-15-2006, 06:59 PM   #3
billindelicato
ok say its the body mounts how can i replace or repair them?
Old 02-15-2006, 07:03 PM   #4
amigo-2k
Isuzu Guy
what year?
It could also be the drive shaft. See the FAQ's
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
Old 02-15-2006, 07:22 PM   #5
billindelicato
1997 the faq's appear to be only for +98
Old 02-15-2006, 08:10 PM   #6
rodeo02
Where is the jack & tire iron stuff on the 1997's? I know it sounds silly, but I've seen (and had) jack handles flop around and cause the issue you describe.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
rodeo02 is offline   Reply With Quote
Old 02-15-2006, 09:13 PM   #7
johnsm
Check if your exhaust pipe is hitting your axle.
John
johnsm is offline   Reply With Quote
Old 02-16-2006, 10:37 AM   #8
billindelicato
i checked the clearance for the exhaust and its just fine...i took it to my dads shop and he seems to think its both the bushings and the body mounts so ill change out the leaf springs and body mounts and get back to you on it
Old 02-16-2006, 11:35 AM   #9
redbug
It's probably your leaf spring bushings. I have a 95, same thing, thought it was wheel bearing, changed it, what a job that was... made no difference. Noticed leaf spring was not sitting even. Found that Napa sold the lower bushings, must have been common failure. Took the old ones out, they were shot. Put new ones in, problem solved. I have 206,000 miles.
redbug is offline   Reply With Quote
