| Latest | 0 Rplys |
#1 | |
Didn't find the right parts for 3.8L 98 Lumina
Hi,
we have an coolant leak and the only wet place are the two hoses up on to the belt tensioner. A couple time ago I replace the tensioner, elbow, upper and lower gasket, Oil is clear. But I can't find the gasket for the 2 hoses (heater?) Are these the right one? http://www.rockauto.com/catalog/moreinfo.php?pk=1309871 |
#2 | |
Lactose the Intolerant
![]() Join Date: Aug 2004
Re: Didn't find the right parts for 3.8L 98 Lumina
if you are looking for an o-ring type seal, easiest way is usually to remove one and take it to the parts store and they will match it from an assortment.
Otherwise you can usually buy a small assortment of o-rings in a pack and it will usually have what you need. Here, anyway, don't know what you have there as far as parts go.... Every time I run across an o-ring in a fuel or cooling system that I don't have, I buy one of these. Has not failed me yet ![]() http://www.oreillyauto.com/site/c/de...0243&ppt=C0142
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
#3 | |
Have you thought of replacing the whole fitting? Not sure of the cost....
#4 | |
[quote=McLin;6945732]Hi,
we have an coolant leak and the only wet place are the two hoses up on to the belt tensioner. A couple time ago I replace the tensioner, elbow, upper and lower gasket, Oil is clear. But I can't find the gasket for the 2 hoses (heater?) Are these the right one? Are you talking about the o-rings that go on the two 90 degree plastic elbows that route the cooling water through the serpentine belt idler to the heater hose then onto the heater and then back to the engine in the reverse order ? If so , replacement elbows will come with the o-rings in place ready to install . The elbows are inexpensive and should be replaced as the plastic deteriorates with age and cracks . This leads to leaks often so slight that they are hard to detect causing a constant low coolant level . Eventually they will fail in a big way leaving you stranded by the side of the road .
" Sometimes I grow so tired " |
#5 | |
#6 | |
Oldblu65 and I are referring to Part #6....it's the fitting that comes with o-ring #8.....you just remove bolt #7, and the fitting comes out....I personally would replace the whole fitting instead of just the o-ring....
The Following User Says Thank You to Tech II For This Useful Post: |
McLin (12-14-2011)
#7 | |
Can you look if you find it on rockauto, please?
