| Latest | 0 Rplys |
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
01-09-2005, 07:13 PM | #1 | |
overheating please help
ok i have a 1990 Z...i blew the first engine so i have a jdm engine in my Z.
the problem is that yesturday i was going to school and all the dash lights came on, except the check engine....the alternator belt was gone, so i replace it, and everything worked fine...but then i did a small burnout...the top hose that goes to the radiator broke in two pieces...i went to autozone, get a new one, put some antifreezer and the temperature gauge at first didnt move, drove it like 5 minutes and nothing, i felt my car more slower than usual....then the gauge suddenly like nothing went all the way to the middle, and then it start going up and up, i shut down my engine... when i was coming to my house, the gague was on High...i suddenly stopped and when I open my hood, my radiator explote, all the antifreezer everywhere.. so i bought a new radiator... one week ago i change the termosmester and the radiator cap... the problem is that i dont feel the engine hot, or the radiator, but the gauge it marks High....when the car is at idle, it goes fine....as soon i drive my car my gauge get all the way to High, but i touch the engine and it doesnt feel hot, and i touch the radiator and it doesnt feel hot.... where is the problem? my fan works..... |
01-09-2005, 07:47 PM | #2 | |
Z Cars Fanatic
maybe engine temp sensor...
also, you said you replaced the thermostat??? try resetting the computer also... something is not reading right...makes me think coolant temp sensor or thermostat....
ZedEx Crew Member #4 |
01-09-2005, 08:05 PM | #3 | ||
Re: overheating please help
how do u reset the computer? but how its possible that my hose explote and my radiator too? i mean, there should be a problem, i dont think just changing the radiator will cure the problem....i am afraid to drive my car like that and fuck my new radiator... |
01-09-2005, 08:45 PM | #4 | |
reset teh ecu by disconecting the negative terminal on your batt.
01-09-2005, 10:01 PM | #5 | ||
Z Cars Fanatic
Re: Re: overheating please help
did you replace the thermostat>???? it sounds like it is getting stuck closed and opened...
01-09-2005, 10:02 PM | #6 | ||
The water pump is not working......If the radiator is not getting hot its because the water is not entering the block to conduct any heat.
01-09-2005, 10:08 PM | #7 | ||
Afterthought........I am now quoteing myself........Note to self........Get help......ha......
01-09-2005, 10:10 PM | #8 | |
Z Cars Fanatic
oh yeah, check your water pump like ehonda and ehonda said...
01-10-2005, 08:22 AM | #9 | |
Did you install the new thermostat in the right direction and was it the right one for your Zed?
01-10-2005, 11:56 AM | #10 | |
Did you bleed the air from the system. That would cause a over heating problem like you described. A air pocket is forming around the thermostat and not alowing it to open when it should. Just "burp" the system and everything should be fine.
Finaly got pics of my car....... after I washed it of course. |
01-10-2005, 06:06 PM | #11 | |
Yer right Mr. Hodo, The Zed32 has a bleeder on it to help bleed the air out, and if you don't guess what? It well keep heating up and boiling over.
01-10-2005, 06:35 PM | #12 | |
How do you burp your car?
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105 |
01-10-2005, 09:18 PM | #13 | |
Pat it on the hatch till it burps.....
No serriously. Most of the time I park on a hill with my front end facing up hill to get it higher than the rest of the car. Then I open the coolant resovoir cap and the radiator cap, start it up. Let it run till it reads warm or till It should be warm, and turn on the heater full blast. Watch for bubbles in the coolant tank. Squeeze the upper radiator hose a couple of quick times to make sure that its flowing and to make sure no air is trapped in the system. Do this for about 10 to 15 minutes and top of the coolant and your done. I am sure Nissan has a official way of doing it but thats my way. Its not the quickest or the smartest but its the easiest for me.
