| Latest | 0 Rplys |
04-12-2012, 11:08 AM | #1 | |
2001 Ram 2500 brake line leak
5.9L, Short box, quad cab, 4x4 with ABS in the rear and rear drums.
I have a rear brake line leaking, it appears that fluid is draining down from the frame rails near the gas tank on the driver side. I assume my issue is the common rear leaking line. What has everyone done for these fixes? Get a new prebent line (steel or SS) or just patched something in? If you patched or run a new line next to the old one how have you secured the line? Just looking for any information I can before I start the project! Thanks. |
04-12-2012, 07:14 PM | #2 | |
AF - Advisor
Re: 2001 Ram 2500 brake line leak
If and when mine starts leaking, I'll replace with pre-bent stainless since I'll have the fuel tank off.
If I have to take the fuel tank off for any sort of maintenance, I'll install the stainless brake line then too.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
